09-21-2011, 09:58 PM | #126 |
Re: 57 Step Side
Truck looks great! I was wondering if you had more info on the brake bracket and pedal, I looked at CCP.
Couldn't find it.. thanks.. good luck on turning that key! Posted via Mobile Device |
09-22-2011, 10:19 PM | #127 | |
Re: 57 Step Side
Very nice unit and easy install. |
09-24-2011, 10:44 PM | #128 |
Re: 57 Step Side
Finally got last wire in cab hooked up so the inside wiring is complete,only have head lights and tail lights left.I should of take a before photo of the wiring or should i say the bird nest with the taped splices,the wire felt like old coat hangers.
09-24-2011, 11:23 PM | #129 |
Certified Car Nut
Re: 57 Step Side
Somebody's been spending, and also has been busy. Everything looks great man.
09-24-2011, 11:53 PM | #130 |
Re: 57 Step Side
Nice and clean...
09-25-2011, 09:11 AM | #131 | |
Re: 57 Step Side
Its coming up on one year since i started removing parts from this truck and i'm planning to start the truck this week.I didn't think it was going to take as long as it did but its been fun to say the least. |
09-25-2011, 11:02 AM | #132 |
A320 Pilot/USAF Retired
Re: 57 Step Side
Your hard work has definetly paid off big time. She looks sweet!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
09-27-2011, 09:28 PM | #133 |
Re: 57 Step Side
Hooked up battery charger tonite to test the wiring,well i can report that their was no fire but then again 2 amps wouldn't start a blaze.Dash lights and dome lite work,turned the key and heard the started click.I guess the next step is drop the battery in and add some fuel in the carb and see what happens.
09-28-2011, 07:37 AM | #134 |
Re: 57 Step Side
Sweet! I did the same thing using the low setting on my battery charger to test my wiring. You've got to be very excited at ths point to hear it run!!
09-28-2011, 02:15 PM | #135 |
Re: 57 Step Side
What stereo is that you have in there? looks interesting.
Learn to deal with reality, or reality will deal with you. |
09-28-2011, 02:37 PM | #136 |
Re: 57 Step Side
Retro Sound,the radio is actual quite small and the knobs are adjustable to fit your application.
http://www.retrosoundusa.com/products/category/id/10 The name is deceiving because when you open the box everything is from china,imagine that....... |
09-28-2011, 02:50 PM | #137 |
Certified Car Nut
Re: 57 Step Side
When I grow up, I going to be just like you. I going to have a really nice classic pickup truck.
09-28-2011, 07:37 PM | #138 |
Re: 57 Step Side
You should have yours done by then i would say,and i still don't have a truck i sort of did this one for my son so we would have something for the local friday nite car shows.Besides i still don't have a 55 or 57 car to cruise around in like some of the people here!! Always wanted a 55 since going to the cars shows theses last few years but the 57 with the side trim has me leaning more towards that model lately.
09-28-2011, 08:50 PM | #139 |
Certified Car Nut
Re: 57 Step Side
09-28-2011, 08:53 PM | #140 |
Re: 57 Step Side
What he said!!
09-28-2011, 09:32 PM | #141 |
Re: 57 Step Side
09-28-2011, 09:55 PM | #142 |
Re: 57 Step Side
I do, the 150 trim is sweeeeet! but mainly because it so closley resembles the '55 belair.
09-28-2011, 10:48 PM | #143 | ||
Certified Car Nut
Re: 57 Step Side
On the real I love tri5's but the 55 is my favorite with the 56 a close second. When I was looking for a tri5, I had to have a 55 or 56. I really wanted a hardtop especially if it was a 56, but I'm happy I found the 55 sedan I would not change it for nothing now (well except for a 55 or 56 Nomad).lol I'm not really a 57 fan but I've seen some very nice ones and if you happen to find a 57 I guess I will still have to except you as my tri5 brother, but there will always be sibling rivalry.lol |
09-29-2011, 09:29 AM | #144 | |
Re: 57 Step Side
Would you ride in my 55 with the 57 trim package? LOL |
09-29-2011, 09:40 AM | #145 |
Certified Car Nut
Re: 57 Step Side
I sure would and when people point I'd just shrug my shoulders.
10-01-2011, 11:31 AM | #146 |
Re: 57 Step Side
Well its alive finally,after resetting the timing and reversing the fuel pump as to pump gas into the carb instead of sucking it out!!! Video sound is off my phone so it doesn't give it justice,but it person it sounds real strong and not to loud.
10-01-2011, 11:48 AM | #147 |
Certified Car Nut
Re: 57 Step Side
Thats great another milestone. You must be happy, I would be.
10-01-2011, 12:11 PM | #148 |
Re: 57 Step Side
Very happy it started and runs,first time for doing a complete build and the only thing i was worried about was the wiring.I missed one ground wire on the dash board and dome light it seams but everything thing else works fine.Fan comes on and turns off as it should,the cab has heat now that works.
10-14-2011, 08:04 PM | #149 |
Re: 57 Step Side
Bed is on and bolted down and gas cap on,gas cap would of been easier to install before the bed was bolted down.
10-14-2011, 11:18 PM | #150 |
Re: 57 Step Side
The bed came out real nice.
Kim |
