11-19-2007, 06:21 PM | #126 |
Re: 4x4 with air bags?
Up DATE TIME!!!
Ok guys, FINALLY got to drive the beast . and man she runs GOOD! Only running 5psi right now, and a VERY conservative tune till I have time to dial it in. I need to do some more work on the front steering though, has some really bad bump steer, so I think I'm gona have to put cross over steering on it. It's riding pretty rough too, but I think the box will help that, if not, I'm gona put some 1500# sleeve type bags in the back, and they should ride better. I got my seats put in too. Oh, and these's a video in here for all you video freaks too,
01 ECSB 4.8 4x4 :Mods: One of them turbo muffler things (someone on the internet told me it dosn't work, so it must be true ) An extra radiator for the air (don't know what that does ) A bumpy stick thingy from a Corvette And on top of that my truck has a drug problem, it addicted to meth! Anyone know a good rehab center Project 72 Chevy 4x4 longbed, 5.3/4L60 swap with a Master Power T-70 turbo and air bags in the works Last edited by kbracing96; 11-19-2007 at 10:47 PM. |
11-19-2007, 06:50 PM | #127 |
That is just too cool! How much is involved in the turbo set up? I am thinking about this for my 70 2WD Blazer. It would be on an LS motor.
Kevin LFD inc. Last edited by Rokcrln; 11-19-2007 at 06:50 PM. |
11-19-2007, 10:44 PM | #128 |
Turbos are pretty simple, once you understand them. I've been messing with them on my other truck for about 3 years now. Started out with a STS remote mount on it and just kept play with them. It got the same thing as this does pretty much now, only I run 10psi on the 4.8. This thing spools super fast, lol. Serious traction issues
01 ECSB 4.8 4x4 :Mods: One of them turbo muffler things (someone on the internet told me it dosn't work, so it must be true ) An extra radiator for the air (don't know what that does ) A bumpy stick thingy from a Corvette And on top of that my truck has a drug problem, it addicted to meth! Anyone know a good rehab center Project 72 Chevy 4x4 longbed, 5.3/4L60 swap with a Master Power T-70 turbo and air bags in the works |
11-20-2007, 02:16 AM | #129 |
I fully under stand them I just have never built a system (yet). I am thinking about a twin set up with two smaller turbo's for a balanced look and it will be very low. I feel it would be easier with two seperate systems then trying to cross over to one and then I would need one larger exhaust pipe instead ot just two reasonable sized ones. It will be a show vehical for the first year then a tire eater after that. I am planning on a 2001-2005 vett LS1 for the power plant. Any thoughts?
Thanks, Kevin LFD inc. |
11-20-2007, 02:51 PM | #130 | |
Twins are always impressive to look at, but don't kid your self if you think they will be easier. There is MUCH more pluming involved
01 ECSB 4.8 4x4 :Mods: One of them turbo muffler things (someone on the internet told me it dosn't work, so it must be true ) An extra radiator for the air (don't know what that does ) A bumpy stick thingy from a Corvette And on top of that my truck has a drug problem, it addicted to meth! Anyone know a good rehab center Project 72 Chevy 4x4 longbed, 5.3/4L60 swap with a Master Power T-70 turbo and air bags in the works Last edited by kbracing96; 11-20-2007 at 02:53 PM. |
11-20-2007, 11:15 PM | #131 |
What all did you or will you need to do for computer tuning? I am not aposed to a iron 6L but like I said this will be a show vehical to start with so I want it to look clean and balanced but I should be able to do that with a single and some sheet metal work. What is a ball park amount for parts that you have in your set up if you don't mind me asking? Thanks for the insite!
Kevin LFD Inc. |
11-20-2007, 11:35 PM | #132 | |
$$$ in this truck, I don't want to think about it, lol. Are you talking about just the turbo setup or the hole truck? The cost of the turbo setup can very greatly depending on what parts you use. If you go brand name or knock off. Most of the parts I used I built or are quality knock offs that I inspected thoroughly before I installed them. If you want to discuss this or turbo's in general, feel free to keep asking questions here, or hit me up on AIM or MSN at this same SN.
11-20-2007, 11:59 PM | #133 |
Yes I was just talking about the turbo set up and just the parts that you did not make. I can build alot of it my self so it will just be the main items I was wondering about a ball park $ on. Thanks for your time.
Kevin LFD inc. |
11-21-2007, 12:04 AM | #134 |
Just the turbo stuff, I'd guess about $1500 in parts, but i got some deals on some stuff.
11-21-2007, 06:49 AM | #135 |
I know I ve ssaid this before but that truck is way awsome. I may need to pic you brain on the turbo stuff I paid to have my lat one built now im settin up my own my twins had wastbgated turbos the turbo I hae now for my truck isnt so I want to add one to it but im using part of an old ats kit to make it easier on me and the ats turbo manafold uses a t4 flange not a t3 so im having trouble finding stuff for it.
Earl 68 2500 4x4 GMC Burb |
11-23-2007, 04:14 PM | #136 |
PROJECT 7DEUCE
Sweeet ride love the burnout video too.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-08-2007, 10:19 PM | #137 |
I got the cross over steering done, but still not real happy with it, Pretty slow steering and doesn't "feel" tight, but most of the bump steer is gone. The truck drive nice, and tracks very well, just don't like the "feel". But that's a problem to fix another day. I'm calling this done for now. Dad can drive it and be happy for a while. He said he's going to try and do the body work so, we'll see, . The truck runs VERY strong for only 5 psi, he should be happy. I'll get some pics with the box back on and of how the interior turned out.
12-08-2007, 11:33 PM | #138 | |
Seat is looking a little painful. JK Nice work.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
12-09-2007, 06:43 AM | #139 |
That trucks a sleeper.Looks great.
12-09-2007, 03:20 PM | #140 |
Haha, funny guy Keeps you from sliding around
Thanks!! Here some more pics All the way down All the way up! And normal ride height with 50psi in the front and 30psi in the back Oh, and YES it is snowing here, lol.
12-10-2007, 12:03 PM | #141 |
Man you have build your Dad the ultimate sleeper. I can't wait to start playing with a turbo'd set up in one of my two curent builds. Hey is the 5.3 a "6bolt" main or is that just the 6.0? I am thinking about going with the 5.3 for better gas milage. My last 6.0 was great but it only got 14 no matter what you were doing with it.
Kevin LFD Inc. |
12-10-2007, 12:08 PM | #142 | |
All the Gen III motors (4.8,5.3,5.7,6.0,) are 6 bolt mains and all the parts pretty much are interchangeable, just like the old small blocks
04-03-2008, 09:07 PM | #143 |
Way cool. Nice work!
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
04-03-2008, 09:14 PM | #144 |
Well, my dad FINALLY got back to WY about 2 weeks ago from galavanting around the country in the Dmax and 5th wheel doing the retired thing with mom and drove her for the first time. He was a little reserve with it at first, cuz I wasn't there to talk to him about all the stuff I had done and what was what, so he was just piddling around in it. He absolutely LOVES IT!!!
He said after he drove it for a week, he decided to get on it for the first time so he nailed it from a stop and about half way though the intersection, it hit full boost and he said it broke both rear tires loose and got a little sideways on him . Surprised him at first, but for only 5 psi of boost, he's in love, May be this summer we will bump it up a little, but he is VERY happy with his baby, and a little proud of his son
04-04-2008, 03:46 AM | #145 | |
This is still may favorite build! Excellent work!
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-31-2010, 05:15 PM | #146 |
In the Forgotten far North.
Finally found this thread again. Any updates on the truck and the steering issues?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
01-31-2010, 07:08 PM | #147 |
Enjoying left field
I just found this thread too. This is basically what I want to do to my truck. Can you elaborate on the ride a little? Did putting the bed back on make a difference?
01-31-2010, 11:38 PM | #148 |
THE TOY STORE
is 30 and 50 psi not a little bouncy?
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know. |
10-02-2010, 11:54 PM | #149 |
good read !!! thanks for the details !!! now the gears in my head are turning !!!
08-08-2011, 01:50 AM | #150 |
What a great thread, wonder what happened to him? Sorry to see him go, his last post was 4/4/2008 Posted via Mobile Device |
