Old 03-03-2007, 12:22 PM   #126
ChevyDude
Re: My build up thread 67 small window short/fleet
Progress looks great!!! Frank is going to be awesome, coming along nicely!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 03-03-2007, 12:38 PM   #127
msgross
msgross's Avatar
what did you paint the frame with? nice truck...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-03-2007, 01:09 PM   #128
byrd
Union Electrician
byrd's Avatar
Thanks, I hope it turns out as nice as your shorty, but we'll see
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 03-03-2007, 01:11 PM   #129
byrd
Union Electrician
byrd's Avatar
I used Eastwoods 3 step chassic paint kit. Two part converter, rust encapsulator(wasn't any left on the frame anyway but I had it so I used it) and then about 2-3 coats of high gloss epoxy chassis black.
Zip:40272
Old 03-03-2007, 01:57 PM   #130
454_72_4X4
454_72_4X4's Avatar
Originally Posted by byrd View Post
Thanks Tracey, I hope it will turn out that nice when are we going to see some action out of the 4x4 your building?
It'll be that nice.
I guess I'm at a stand still on mine for awhile. Had a few seconds of bad luck a couple weeks ago that's put everything here on hold for awhile.
I won't jack your thread with the details though.
Maybe I'll start a thread with the story sometime.
I gotta get my wife's 80 done before I can start on mine. LOL
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-03-2007, 01:59 PM   #131
ChevyDude
Oh it will...just take your time and do it all "right" and it will be VERY nice. I am hoping to get my Lil Red driveable this Spring/Summer. I'm not going to say finished because I have too many plans for her...Vintage Air...Posi...and a few other things. I have my eye out for a 67 small window shorty that will be a frame off! Already have a brand new Tri-Plus short wood complete bed for the "to be found" 67'.
Alex
Old 03-03-2007, 03:25 PM   #132
watahyahknow
watahyahknow's Avatar
cars are not desighned to bump intoo stuff ..... its goiing to be expensive to fix it .
doubt if its going to get straight enough to handle properly again
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-03-2007, 04:18 PM   #133
454_72_4X4
454_72_4X4's Avatar
Ain't that the truth. LOL
Worst part was I was on the recieving end....
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 03-08-2007, 11:15 PM   #134
byrd
Union Electrician
byrd's Avatar
Got a little more done on Frank, started to get the DS inner and outer rockers on. I couldn't just use the inner rocker patch as the little bit of rust was just outside the reach of that panel So I had most every patch panel from a previous cab so we used part of the rear floor patch for half of the inner and a little piece of the floor. We then tried to use the inner rocker part of the front floor patch and found it was WAY different and too short on one side to make it look right. So not having a break I grabbed some patch metal Rick brought over and headed to a local HVAC supply house. I took the piece needed to show the guy, he says no problem take me about 10 minutes @ $1/minute. He starts to cut and shape it for me and asks me what it is for and I tell him for my 67 shorty, and he tells me about one he had and a story or two while he worked. Took him about 20 minutes as he machine was making square cuts and the inner bends are more rounded. So anyway he gets it close enough to bang on little at the shop and tells me don't worry about the $$, just bring the truck by when your done I was like sure will and may be back for for more panels if the rest are this chitty
The first pic shows an old piece of DS firewall I had and used to make the needed shape on the PS for where I shaved the blower motor. Well my first attempt turned out OK (second pic) but it was too weak. So I had another idea, I needed to have the same piece between the outer lip and the firewall to make the panel sturdy enough. So I cut the rest of that old firewall and then sliced one side and shaped it to what I needed and then welded it up and cleaned it up a little.I left most of my old piece in there just shaved the top edge about 3/8" to give me a nice and easy spot to weld to. You can see in the pic with the piece in the vise that I still havce the back side so I can weld it to the firewall of the cab for strength. The best part is that the piece I made the second time has a better, more defined lip so that it better matches the original It is not welded up yet but just in place to show what it will look like.
We welded up a couple small holes in the DS cab corner(that is Rick welding BTW) and got the door hung and mocked up the outer rocker. The door fits really well, except a little tight at the top of the winshield pillar. will have to grind and shape the door a little there.Got the rocker back off and drilled out to spot weld it back in place and put back on for a final check of gaps ect and all looked great. Ran out of time for the week bu will get more in next week as the weather gets better. Here are some pics of the progress with several more to follow.
Zip:40272
Old 03-08-2007, 11:19 PM   #135
byrd
Union Electrician
byrd's Avatar
more pics, I also spent about an hour with my razor knife cutting all the crap out of the rear cab seam to get it ready to weld up. That was fun
Zip:40272
Old 03-08-2007, 11:24 PM   #136
byrd
Union Electrician
byrd's Avatar
Last pic for now, it has the mocked up second try at matching the firewall on both sides, you can just barely see the line from the old try to to the new pieceslid down in behind.I forgot to get a side pic of but will to show the it looks almost like it was there from the start. I think it will turn out nice and be very rigid.
Zip:40272
Old 03-09-2007, 12:58 AM   #137
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I just read the whole thread awsome story awsome build. GR8 work and I'm not gonna sleep over the whole wheel issue Can't wait ta see "Frank" finished. Gotta love this place.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-09-2007, 11:08 AM   #138
byrd
Union Electrician
byrd's Avatar
Thanks for the props Nobody has figured out the wheels yet either, maybe I should have a contest to see if anyone can find out who and what they are
Zip:40272
Old 03-24-2007, 09:53 AM   #139
NGN
NGN's Avatar
Man I think this was the longest thread I ever read !!!!!! It sure pumps my blood . ( Thanks I needed that . lol ) I also have that same truck , Well it's still the same as when you frist inherited the Frank truck. Keep up the good work , Can't wait to see it done .
NGN is online now   Reply With Quote
Old 03-24-2007, 10:03 AM   #140
byrd
Union Electrician
byrd's Avatar
Thanks Not near as long as it will be by the time I am done with Frank
We have made a little progrees(no pics yet) We got the DS inner rocker welded in and cleaned up ready for the outer, and I went back to HVAC metal shop and had Chris(2J supply for local guys) make me up another inner rocker for the PS with about 2.5" of floor on it to pick up some metal that I needed without another seam I also started shaving the rear cab seam and have it almost complete.I will post progress pics at the end of next week, hopefully both inners and outers will be complete
Zip:40272
Old 03-30-2007, 10:47 PM   #141
byrd
Union Electrician
byrd's Avatar
No progress to report,but I did pick up some for Frank over the past week or so. I got a chrome booster & M/C combo with chrome prop valve and chrome mounting brackets, and pedal rod. Man does that thing shine Won it on ebay
I also picked up a polished aluminum radiator also off ebay that is sweet!! as well I picked them both brand new!! GOT A SMOKIN' DEAL IMO Check out the quality of chrome you can see my reflection the booster bracket
Zip:40272
Old 03-31-2007, 07:30 AM   #142
Bling Bling!!!
Nice stuff there Byrd.
Old 03-31-2007, 08:49 AM   #143
ChevyDude
Make sure you PRE fit everything prior to paint!!! My painter DID NOT do this ,,,,it is a vital step that he skipped and was fired.
What color is Frank gonna wear???
Alex
Old 03-31-2007, 10:53 AM   #144
DAJ 67
DAJ 67's Avatar
Getting me pumped about getting the young son one. I know where there is a 70 SWB that I may get and start on now. Keep up the encouragement and we will do the same. Can't wait to see more pix of Frank. Keep us posted.
DAJ 67 is offline   Reply With Quote
Old 03-31-2007, 06:24 PM   #145
byrd
Union Electrician
byrd's Avatar
Talking Re: My build up thread 67 small window short/fleet
Everything is/will be pre fit, thanks for the reminder. Rick the bodyguy is making those calls I just pimp the tools for him and do some welding and grinding and a little shaping here and there. He is very knowledgeable and is doing it right the first time, it takes a little longer on the front end,but pays off at the rear
Frank will be wearing Onyx black(or similiar black) base clear
Zip:40272
Old 04-11-2007, 05:57 PM   #146
byrd
Union Electrician
byrd's Avatar
A little progress to report. We have gotten the PS inner rocker tacked in and the small floor patch tacked in place as well. Notice my custom made inner rocker, the inner rocker patch panel didn't have enough metal on it to repair the section of floor I needed at the same time. A local hvac shop mocked it up and Rick massaged it to fit perfectly,even forming the little spot in the patch to match the floor I also have made my last pass with the welder(4th and final ) and just need to grind a few small spots down and the shaving of the rear cab seam will be done Also made the final adjustments to the panel I am using to shave the heater blower motor spot and to match the DS of the firewall. Rick took it to work today to blast it clean and I will start welding it in tonight! The plan is to get the PS inner rocker, and floor patch welded in tonight and try to get the rocker on and mocked up to mark holes for spot welds, and maybe hang the door, but that is pushing it.Here are a few pics of the progress and hopefully more in a day or two...
Zip:40272
Old 04-11-2007, 06:10 PM   #147
1969k10stepside
Truck is looking good,keep it up and it will be done!Hey,your in Louisville,not to far from me
1969k10stepside is offline   Reply With Quote
Old 04-11-2007, 11:42 PM   #148
byrd
Union Electrician
byrd's Avatar
Not too far, are you in evansville?
A little more progress tonight, got the PS inner rocker and floor welded,but still need to clean them up. Also got the blower motor area shaved out with the piece I made out of the scraps from an old cab. It s about 3/8" too short on the outside edge when compared to the DS, but still looks clean none the less, and shouldn't be noticable once the fenders and hindges are in place. I also go the gaps set and straight on the DS door along the window post, the rest of the door is where it needs to be. It was a little too tight for about the last 6" of the top of the door, as well as the first inch or two from the bottom of the window frame.Will need to be welded up the upper portion as it needed to be ground more than the thickness of the skin, very minor. A few more pics....
Zip:40272
Old 04-11-2007, 11:45 PM   #149
1969k10stepside
No,I'm about an hour north of Evansville,still fairly close though considering there isnt many members here locally.....and since you do such a good job doing body work,you can come over and do some work on the cab for my 71
Old 04-13-2007, 11:05 PM   #150
byrd
Union Electrician
byrd's Avatar
Body work, me?? Rick IS the real bodyman, I am just his helper . I have done some of it,(mostly welding) and not to say I'm terrible at it, Rick is just SOOOOO much better//faster with his almost 30 years experience. He has been a blessing, making the build much more enjoyable, and great experience for me as well
Zip:40272
