Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 01-23-2013, 12:03 AM   #126
padresag
Re: SiX-fo SuBuRbAn
that looks good Jon
ron
padresag is offline   Reply With Quote
Old 01-23-2013, 08:21 PM   #127
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: SiX-fo SuBuRbAn
here is the pass side roof post, I was able to leave the inner post intact by drilling out the spots, so I won't have a seam to do body work on there; then I cut a section out of the front, so I can weld the inner post first, then fix the outer.
Old 01-23-2013, 08:33 PM   #128
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
to get the white roof posts trimmed in the right spot, I cut a portion off the top of the blue posts, and then layed them over the white, that gets me real close for the cuts, it helps to be able to cut both the doners on the long side.
my doner was a rollover, and I wasn't sure how bent the posts were,if at all, the pass side was perfect, but the driver post (from the big tree mark on the roof) was pulled in a little bit, about 3/4 inch.
Old 01-24-2013, 11:27 AM   #129
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: SiX-fo SuBuRbAn
Nice work Jon ....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-24-2013, 04:38 PM   #130
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
here is how I was able to fix the lh post... I remembered this from an old auto body book I read 25 years ago..
what I did was cut all the spots on the post , sepperate it into the 3 pieces , and then bend it back to where it was supposed to be.
I got the posts welded together on the inner support, and then checked the windshield for fit. I used chunks of an old gasket for windshield shims.
Old 01-24-2013, 04:46 PM   #131
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
hereis a shot of the rh post going together, there was a bit of a gap, so I used a trick an old body guy showed me, and "sleaved" it, I cut a piece of scrap inner post , welded it to the bottom , and then jacked the cowl into place so that all my measurements lined up.
I was also glad to see that the lower rear corner pillars lined up perfectly.
Old 01-26-2013, 08:42 AM   #132
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
Originally Posted by padresag View Post
that looks good Jon
ron
Originally Posted by ChiefRocka View Post
Nice work Jon ....
thanks, guys, got the lh post ready for mud, will have to get some more pics...
Old 01-26-2013, 09:17 AM   #133
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: SiX-fo SuBuRbAn
Looking good glad to see some progress can't wait to see what it will look like when you are done with it!
gostranger is offline   Reply With Quote
Old 01-27-2013, 08:46 AM   #134
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
ok, here is the lh post ready for filler!
Old 01-27-2013, 12:14 PM   #135
piratexpress1369a
piratexpress1369a's Avatar
Re: SiX-fo SuBuRbAn
dam that turned out great ..want come work on mine? lol
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 01-28-2013, 03:04 AM   #136
hemifalcon
Re: SiX-fo SuBuRbAn
That's some good work there merging the two trucks into one again.. Really good job..
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 01-28-2013, 09:32 AM   #137
duallyjams
duallyjams's Avatar
Re: SiX-fo SuBuRbAn
you got skills
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-13-2013, 06:55 PM   #138
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
thanks guys.
ok, here is the pass side post:
this one came out a little nicer than the lh one.
Old 02-13-2013, 07:01 PM   #139
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
I had to relieve the firewall a little bit for the bbc valvecovers the lh side I cut a piece out, then folded it in on itself, made a patch for the top, and tapped the bottom in until it was the same shape.
the rh side didn't really need much, so I cut around 3 sides , pushed it in a bit, and then welded it back up.
I used the old cowl setting on the frame to see where I needed the room for the engine.
before I put the body on I spray bombed the firewall.
Old 02-13-2013, 10:40 PM   #140
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
I also salvaged the rear brake line off the 1/2 ton shortbox, (think it is an 87) and the front part of the rear brake line off of the 88 sub, I will utilize all the front brake lines and prop.valve off the 88, and then the hydrovac system off the blazer that had the engine.
Old 02-14-2013, 02:01 AM   #141
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
Nice work Jon, you've been busy
Old 02-14-2013, 09:10 AM   #142
piratexpress1369a
Re: SiX-fo SuBuRbAn
nice work and i think i see a big block going in ?
63
Old 02-14-2013, 11:29 AM   #143
Bomp
Bomp's Avatar
Re: SiX-fo SuBuRbAn
Amazed at your skillz.
Bomp is offline   Reply With Quote
Old 02-15-2013, 12:23 AM   #144
SFTorange
SFTorange's Avatar
Re: SiX-fo SuBuRbAn
Nice work Jon. Very cool.
The Brown Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=437222
SFTorange is offline   Reply With Quote
Old 02-15-2013, 12:31 AM   #145
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: SiX-fo SuBuRbAn
You have been busy.!! Looks great.
Alan's Classic is offline   Reply With Quote
Old 02-27-2013, 07:26 PM   #146
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
more progress... buttoning up stuff to do before the body goes on.
got the exhaust welded up.
at first I started to use the brake lines off the 64 sub, but I realized that it would be much easier to use the lines off the 80's parts trucks, used the back half off the 87 shortbed, and the front off the 88 sub. now all the fittings match up, and I don't have to buy anything. I saved most of the attachment clamps off the 80's trucks and used exsisting holes to route the line.
...same thing happened with the fuel line..after fighting with the original sub line a little bit, I took a look at my options on the parts trucks.
the original line was 5/16, and the blazer with the bbc was using a 3/8.
the original line stopped short up front to meet with the 292 6 center mount fuel pump ( I also noticed that it was kinked almost 2/3's right at the pump.. that is probably why the guy couldn't keep it running when he sold it to us...) and routed right into the new 4x4 engine x member and mount.
the 60's sub uses a 2 piece fuel line, the front 1/2 is the same as a truck, and takes 90 degree turn right under where the back of the cab would be, all gm did for the sub was create a new line for the back half, and connect the 2 with a horseshoe piece of rubber line... ( you can see a pic of the original line on post #97-page 4)..this piece ended up routing right through an exhaust hanger that I put on, and the rubber ended up real close to the exhaust.
because of all that I took a look at the blazer line, and realized that it would be a better fit, it is 3/8, and routes outside the frame rail near the dual exhaust.
Another thing I did was put an in line fuel filter in the original break in the blazer line, this compensated a little for the w.base difference and was needed because of this:
It has been our experience with 73-87 gm trucks that the fuel sock that is mounted on the fuel sending unit pickup , after years of use breaks down, and gets a kink in it.
This has happened on 6 of our 73-87 rigs.
What will happen is that the sock will kink, and cut off the fuel flow to the line, the frustrating part is that it will only happen when you put a heavy load on it, let off the gas and it opens up, it will run, then you put pressure on it and it closes up and chokes off the supply, if you don't know about it you end up spending a lot of money on the fuel system until you figure it out (the first time).. we sure did!
(I grabbed a photo of one off the net, I will try and remember to grab some pics of a few of our kinked ones next time)
Old 02-27-2013, 07:44 PM   #147
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
Next I have to give a huge thanks to member PAPAKENT, who had stopped by to pull a receiver hitch, and stuck around to help with putting the body on.
this time I decided lifting the whole body with 2 camper jacks on the cement was too sketchy, and used a third body lift jack at the rear to triangulate the lift... much safer.
I also ran some bolts and chain through the front 4 body mounts to lift from, mainly because the new rockers are not on yet, and there was nowhere else to lift, but this also helped out a couple things, less chance of rocker/body damage from the jacks, and it also got the bases out wide enough that they didn't interfere with the tires.
( I snuck some photos of papak. into the last shots!)
Old 02-27-2013, 08:00 PM   #148
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
here it is!
I left a bunch of stuff on the roof, and now I'm going to need a step ladder to retrieve it!
you will notice that the rear wheels are off a little bit, I did this on purpose for 2 reasons, 1. I didn't want to have to pay to get a driveshaft shortened, and 2. since I am replacing the lower 1/4's and wheelwells due to rust I wanted to go with the longer fleet side wheelwells, because they are bigger, and I think will fit the 33's, or 35's better than the short sub wheelwells, also because that's all I have!
Interesting note.. I measured the centerline of the 1/4 to the ground,on this (51 inches) and the centerline to the ground on my stock 63 3/4 4x4, and this sub is exactly 4 inches taller, which is the amount of lift I added to the 73-87 suspension.. I thought the 63 sat higher than that, but I guess it dosen't.
Old 03-07-2013, 08:37 AM   #149
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
no pics, spent the day "finding" stuff that got scattered when I took this and about 5 other trucks apart!
I got the body bolted down, which was a royal PITA in the back ; because I mounted the gas tank in the frame rails, which didn't leave any room to get a hand in there to hold the mount up and put a nut on the bolt!!!...and a spring hanger bolt on each side had to be turned around so that he nut was out, so that they wouldn't hit the mount!..still in the same spot that I couldn't get my hand.
so, about 15 minutes on 8 mounts, about 2 hours on the other 2, and another couple hours wandering around looking for parts
Old 03-07-2013, 11:10 AM   #150
SFTorange
SFTorange's Avatar
Re: SiX-fo SuBuRbAn
Looks great Jon! Awesome work! I think the long fleet wheel openings will look nice on there.
The Brown Truck
