01-28-2011, 11:38 PM | #126 |
Re: The Fuse is Lit...
allred!!!
01-28-2011, 11:46 PM | #127 |
Still Learning
Nice work on the cab. You can do what you want with your paint. For me I'm going with solid red, so I am kinda partial.
01-29-2011, 11:19 AM | #128 |
GEARHEAD
If you go with the white top, also paint the windshield posts and door window frames to match. I would do the grill also if you went that route, but not the bottom of the body.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-29-2011, 11:24 AM | #129 |
67cheby
Are you going to be using all of the factory trim , if you are running all of the factory trim i like a white top, if you are shaving all of the trim all red , just my 2 cents
01-30-2011, 04:47 PM | #130 |
Thanks for the opinions. I am still trying to decide for sure.
Thought you might want to see the undercoating I put on the other day. Wow, I think I need to use some Windex on that camera lens.
Rex |
01-30-2011, 04:50 PM | #131 |
wow looksa clean!!!
01-30-2011, 05:19 PM | #132 |
VA72C10
nice work...and the lens may not be dirty...if you had just finished spraying it might have picked up the particles in the air...happened to me all the time when documenting my last build...
Looking for a 67-72 swb or blazer project in or around VA. |
01-31-2011, 10:11 AM | #133 |
67cheby
looking good
02-04-2011, 12:22 AM | #134 |
Primer and sand...and sand...and sand.
Rex |
02-04-2011, 12:30 AM | #135 |
Still Learning
Diggin the roticerie. I bet that makes it a lot easier hitting the roof. Hey, you got any fingerprints left? Gotta love sanding.
02-04-2011, 12:32 AM | #136 |
VA72C10
Looking good! And I feel your pain with the sanding!!!
02-04-2011, 12:38 AM | #137 |
my favorite part of sanding was the door jambs and the roof on the inside! that was fun your lucky you have a big window! less metal.....
02-04-2011, 12:43 AM | #138 |
The rotiserre is the best! First time I have used one and would hate to go back to just sawhorses!
I was just thinkin' in the first post that now would be a good time to rob a bank because I would be hard to fingerprint...lol.
Rex |
02-04-2011, 03:21 AM | #139 |
6>8 Plugless........
Nice work! It is coming along nicely!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-04-2011, 10:22 AM | #140 |
67cheby
quit typing.....back to sanding, only a few months left until Summer !!!
02-16-2011, 09:31 PM | #141 |
Has more rust than truck...
Rocketking, Have you test fitted the cab with the engine/trans in place? I tried putting my 4.8/4l80e all the way back like yours and the trans hit the pinch weld on the cab when I tried installing the trans mount. I ended up modifying my adapter plates to both be like your passenger side(1.75" forward). Body work is lookin great by the way!
02-16-2011, 10:43 PM | #142 |
Still Learning
What is the main reason for moving the engine towards the back? Just to close the gap at the firewall or to gain clearence for the cooling fan(s)? thanks
02-17-2011, 10:10 AM | #143 |
Room up front and wieght transfer were my reasons for trying, oh and it was easier to put it all of the way back because of the adapter plates i have.
02-17-2011, 12:02 PM | #144 | |
Thanks for the compliment on the body, I hope the major work on the cab is done! My main reason was for more clearence up front.
Rex Last edited by RocketKing; 02-17-2011 at 12:05 PM. |
02-17-2011, 12:10 PM | #145 |
67cheby
Have the cab painted next week.......wow !!! Smoking me
02-17-2011, 02:50 PM | #146 | |
02-17-2011, 07:08 PM | #147 |
02-17-2011, 11:11 PM | #148 |
Thanks, but don't feel to bad because it is just the cab. lol
Okay, now I am reeeally sweating it.
Rex |
02-18-2011, 02:16 AM | #149 |
Home Built '87
Great looking build...love the swap!!
How did you prep the intake for paint? Did you remove lots off of it before spraying it or just taped off bits?
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
02-18-2011, 03:42 AM | #150 |
just did a quick read over looks good so far man good luck
