Old 10-14-2012, 09:21 PM   #126
1978chevybigten
1978chevybigten's Avatar
Re: 1978 big ten build
Originally Posted by mud.man.rj View Post
Comes up as a 26 spline Auburn posi unit.
thanks for the info! i looked high and low and couldnt find the specs
1978 big ten 350/350:chevy
1978chevybigten is offline   Reply With Quote
Old 10-18-2012, 09:17 PM   #127
1978chevybigten
well that what i get for buying the cheap autozone handles
Old 10-18-2012, 11:33 PM   #128
mud.man.rj
mud.man.rj's Avatar
Your arms are just stronger than where they were made. Junk for sure.
mud.man.rj is offline   Reply With Quote
Old 10-19-2012, 11:09 PM   #129
WarBeard
WarBeard's Avatar
You are stronger than a Chinaman
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 10-24-2012, 05:20 PM   #130
1978chevybigten
Had a rough day today. Transmission went out. On the way home didn't shut the hood hard enough like a dumb a** hood flew up broke the hinges. Yep today was a bad day.
Old 11-10-2012, 06:55 PM   #131
1978chevybigten
Been a while since I posted. Going to pull engine and tranny over the thanksgiving break and rebuild the trans and fix all oil leaks on motor also replace the lifters and cam. Finally finishing up all the interior hopefully getting carpet in the next couple of weeks and new back window. Things are looking up!
Old 11-21-2012, 11:06 PM   #132
1978chevybigten
started working on the trans this week. friction plates were toast..got the rebuild kit torque converter and stage 1 shift kit from rockauto.
Old 11-21-2012, 11:12 PM   #133
1978chevybigten
Also got a cool picture when i was broke down at my fishing spot. starter went out. this was right before the tranny went out.
Old 11-22-2012, 01:42 AM   #134
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Cool build! Sorry about all this bad luck though.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-22-2012, 01:56 AM   #135
1978chevybigten
thanks man! and ya shes just keeping me on my toes
Old 11-23-2012, 11:18 PM   #136
1978chevybigten
half way done with the trans rebuild. this trans was rebuilt at some point and who ever did it was not the smartest gearhead out there..... the 1-2 accumulator spring was broken and he just put it back in.. on the modulator valve he didnt put the spring back on. over tightened everything to the point is mashed up the parts. also spent today getting the bushing kit and the lip seal tools also got the control valve assembly cleaned which took at least an hour just to clean it was full of friction plate goop. and got the shift kit springs installed. tomorow ill be installing new bushings, seals and starting the re assemble process.
Old 11-25-2012, 10:17 PM   #137
1978chevybigten
the trans is almost done come to find out the po took the 2-3 accumulator spring out. iv heard of people doing this and shimming it to make the shift crisper but this wasnt shimmed. so ill head to a local trans shop and see if they have a spring if not then ill have to go and order one off the internet.
Old 12-16-2012, 08:39 PM   #138
1978chevybigten
trans has been in the truck since last week, shes shifting good. replacing the cam,lifters,push rods next weekend. next week will be a busy one, ill be graduating high school and getting started enlisting in the the USMC.
Old 12-19-2012, 07:43 PM   #139
1978chevybigten
Instead of buying the comp cam and lifters I decided to just replace the lifters and push rods. And save for a crate engine.
Old 12-25-2012, 08:15 PM   #140
1978chevybigten
Got some snow today!
Merry christmas everyone!!
Old 12-25-2012, 08:17 PM   #141
JRANGER
JRANGER's Avatar
Nice suppose to snow tonight here....back to work tomorrow in the stang ugh
JRANGER is offline   Reply With Quote
Old 12-25-2012, 08:20 PM   #142
1978chevybigten
bummer man!!
Old 12-25-2012, 08:45 PM   #143
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Got about an inch out here. Boy do I love driving in the ice spinning around!
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 12-25-2012, 08:48 PM   #144
1978chevybigten
Same here man!!
Old 12-25-2012, 08:49 PM   #145
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
It was 70 degrees here with no clouds most of the day, a cold front blew in a little while ago and its down to 40 or so now...
Tony
Old 12-25-2012, 08:53 PM   #146
THE "10" SILVERADO
Got home about 20 minutes ago and the last temp reading on the truck was about 23-4 degrees.
Michael
Old 12-25-2012, 10:02 PM   #147
mud.man.rj
mud.man.rj's Avatar
Lookks congested where you park, a bit of everything. It is -25 here right now with about 1ft plus of snow, but not to slippery.
Old 12-26-2012, 09:31 AM   #148
rusty76
rusty76's Avatar
It'll be awhile for snow here.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-26-2012, 06:32 PM   #149
1978chevybigten
finally broke down and bought a stero system. a kenwood kdc-152, a pair of 6 1/2 2 way speakers, 400 watt dual amp, 2 boxed 8in subs, and a pair of 6x9 duals. im wanting to build a console on the trans hump. that will hold the 6 1/2, my tach and temp gauge. has anyone ever done this? id like to see pics if you have them.
Old 01-04-2013, 10:16 PM   #150
1978chevybigten
finished the sub box today.
