Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-08-2012, 07:54 PM   #126
duallyjams
duallyjams's Avatar
Re: 66 4x4 my sons new project
Originally Posted by argonaut View Post
James,
I used 52" springs in the back. I can take a few more pictures this week if you like.
That would be great , I plan on using the same rear frame spring hangers on my 64.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-10-2012, 02:13 AM   #127
argonaut
argonaut's Avatar
Ask and you shall receive, James! I took a bunch of photos from all angles for you. All photos are of the left side spring.
One thing to note is that I trimmed some off the tops of the spring hangers in front of the rear spring. I had a 73 3/4 ton (from which the brackets came) and an 83 1 ton to look at while I was putting these on. The 3/4 ton brackets hung lower than the 1 tons. Both of these trucks had the front bracket placed more vertically than on my frame, mainly because the geometry of those frames is different and they are more level in the mounting location where ours are more sloped. I trimmed the hangers to be shorter like the 1 ton type, and not hang down as far as the 3/4 ton. This gave me a slightly more shallow spring angle (with respect to the horizontal plane) and obviously didn't give me as much height. But that will be made up for by using lift springs (2" or 4"). As a result of the location these brackets ended up in, you can see in the photos that the support bracket didn't line up with the four crossmember blots like the stock ones do on all the trucks. So I had to mark and re-drill new holes. I only caught three instead of all four, but I don't think it will be an issue.
I used a plumb bob and tried to locate the new bracket in such a way that the front pivot was vertically aligned with the original position. Same for the rear, more or less. I made some swags on the spot while doing the rear shackle hanger because the rear shackle is longer than the stock one. I think in the end I just aligned the top of the bracket with the top of the frame like it was on the 73.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 10-10-2012, 02:31 AM   #128
argonaut
argonaut's Avatar
Ah, okay, now I remember how I decided the relative vertical position of the hangers!
First I mounted the shackle hanger in the rear. It aligns horizonataly with the mounting position of the old shackle hanger. However there isn't much of an option, you pretty much have to mount it so that the bolt holes are centered between the top and bottom of the frame (same as on the donor truck). I then took some measurements and figured the effective drop of the rear spring eye, compared to stock, given this new shackle hanger location, and the longer shackles. I think it was around 4-5" lower.
Second I dropped a plumb bob at the location for the stock front hanger eye bolt. Then I positioned the front spring hanger with its eye bolt location about 5" lower, and rotated the bracket so that it was effectively oriented perpendicularly to the bottom of flange of the frame (since the frame is sloped and tapered in this area. This was necessary so that the backing bracket would sit flush with the under side of the frame flange and bolt together with the frame crossmember.
This resulted in spring geometry similar to the stock geometry, but without using the huge 5-1/2" stock lift block, and with a longer shackle. If I remember correctly I also lowered the front of the spring a little more than the rear, as this gave me a spring angle more similar to the newer model trucks I was using for reference. My logic was that the newer trucks probably handled heavy loads a little better and rode a little more comfortably, and thus some engineer had determined a more optimal rear spring and shackle design to accomplish this. Hopefully it works out!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-10-2012, 07:53 AM   #129
duallyjams
duallyjams's Avatar
Perfect thanks
James
IG duallyjams
Old 10-11-2012, 04:58 AM   #130
argonaut
argonaut's Avatar
Tire sizes. I lined up a selection of radials that I had around the house for a comparison. From right to left is 31x10.5R15, 235/85R16, 33x12.5R15, 315/75R16.
Ideally I want a tire roughly sizes at 35x10.5, but the only tires I can find in this size are Interco's SSR 35x10.5R16, a radial, roughly $400 each or the TSL Q78-16, a bias ply, roughly $300 each. I've heard bias play tires aren't that great for daily or highway driver vehicles.
I want tall and skinny, but for now I might just put the worn out 315/17R16 Xterrains onto my 16x6.5" 8-lug rims to get a feel for ride height.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-12-2012, 10:21 PM   #131
argonaut
argonaut's Avatar
Originally Posted by quadzero View Post
Everything is really coming together very nicely. It all looks professional, especially your new steering system. I also need a new tie rod and was wondering where you got yours and what do I need to know in getting one made up for me. Just wondering because I don't want to get some "pipe" from the local metal dealer here. Keep up the awesome work.
I used 7/8" tie rod ends, one right hand thread, the other left had thread, and a threaded sleeve for each. The sleeves fit 1" ID tub, so I bought some 1-1/4" x .125 wall DOM from my local hardware store. I don't think you really need DOM for this application though. I think standard cold rolled ERW in the same size would work fine and at about a quarter of the cost. Anyway I just welded the sleeves onto the tube and voila!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-12-2012, 10:32 PM   #132
argonaut
argonaut's Avatar
I was losing some sleep this week over the fact that I used 3/8"-16 bolts to reassmble my chassis. So this afternoon I bit the bullet and bought all new 7/16"-20 fasteners, and a 7/16" drill bit, and started removing the bolts, one by one, and replacing them with the larger, fine thread ones.
The benefit being that the 7/16 fine thread give me about 60% more clamping force at the joints compared to the 3/8 course thread, because of its bigger minor diameter. Also the fine thread pitch give a more shallow thread angle so it should resist vibration loosening a little bit better. Lastly the larger bolt head has more bearing surface. Best of all, I can sleep soundly tonight
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-13-2012, 03:54 PM   #133
quadzero
quadzero's Avatar
Thank you for that information, really appreciate it. I sometimes get that losing sleep feeling and the only thing you can do is go back and do it the way you think it should be especially at this stage of the game. Your logic for the bigger bolts makes perfect sence.
quadzero is offline   Reply With Quote
Old 10-19-2012, 11:30 AM   #134
gmjim4x4
Very nice work Jason! Hey, have you come up with the shock mounts for the corp 14 yet? I scored the same set up you have from a 78 3/4 ton with 6.2 diesel. The dana44 with the 8 lug hub and the corp14 FF. I am watching your build very close and you are a true craftsman. Hey, why did you put fabbed hangers on the front if you didn't change springs? just wondering (you did a fantastic job) Keep up the good work!
gmjim4x4 is offline   Reply With Quote
Old 10-20-2012, 09:41 PM   #135
argonaut
argonaut's Avatar
Gmjim,
I made new brackets for the front springs because neither the 66 brackets nor the 73 brackets would work for me. The stock 66 have an inner width of 2-1/2", meaning that standard 2-1/2" wide spring would contact the sides, not having any clearance. I think this was the stock design but not what I wanted. Then the 73 stuff is made for a 3" wide spring ends so they are 3-1/2 wide. Plus the front uses the radiator support bracket as an integral part, riveted on. So I thought it would look messy to modify it. Then the rear shackle hanger simply won't mount in the stock location, nor would it work with the stock bell housing crossmember on the 66. I can show you what I mean with photos later if you want.
I have a plan for the shock mounts but I havent welded the brackets on the axle yet. Basically instead of having the tabs straddle the shock putting it in double shear I will offset the tabs, with a collar between them, then mount the shock on the side, in single shear. Similar to the upper mount. Also the lower end of the shock will not hang lower than the axle tube, at least it wont as long as i can get adequate damper travel without doing so. I want as few things as possible hanging low.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-22-2012, 01:05 AM   #136
argonaut
argonaut's Avatar
This weekend was filled with turmoil over the right path to take with the drivetrain on the pickup. I pulled both SM420 transmissions I have apart, pressed all the sprockets off the shafts and inspected them. The hope was that between the two of them, I'd have a enough good parts to put together on solid transmission. Well I wasn't impressed with what I had to work with. One had rusty gears from sitting outside for 10 years (blame it on my hasty youth) and the other had some wear.
So today I decided to haul the two SM465 transmissions up from the stock pile of parts in the back, pop that tops and check them out. I wasn't expecting these two to look any better. Boy was I surprised to see that both of them, even the one that had been outside for a year were incredibly clean inside. The first came out of my Dad's 69ish K10 pickup. He swapped the SM465 and divorced T221 out for an automatic and an NP203. Based on the condition of his truck when he got it I thought it would be rough, but its was actually very clean inside and the oil looked clean too. The second is actually the SM465 + NP205 combo that came in my 73 K20 parts truck. This truck had seen some abuse too, but much to my surprise it looked brand new inside.
I first considered just putting the 2WD SM465 in and still running the T221. But then I figured what the hell. May as well upgrade both at once. And these two units are easier to find parts for and better supported by the aftermarket. So, although I feel like I've betrayed the 66 a bit, here it is:
Now that I've committed I've got a few new challenges (in addition to finding a good home for all these SM420 parts that have taken over my garage).
1) Because the 60's pickups, and early 4x4s, all had the engines sitting further back than the 70s and newer pickups, my front driveshaft will have to be lengthened. The rear will have to be shortened regardless as the donor truck was a longbed. However the lengths are dependent on the outcome of the additional issues below.
1) The shifters now site further back than the stock setup. The trans shifter is ~1-1/4" further back, and the transfer case shifter is about 3" further back. Aside from the potential for the TC shifter to hit the seat, I also wanted it to look stock inside the truck and not hack up my nice high hump. The next step here is to get the cab on the frame and actually see where the shifters line up and where the interferences are. Then I can decide about the possibly moving the whole assembly, motor + trans + tc, forward and inch and a quarter. I also have an idea on a custom bent shifter for the transfer case that would utilize the stock hole on the driver side of the 66.
3) If I do move everything forward I end up with other problems. Tight clearance up front between the water pump and the radiator. I'd have to eliminate the stock crossmember than spans at the front shackle mounts (former bellhousing support), and swap in a 67-72 K-series engine crossmember (I may have found one already though).
Also, the frame is taller on the 60-66 than the 73+ pickups. Which means that the 73 trans crossmember won't mount up to the bottom of the lower frame rail as intended.
No biggie though. I'll just make a simple pair of brackets out of 2" angle that will look something like this (only with a bigger, thicker piece):
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-22-2012, 07:55 AM   #137
duallyjams
duallyjams's Avatar
GM had a half dozen different shifters for the np205 , some would be close to were the t221 shifter would be. I think a 70 truck had them.
On the tires you move up to a 17" tires would give you more choices on tall skinny tires.
James
IG duallyjams
Old 10-29-2012, 10:39 AM   #138
argonaut
argonaut's Avatar
I test fit the cab on the chassis with the new powertrain setup and I learned a few things. It was nice to see it resemble and actual truck again, even if only for 30 minutes.
It turned out that the firewall and the valve covers on the big block were just kissing. There was almost nil for clearance at the distributor too.
I know some other members here have gotten away with running a big block in the stock position. I was hoping that would work for me, but alas I'm not overly surprised that it didn't pan out. Based on this test fit I knew I needed to move the whole powertrain assembly forward by an inch or so.
Then I poked around the inside of the cab and the hump where the shifters come through. The SM465 is about 1.25" longer from its front face to centerline of its shifter. So I decided to move the motor forward 1.5".
I didn't want to move it too far forward. When I had the big block in my 2wd 64, I moved it the full 3" forward and it really seemed to shift the trucks weight too much over the front wheels. I also didn't want to lose all the space between the water pump pulley and the radiator like on my 64.
Anyway, I didn't get anymore photos, but I pulled the cab off and powertrain out. Then I removed the stock engine mount brackets, as well as the bellhousing crossmember. I then installed the 67-72 K-series engine crossmember and clamped it in the target location, with the motor mounts exactly 1.5" forward of the stock position. I put the 73+ transmission crossmember about where it belonged. Then I put everything back on one more time to make sure it would all fit okay, and wouldn't require any frame trimming. Everything fit fine so now I have to clean and paint the new crossmembers, drill the frame and then I can put the motor, trans and transfer case in their final resting places once and for all. Whew!
The real kicker here is that I would not have been able to so easily move the powertrain forward if i hadn't gone to the married SM465-NP205 setup from the divorced SM420-T-221 setup. And the reason is that I wouldn't have been able to just shift the motor mount brackets and bellhousing crossmembers forward. They are both mounted to angled parts of the frame and would have required extensive rework and fabrication to make work, or just completely custom crossmembers. So, in the end, everything would have ended up the same either way.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-29-2012, 11:41 PM   #139
travz500
travz500's Avatar
so did you use the 47" front springs off the 73-87 frame? if you did, did you move the shackles for the rear of them back and make a new hole or did you do something different
travz500 is offline   Reply With Quote
Old 10-30-2012, 01:29 AM   #140
argonaut
argonaut's Avatar
Trav,
I used 44" spring up front, and 52" in the rear. So I used the stock mounting positions but made new brackets.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-30-2012, 02:01 AM   #141
travz500
travz500's Avatar
ok was hoping you used some 47" so I can see how you did that I think i am gonna use my 47s since I got a 8" spring lift on my newer frame but I am using my old 65 frame soon as it gets shortened to fit the shortbed think I may just fill the hole where the rear shackles go thru the frame and then make a new hole so the longer springs will work out thanks for the information and nice build so far
Old 11-04-2012, 02:05 AM   #142
argonaut
argonaut's Avatar
Trav,
That is exactly how I would do it. I'd fill the hole, then move the front mount 1.5" forward, and the rear mount 1.5" rearward. Unless of course you with to offset the axle forward or backward a bit. What spring hangers and brackets are you going to use? You might also think about the angle you want your shackles to be at when loaded. This may change the location of the shackle hanger.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 11-04-2012, 11:34 PM   #143
travz500
travz500's Avatar
gonna use all the stuff off of my 87 blazer frame its all in good shape
Old 11-08-2012, 02:57 PM   #144
argonaut
argonaut's Avatar
Finally got my new lift springs in yesterday! Now I can set the suspension and steering for good (as long as it doesn't rain this weekend ).
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 11-10-2012, 02:24 AM   #145
argonaut
argonaut's Avatar
Swapped out the bushings and mounted up the 4" lift springs, front and back, this afternoon. The fronts were about 1.5" higher, and the rears 4" higher, than what I had on there previously... and now it sits quite a bit higher than I thought it would! Maybe too high?
I guess I'll keep it this way and finish the build. It will definitely need 35" tires now! Hopefully it will sit an inch or two lower once the powertrain and body get loaded onto it. If I still don't like how high it is I'll drop it down with 2" lift springs later on.
If all goes according to plan I should have the crossmembers and powertrain back in place by the end of this weekend.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 11-10-2012, 08:05 PM   #146
duallyjams
duallyjams's Avatar
The weight will bring it down some.
James
IG duallyjams
Old 11-13-2012, 03:41 PM   #147
splehigh
splehigh's Avatar
Very nice looking frame
splehigh is offline   Reply With Quote
Old 11-14-2012, 04:11 AM   #148
MTCK
MTCK's Avatar
Awesome build! I'm not sure how I missed it previously... I got a good chuckle out of your hardware swap too. I bet the guy at Fastenal loves to see you coming. Probably a very smart move, though. I was going to say look into some 255/85r16's, but I think you might need a little more than that with as much lift as you have. I think I've seen some of those spec'd at 33.7 x 10. Keep up the good work!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-22-2012, 01:39 AM   #149
Auctioneerhere
This is very helpful information with great pictures. Thanks!
Auctioneerhere is offline   Reply With Quote
Old 12-04-2012, 04:23 PM   #150
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nice project, this thing is going to be sweet!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
