Old 11-25-2013, 02:00 PM   #126
Low Elco
Re: 59 Apache Stepside Rookie Build
Wow, great fab work!
Low Elco is offline   Reply With Quote
Old 01-13-2014, 02:00 AM   #127
hotrodrookie
hotrodrookie's Avatar
Currently working on getting the 5.3 straightened out. It seems as if it may need a trip to the machine shop. Hopefully the damages are too bad. Driveshaft and shortening will be next.
hotrodrookie is offline   Reply With Quote
Old 01-13-2014, 11:18 PM   #128
Larry Lindley
The rust is from my drooling over the pictures.
Larry Lindley is offline   Reply With Quote
Old 01-26-2014, 04:55 PM   #129
hotrodrookie
Got a little bit more painting done on the drivetrain pieces. My driveshaft also came in, it's from Crown Vic police car. The shaft currently measures 55.5" from joint to joint. Once the engine and trans are assembled and in, I'll send it out to have it shortened/balanced.
One big relief I was able to take care of was the rust in the water jacket issue. Rather than tear down the bottom end, I filled the jackets with Evaporust and let it do its magic for a week. Most all of the rust build up disappeared. After that, I steam cleaned the block, dried it, and gave it a heavy dose of Marvel's mystery oil. It's now waiting patiently in a bag before it gets reassembled.
Old 01-26-2014, 08:15 PM   #130
4Eyedtruck
this build is looking great definitely not rookie in my eyes keep up the good work also what is the color of the paint you used on the valve covers and engine parts if you don't mind sharing id love to know
4Eyedtruck is offline   Reply With Quote
Old 01-27-2014, 10:13 AM   #131
Kim57
Kim57's Avatar
Looking real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-27-2014, 04:43 PM   #132
hotrodrookie
I'm not sure, it's the auto parts store metallic grey wheel coating rattlecan special.
Old 01-27-2014, 08:26 PM   #133
4Eyedtruck
LOL I like it ill be sure to ask for the auto parts store metallic grey wheel coating rattlecan special next time I am at the parts store keep up the good work man I think 59s are taking over in here lately
Old 03-03-2014, 01:12 AM   #134
hotrodrookie
Been getting the motor back together. New additions include Comp Cam, Texas Speed & Performace stage 2.5 ported cylinder heads, high pressure oil pump, ls7 lifters, ls2 timing chain, gaskets etc... It looks like the driveshaft will have to have a couple inches pulled out of it. Tailpipes and mufflers will be in the works soon.
Old 03-03-2014, 11:07 AM   #135
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
Old 03-03-2014, 06:36 PM   #136
Spblack
Spblack's Avatar
im rolling the same motor and rear end. what year was that drive shaft? where did you get the front yoke?
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 03-04-2014, 02:08 AM   #137
hotrodrookie
The driveshaft is fairly common, I believe 99+ are nearly the same for the Police Crown Vics. I think mine was from an 06? The yoke was from a 90's 1/2 ton truck with a 700r4 (same spline count). I still need to get the correct U-joint to mate the two after the shaft is shortened.
Old 03-14-2014, 01:24 AM   #138
hotrodrookie
Exhaust parts are coming in. Here's a drawing of what I'm thinking of doing. Simple x-pipe, flow through mufflers, turn down right after the muffler, all 304 stainless, and the cutouts will be just for fun
Old 03-14-2014, 09:52 AM   #139
Kim57
Kim57's Avatar
That looks real clean.
Kim
My build thread
Old 03-14-2014, 11:53 AM   #140
99 to Life
99 to Life's Avatar
gonna be sick, I like the cutouts for sure
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-14-2014, 06:28 PM   #141
Rednek13x
Rednek13x's Avatar
you are talented, great work so far!
Rednek13x is offline   Reply With Quote
Old 03-31-2014, 12:57 AM   #142
hotrodrookie
Got my driveshaft back from the shop. Shortened to the 52.75" center to center on the u-joints, balanced, and new u-joints installed. I can't wait to get it spinning. I'm guessing that next up will be mocking up the exhaust and finishing the engine intake/accessory assembly.
-1959 Apache Stepside/5.3/4l60e LS/Explorer 8.8/Camaro front clip/Parallel 4 link/watts link
-59 Apache Stepside Rookie Build http://67-72chevytrucks.com/vboard/s...d.php?t=403875
Old 03-31-2014, 10:34 AM   #143
Kim57
Kim57's Avatar
Very nice looking.
Kim
My build thread
Old 05-18-2014, 04:59 PM   #144
hotrodrookie
Started to tear into the wiring harness. lt1swap.com is definitely a great help. wish me luck...
Old 05-19-2014, 09:56 AM   #145
Kim57
Kim57's Avatar
Good luck.
You're a lot braver than I was.
Kim
My build thread
Old 06-06-2014, 02:18 PM   #146
BC Toy chest
BC Toy chest's Avatar
Can't wait to see it when you're done nice work. Keep the pics coming.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 06-07-2014, 04:32 AM   #147
hotrodrookie
I tried to squeeze in a little time to get some work done on my exhaust. The hardest part was getting the x-pipe clocked correctly and locating the flanges on the header collectors. I'm really trying to button up all the little engine accessory/wiring/stuff etc. so I can this thing some time this decade
In other news, I just got a new job. Good news is that it's awesome, bad news is that I'm moving 120 miles away from my truck. Lucky for me, I can atleast keep my truck and work on it over the weekends.
Old 06-07-2014, 10:44 AM   #148
Kim57
Kim57's Avatar
Congrats on the job.
Nice job on the exhaust.
Kim
My build thread
Old 10-22-2014, 07:54 PM   #149
hotrodrookie
I was able to squeeze in some time to weld in my dash panel. Pretty happy with how it turned out.
Old 10-23-2014, 12:52 AM   #150
Kim57
Kim57's Avatar
Nice job.
Kim
My build thread
