12-20-2012, 04:01 PM | #126 |
Boosted Member
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Back to my project.
Cleaned up the heads, and started swapping valve springs. Also started tearing into the 6L. Sadly, I won't get a chance to work on it for another week or so....travelling home for chirstmas. In the meantime I've got a buddy that is powdercoating the valley cover and the front timing cover.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
12-20-2012, 06:56 PM | #127 |
Certified BFH Operator
Ya, Chris has the itch to build, so i'm gonna set him loose on my c10 when he gets time.
Looking good! Hope to clear out some more of your shop space by gettin some pesky parts out of your way soon and relocating them onto my truck
- 1969 swb C/10 fleetside -LSx swap and Resto in progress LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay... -1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle |
12-25-2012, 12:34 AM | #128 |
Great build!
Posted via Mobile Device |
01-03-2013, 05:23 PM | #129 |
This truck is going to be awesome when finished. And the pictures don't do the fab work justice... the out board shock mounts look right at home with the PB parts.
01-07-2013, 10:40 AM | #130 |
Boosted Member
I stripped all the ricer paint off the block, and sprayed it with a single stage urethane black.
Studded Welded some crankcase vent fittings to the valve covers. These are the manifolds I'm using for the new turbo setup. They're from a C6 vette. (ZOMGVETTEPARTS!!!) Engine is pretty much finished. Next comes the trans.
01-07-2013, 04:34 PM | #131 |
A guy with a truck
Nice, clean work as usual. Looks beastly! Doing single or twins?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-08-2013, 02:04 AM | #132 | |
Boosted Member
Worked for a bit tonight. Gutted out the old trans....I guess the broken case was a mixed blessing, because I found a couple other issues during the teardown. Been wanting to do this for awhile....build a completely gutted LS1/4L80E for mockup purposes. Had a toast LS1 sitting on the shelf Welded the broken bellhousing ears back on to the trans case Voila! Mockup goodness. It's kinda awkward shaped, but I can lift it by myself.
01-12-2013, 03:03 AM | #133 |
Boosted Member
Got the steering rack put on last night
Time to mate the body to the frame to check how everything fits Everything seems to fit decent for the most part. Plenty of clearance around the engine and trans. A couple of my chassis stiffening bars tag the body underneath, so that will have to be reworked. Also I'm gonna have to do some tweaking to level out the rake.
01-12-2013, 10:05 AM | #134 |
A guy with a truck
Nice progress! Cool to see it together. Do you have enough adjustment in the coil overs to get it to sit how you want?
01-14-2013, 10:19 AM | #135 | |
Boosted Member
Rolled it outside on saturday to snap a couple more pics. Seeing it take shape is definitely a motivator.
01-14-2013, 11:41 AM | #136 |
Looks awesome, especially those wheels
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-18-2013, 12:16 PM | #137 |
I'm just glad to be here!
Can't wait to se more progress. I like your build plan and like how you did the rear coil overs.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-18-2013, 02:56 PM | #138 |
That motor is awesome, cant wait to see the turbos on top of it....big bucks!
Nice work on all the fab work
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-22-2013, 03:07 PM | #139 |
Now this is a nice project. I just wish my 7yr old daughter was excited about the cars/trucks but runs away. But I still plan on her running w/me in the 81 when it's done.
81 GMC C15 RC SWB 5.3L 4L80E project |
01-23-2013, 02:33 PM | #140 |
Boosted Member
Thanks guys.
Got the frame 90% boxed in. Just need to finish welding, and a couple other things, and the chassis will be mostly done and ready to paint. Also finished up the Megasquirt harness and tested all the sensors.
01-23-2013, 09:47 PM | #141 |
Lookin good Jeff.
Danny looks proud of his wiring work and ready to be done with it.
70 Chevelle SS (clone), 454, 350 auto 71 K5 350, 350 auto, 3" body lift, 35's -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |____|__|___] *.*..*.*.._@_ _ _ _ @ |
01-24-2013, 01:58 PM | #142 |
nice work on the frame and wiring!
02-15-2013, 01:16 PM | #143 |
Boosted Member
I've been welding my ass off, and not much to show for it other than 3 empty TIG tanks in the past month or so. Grind, prep, weld, repeat. My garage is destroyed right now with grinding dust everywhere.
Everytime I thought I was done with the frame...I'd think of something else I forgot....but at least now everything is welded up. Got the coilover mounts all burned in, and fabbed up a panhard rod mount. The valvecovers also made their way back from the powdercoater. I forgot how much I hate painting. I would rather weld for an additional 10 nights, than to have to paint an additional night. Anyway, it's done. Sprayed it a gloss black urethane with an HVLP gun. Made a big ass mess, but the finished result looks pretty awesome.
02-16-2013, 08:49 AM | #144 |
That's really nice.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-18-2013, 11:22 AM | #145 |
Boosted Member
Swapped from drums to discs on the rear axle. They're police Caprice / Impala SS brakes.
Also routed the rear brake lines to the calipers and temporarily secured them. Got all the front and rear suspension back underneath it. Gotta run the brake hardline along the framerail yet. Next up....big fuel.
02-21-2013, 05:41 PM | #146 |
WOW great progress on the build!!
02-21-2013, 08:59 PM | #147 |
I see you changed the position of the coil over to raise the front. I am also going to do this in a couple weeks. I'm curious to see how much this will lift the front.
02-22-2013, 11:05 AM | #148 | |
Boosted Member
We'll see how it shakes out.
02-22-2013, 11:06 AM | #149 |
Boosted Member
Slowly checking tasks off the list.
Got the transmission put back together and buttoned up. Would really like to get it mated to the engine and back in the chassis this weekend. Hopefully. Like everything else on this project, the running the brake lines is taking way more time than I budgeted for it. Started out with a roll of copper/nickel alloy line, a flaring tool, and went to work. After 3 hours, this is all I got done...lots of head scratching and pondering the best route, clipping points, etc....gotta leave room for the downpipe to make it thru. Also got the PS rack re-installed. Gotta find a place to mount this guy. Will probably wait until the body is back on, and fab a bracket that comes off the master cylinder.
02-22-2013, 07:08 PM | #150 |
GEARHEAD
Hell of a build.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
