Old 11-07-2011, 10:22 PM   #126
dnd1978
dnd1978's Avatar
Re: I think i can!!! - SWB 72 Step-side
more pic.
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 11-08-2011, 12:25 AM   #127
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-08-2011, 10:22 AM   #128
67cheby
67cheby
67cheby's Avatar
yep what he said...nice progress
67cheby is offline   Reply With Quote
Old 11-08-2011, 05:20 PM   #129
dnd1978
dnd1978's Avatar
Cheby,
Thanks, I see you are making some good progress on your truck.
Old 11-08-2011, 05:41 PM   #130
67cheby
67cheby
67cheby's Avatar
i am plugging away...hopefully turn on the afterburners in the next couple months !! as soon as i get this back bed brace done the bed is going in the paint shop !!
Old 11-10-2011, 08:14 PM   #131
dnd1978
dnd1978's Avatar
Look what came in today! No Limit rack kit.
Old 11-12-2011, 11:07 PM   #132
giles70chevy
giles70chevy's Avatar
Good job on the front end. I'm doing the exact thing to my truck right now..... keep it up man...... I'll be taggin' along for your build now....
giles70chevy is offline   Reply With Quote
Old 11-12-2011, 11:10 PM   #133
gearys 5600
gearys 5600's Avatar
Nice !!
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 11-13-2011, 09:47 PM   #134
dnd1978
dnd1978's Avatar
Originally Posted by gearys 5600 View Post
Nice !!
Thanks Guys. I hope to get some work done this week.
Old 11-20-2011, 10:27 PM   #135
dnd1978
dnd1978's Avatar
I made some progress this weekend but it does not feel like much. I hope this holiday weekend will be way more productive.
I figured out my rear shock mount plan. I bought the upper mounts plates from No Limit Eng. The lower mount on the trailing arm is home made.
I got the rack kit mounted but ran into a lot of problems with Step 13, the bearing mounting. I will get it next weekend.
Old 11-27-2011, 09:03 PM   #136
dnd1978
dnd1978's Avatar
I hope you guys had a good Thanksgiving weekend. Food, family, friends and drinks! What’s not to like? I got a little work done on the frame. Its coming around, but not fast enough. I got my air ride system in!!
I finished all the mods for the rack kit. It took some work but we got it in with all the changes going on up there. Im hoping to have the motor in and the complete front suspension for test fit next weekend.
In the rear we added some boxing and tubing for support. I think the Tubing looks armature but im learning and buying more tools. Note need a pipe bender
Later
Old 11-27-2011, 09:14 PM   #137
dnd1978
dnd1978's Avatar
More pictures. The last picture is my trans cross member. I add a little somthing to it.
Old 11-27-2011, 09:15 PM   #138
big_al_71
big_al_71's Avatar
Great work....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-27-2011, 09:24 PM   #139
VA72C10
VA72C10
VA72C10's Avatar
Looking good! Like the gussets and braces....nice and solid. And love the accuair products!
Old 11-27-2011, 09:28 PM   #140
dnd1978
dnd1978's Avatar
Originally Posted by big_al_71 View Post
Great work....
big al 71,
Thanks.
After looking at the pictures I might need to take a camera class next!!
Old 11-27-2011, 10:14 PM   #141
giles70chevy
I might have missed something in some of the previous posts, but why are you moving the X-member forward 1"? Is it because of the wheels being centered in the wheel well?
Old 11-27-2011, 10:47 PM   #142
BuiltwithIvy
So a small thing I noticed, before you weld the bung for the trailing arms solid, I would suggest drilling some holes through the side of your tubing near the ends so you can plug weld it as well, safety on suspension is pretty important! I know this is something I have always done when making 4-bar kits, and have yet to run into a problem. But all things considered, its lookin awesome, keep up the kick @ss work!!!
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 11-28-2011, 12:29 PM   #143
dnd1978
dnd1978's Avatar
giles70chevy,
Yes, Im moveing the X-member forward to center the front wheel and change the handling.
Old 11-28-2011, 12:57 PM   #144
dnd1978
dnd1978's Avatar
BuiltwithIvy
Thanks for the advice! I had thought about it, but was not sure if I needed it. Will do!
Later
Old 12-04-2011, 08:19 PM   #145
dnd1978
dnd1978's Avatar
Whats up guys? I hope yall had a good weekend. I got some work done on the truck with the help of my dad. We assembled the front end, installed new motor mounts and installed the motor to check the fit. When i installed the new motor mounts we lowered the motor 1" and pushed it back 2". It feels good to see some parts going back on the frame!!! The rack kit from no-limit is installed and looks good.
Old 12-04-2011, 09:16 PM   #146
lolife99
67-72 parts collector,…
lolife99's Avatar
You might want to check,... But I'm sure the CPP upper a-arms are on the wrong sides.
(the straight tube goes in the front)
The upper balljoint should be closer to the front of the truck.
Here's a picture from a Classic trucks Tech article.
http://www.classictrucks.com/tech/10...s/viewall.html
They also install the balljoint on the bottom side for some reason.
Keith
Convert to disc brakes.
Old 12-04-2011, 09:57 PM   #147
dnd1978
dnd1978's Avatar
Lolife,
Haha! i know... just check if anybody is looking at my thread. Thanks
Old 12-04-2011, 11:43 PM   #148
gringoloco
A guy with a truck
gringoloco's Avatar
Haha- nice! The ball joints used to not fit correctly on the CPP arms- you have them installed the safer way...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-05-2011, 12:28 AM   #149
BBcj8
BBcj8's Avatar
Did you end up getting the Professional products injection? I have it on my 427 in my jeep.
I have liked it dont have alot of miles on it yet but runs good and is programable which is nice.
67 C20 CST long fleet SB 327
69 Chevy swb stepside BB 396
82 Jeep Scrambler Crawler BB 427
2008 CCLB Duramax Toy Hauler
To many big dreams.
BBcj8 is offline   Reply With Quote
Old 12-05-2011, 08:19 PM   #150
dnd1978
dnd1978's Avatar
BBcj8,
Thanks for the info. I did not get my fuel injection kit yet. I have it down to 2 different kits Professional Products or Holley Avenger EFI 4bbl Injection System. Im still thinking about it.
