02-16-2010, 11:58 PM | #1426 |
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
wonder what that pic was!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
02-17-2010, 12:01 AM | #1427 |
I have car A.D.D.
Maybe it was the award winning Rooster from the other day.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
02-17-2010, 12:21 AM | #1428 |
Next project: 1970 K10
You guys can't see it?? Hmmm, I still can. How 'bout this one?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
02-17-2010, 12:23 AM | #1429 |
I have car A.D.D.
Nope, it says TINYPIC "This image or video has been moved or deleted." I bet its the rooster isn't it?
02-17-2010, 12:41 AM | #1430 |
What rooster are you talking about??
Are you looking at it on your phone? I tried that and it shows the tiny pic thing too, but it's just fine on the laptop.
02-17-2010, 12:51 AM | #1431 |
Gettinlow & Goinfast
Bob, those are some very nice numbers for a stock motor swap!!
I was looking at the ls6 cam but I've decided on the ASA cam that Gm offers it's a torque cam with lots of overlap and really mean idle.
Protouring Texas built rides- 78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390 71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html 70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo- 85' C20 crew, 5.3/6L90/S475 turbo- 68' C10 5.3/4L60/Level 2 coil overs Facebook- Protouringtexasdotcom Instagram- @Protouringtexas Last edited by lownfast; 02-17-2010 at 01:23 AM. |
02-17-2010, 01:18 AM | #1432 |
I have car A.D.D.
No I am on the PC. And the Rooster was from a text the other day. Maybe I forget to send it after what happened the other day.
Edit: I checked with my phone just to see and it is the same there as well. I don't get it.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 02-17-2010 at 01:26 AM. |
02-17-2010, 09:44 AM | #1433 |
Hey Bob, wish I could have stayed longer, I came back when I was done working, but you guys were all done. I talked to Dave and he seemed impressed with the numbers, so am I! Thanks for telling me you were going over there, it was cool!
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
02-17-2010, 10:41 AM | #1434 |
Congratulations on the great #'s. Once this crappy weather begins clearing up and I can finish the garage, I will be jumping on my install in "Bob".
02-17-2010, 01:28 PM | #1435 | |
Still plays with trucks
I ran one in my 95 Formula that made 340 hp to the wheels and beat the snot out of it on the track for over a year with no problems from the converter and mine was a used one out of a 130,000 mile S-10 Blazer that I got with the transmission at a pull-it-yourself wrecking yard for $50. This converter should work great with the LS1 hot cam. Don't give up on the 5.3 heads yet. Try the hot cam with the LS6 yellow springs and the Vortec V-6 stall converter first. You might be surprised at how much power they can build. If they are not enough for you then upgrade the heads with no money lost.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-17-2010, 05:16 PM | #1436 |
Congrats on the dyno run numbers. Fred sounds mean!
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
02-17-2010, 06:25 PM | #1437 |
Future: 86 on GenIV power!
Congrats on the numbers....
02-17-2010, 09:48 PM | #1438 |
good number bob...
also want to say thanks to you and all the guys here that help with the many question I had,, as of today my truck is alive again.. it started on the first try....have a small leak on the return line and a small leak right at the transmission where the cooler lines come out... |
02-17-2010, 10:02 PM | #1439 | ||||
I was looking through some notes today and saw that I also had the Vinci Performance Ultra Torque and their 043 towing cam in my book as possibilities. They both have a little choppier idle than stock, but not too bad. And all 3 will work with a stock converter. Quote:
02-17-2010, 10:31 PM | #1440 |
thanks bob... I did check all fitting and wire connections they are all good.. the only reason the fuel is leaking is because the return line from the vette filter is a 5/16 hose and the return to my stock 84 tank is smaller than that... I tried double clamp it but didnt work... it looks like the 5/16 hose fits better in the one line that came from the canister for the evap stuff...? do you think I could just clamp it to that line instead?
and the trans lines I leaking at the clamp.. so I am just gonna order the right fittings.... bob how did you guys make the alternator charge... I guess I eliminated the plug that went to it and yes I got you on the a few things here and there... Last edited by fpjr0; 02-17-2010 at 10:33 PM. Reason: m was missing on all the clamp words lol |
02-17-2010, 10:39 PM | #1441 |
On the alternator, if you eliminated the plug that went to it, that's probably the problem. I think it is the PCM that tells the alt when to charge, and when to shut off, kind of like the exciter (field) on the older alternators.
For the fuel, refresh my memory. Are you running an in-tank pump, or external?
02-17-2010, 11:42 PM | #1442 |
Still Learning
Looks to me like you have plenty of ponies to the tires and tons of torque to play with! SWEET!
02-18-2010, 12:10 AM | #1443 |
running an external pump and as mention b4 the line the came from the evap canister will fit more better and tighter than the actual return line,, so I was thinking on clampin the return to it and the original return line just pluged it....and I dont recall eliminating the plugs from the pcm to alternartor but I thinks it was already cut from when I bought engine.. I found some info on how to make it work with out the pcm thought.... thanks.. let me know your opinion on the fuel line dilema....
02-18-2010, 12:22 AM | #1444 |
That might just work. Is that evap line mostly steel with short rubber ends? If so, and if you end up cutting the steel to get it the right length, be sure to flare the end of it a little to prevent the hose from being pushed off the end by the psi.
That's good news on the alternator, hopefully you can get it to work!
02-18-2010, 12:49 AM | #1445 |
yes the evap line is steel and it has a T next to where I put my fuel pump... with short rubber hose as you said,... I am just gonna clamp it there,its flared.., will let you know how it turns out ....
02-18-2010, 12:02 PM | #1446 | |
The L terminal on the CS-130 alternator is connected through an idiot light on the dash. It needs that resistance to function. You can connect it to the alt warning lamp wire that was on the old 12si alternator in your truck or run a CS-130 pigtail harness from GM that they have with a resistor in the L terminal connection. You can also get a courtesy light circuit out of a donor car and connect it through that too. I did it this way on an old Jaguar that I put an LT1 / 4L60 into to get the alternator to work since it didn't have an alternator warning lamp circuit to use. I left it under hood as a diagnostic tool to know the alternator was working.
02-18-2010, 05:37 PM | #1447 |
Are the 5.3 intake manifolds and the 6.0 manifolds the same? If so I've seen the guys over at tbssowners porting their intakes and getting 15-20rwhp. They were having it done by LSportworks. Here is a link.
http://www.tbssowners.com/forums/showthread.php?t=39770
02-18-2010, 11:30 PM | #1448 |
68 tt,, thanks for the info... I been reading the schematics for the 80-87 trucks and I saw what you mentioned above,, the wire coming from the truck has the resistance built in .. so I am going to hook it to that and see if it works... thanks
bob sorry to keep hickjacking the thread... but not sorry about the total # of post in it.. |
02-19-2010, 11:27 AM | #1449 |
No problem man! More info for the masses!
02-19-2010, 06:45 PM | #1450 |
Ok its been three weeks and your not done with the trailing arm conversion yet??
WTF? You did the LS swap in a day???
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
