Old 01-26-2013, 05:47 PM   #126
Malamute
Malamute's Avatar
Re: PB bagged 69 stepside-because Leon asked...
He didn't know Jim. He said he bought it in the for sale section on this board some time ago. He ran it 90 minutes with no issues before it was shipped but something is out of whack now. If there was an adjustment in the front/rear direction I could solve it easily I believe.
I have a thread and pic over in the 67-72 section as well so we don't clutter your thread Jim.
Malamute is offline   Reply With Quote
Old 01-26-2013, 05:54 PM   #127
Jimbabwe
Jimbabwe's Avatar
Hey, no problem. I'll check it out.
Jimbabwe is offline   Reply With Quote
Old 01-27-2013, 06:17 PM   #128
502ms
502ms's Avatar
Oh man...I forgot about the step stickers. Will do the same
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 01-28-2013, 02:52 PM   #129
lolife99
67-72 parts collector,…
lolife99's Avatar
Are you looking for a stock throttle cable for a 6-cylinder?
I have this set-up that I bought on the board.
I sold the truck it was to go on.
http://67-72chevytrucks.com/vboard/s...d.php?t=463659
I would think you would need the 71-72 gas pedal assembly also.
Keith
Convert to disc brakes.
Old 01-28-2013, 03:01 PM   #130
Jimbabwe
Jimbabwe's Avatar
Yep. I think that's what I need instead of the handmade job on my firewall. I have the pedal assembly, with the LFD bracket in there now.
This is what I just posted--besides the WTB ad:
Are any of you running a straight six with a throttle cable (not a rod) in your 71/72?
I've got a '69. We swapped the rod for a 2wd V8 cable with a handmade bracket mounted on the firewall, and the 71/71 pedal with the LFD bracket. The loop it has is minor, but the cable, even lubed, is VERY hard to push/pull--due to the loop, I'm sure. I was going to switch back to the rod, but I got a universal Lokar cable which I can cut much shorter than the stock one to remove the unnecessary tight loop. It will be very short since the bracket we made is on the firewall.
I'd like to know, or see, what the throttle bracket setup is which the 71/72 trucks used. Where it mounted--on the carb? Motor? Maybe I could get my hands on the factory bracket, or similar and get rid of the cobbled together pos that my buddy made.
Old 01-28-2013, 03:08 PM   #131
lolife99
lolife99's Avatar
The part circled in red, is the key to making what I have work.
The manifold has to have these two bosses cast into it,... to accept the bolt on bracket.
Keith
Old 01-28-2013, 03:11 PM   #132
Jimbabwe
Jimbabwe's Avatar
I'll have to check mine out. I don't remember them being there, which is why we made something else...couldn't figure out where to attach anything on the carb or motor. Mine's a '69, I wonder if they only made them that way when they switched to the cable in 71. I'll look and let you know. Thank you.
Old 01-28-2013, 03:11 PM   #133
lolife99
lolife99's Avatar
This part of the manifold (yellow "X") is also critical for mounting the linkage.
Keith
Old 01-29-2013, 01:00 PM   #134
Jimbabwe
Jimbabwe's Avatar
Keith,
It looks like I'm good on mounting the stock brackets.
Old 01-29-2013, 01:02 PM   #135
Jimbabwe
Jimbabwe's Avatar
Oops! Forgot the pics! You can see the bracket that was made in an attempt to make due, and the crazy loop that makes for an extremely non-smooth throttle.
Old 01-29-2013, 01:42 PM   #136
lolife99
lolife99's Avatar
I have $50 in my bracket and cable.
I can ship in a flat rate box for $61 if you are interested.
Keith
Old 01-29-2013, 01:45 PM   #137
Jimbabwe
Jimbabwe's Avatar
I PM'd you.
Old 01-29-2013, 07:08 PM   #138
lolife99
lolife99's Avatar
Linkage on it's way to you!
Thanks.
Keith
Old 01-29-2013, 07:18 PM   #139
Jimbabwe
Jimbabwe's Avatar
Cool, thanks!
Old 02-22-2013, 11:59 PM   #140
jblaust
jblaust's Avatar
Looks sweet! Do you have any pics inside the bed to show the cnotch and how you cut the wheel wells to fit the rims?
jblaust is offline   Reply With Quote
Old 02-23-2013, 12:01 AM   #141
Jimbabwe
Jimbabwe's Avatar
I do. I'll post some when I get home. Thanks!
Old 02-23-2013, 12:02 AM   #142
jblaust
jblaust's Avatar
so you narrowed the rearend to make the rims fit in the stepside wheel wells?
Old 02-23-2013, 12:04 AM   #143
jblaust
jblaust's Avatar
I just bought a 1968 stepside and im planning on bagging it right porterbuilt strong arms in the front and bolt in c notch and 4 link in the back with e-level and accuair compressors
Old 02-23-2013, 12:06 AM   #144
Jimbabwe
Jimbabwe's Avatar
Yes. It's a must with the stepside if you want to be that low. Narrowed 8 1/2".
The step notch, and all other suspension components are made by Porterbuilt, if you are not familiar with them. I highly recommend checking them out. The bedsides are cut right up to the top inside of the fenders--just above that center bolt.
Old 02-23-2013, 12:07 AM   #145
Jimbabwe
Jimbabwe's Avatar
Oops, we typed that at the same time! So then you know!
Old 02-23-2013, 12:09 AM   #146
Jimbabwe
Jimbabwe's Avatar
The first few pics actually show you the inside, although it was cut up the additional inch or so that was still there to get more clearance and lower.
Old 02-23-2013, 12:13 AM   #147
jblaust
jblaust's Avatar
how much did it cost to narrow the rearend? was it a pain in the butt?
Old 02-23-2013, 12:14 AM   #148
jblaust
jblaust's Avatar
still have to body lift the bed right?
Old 02-23-2013, 12:17 AM   #149
Jimbabwe
Jimbabwe's Avatar
It was 2 and change. I wrote here somewhere. 1st or 2nd page.
Body lift bed? To get it off? It was lifted on a lift at a shop. Much easier, but 2 guys can lift a bed. I did it with the fleet I had before this.
Old 02-23-2013, 12:20 AM   #150
jblaust
jblaust's Avatar
what i meant is dont you have to raise the bed floor 4 or 5 inches to clear the cnotch and the wheels if your laying frame?
