Old 06-22-2014, 08:07 PM   #126
RANDY COX
RANDY COX's Avatar
Re: Randy & Jakes 64 4x4 SLOW build
Well Guys she's sittin pretty
my megshift motor mount, LOL until I can get my hands on one
Gotta get everything buttoned up.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 06-22-2014, 08:27 PM   #127
mud.man.rj
mud.man.rj's Avatar
She is coming together pretty nice...except the motor mount Ahh it always twists that way anyway, no one else will have a hammer. Like the paint color matching the truck and block.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 06-22-2014, 10:49 PM   #128
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Nice work! Engine look perrty!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-23-2014, 09:23 PM   #129
C@rnut001
Man, your engine is looking great. Keep it up!
C@rnut001 is offline   Reply With Quote
Old 06-24-2014, 01:17 AM   #130
argonaut
argonaut's Avatar
I like that color!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 06-24-2014, 12:40 PM   #131
61K10
61K10's Avatar
looks good Randy!! But i would use a hammer with a metal handle-----
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-24-2014, 12:57 PM   #132
1963c-10
1963c-10's Avatar
Are the mounts the same as the 230 and the v8's? For some reason I remember the 292 mounts being unique. I have two sets of the 230/v8 mounts if they will work.
Engine look great sitting down in there and again....the paint looks great.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-24-2014, 02:42 PM   #133
McMurphy
McMurphy's Avatar
I am pretty sure they are all the same, and I have a set of them as well if you need them.
Mine were under the original 292 that came in my truck.
You are welcome to them.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 06-24-2014, 04:58 PM   #134
RANDY COX
RANDY COX's Avatar
Thanks Guys, the 292 engine perch is different from the others I believe, I took the V8 perch off of the cross member I took out but it's totally different, And I would assume it would also have to be for a 4x4..
I got the exhaust from the manifold bolted up and got the carb on it and fuel pump, Gonna put the starter on it today and clean up the line from pump to carb...
1964 BBC 402 4x4
Old 06-24-2014, 09:46 PM   #135
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Then...you MUST post a vid of it running when you fire it up. lol
Old 06-25-2014, 04:23 AM   #136
RANDY COX
RANDY COX's Avatar
OOPS TJ I fired it up yesterday, she was running smooth.I'll see what I can do..
1964 BBC 402 4x4
Old 07-01-2014, 04:43 PM   #137
RANDY COX
RANDY COX's Avatar
Not too much work on the truck, It's been very hot here in the 90's and no shade...I did
manage to get the steering rod welded and sleeved. This will work until I can get me an
early 70's column.
I still got to find or fab up some power steering brackets. Slowly but steady.
1964 BBC 402 4x4
Old 07-01-2014, 10:20 PM   #138
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Progress =
Old 07-01-2014, 11:53 PM   #139
mud.man.rj
mud.man.rj's Avatar
How is the "special" motor mount doing, get one to change it to.
5.0 4spd std.
7" lift w 35's.
Old 07-05-2014, 08:56 AM   #140
RANDY COX
RANDY COX's Avatar
No still on the look right now CASH flow is slow I will have to wait, I did run across some front Tow hooks that I want. My battery gave up the ghost so now I need to buy a battery, I did go out yesterday and Installed a new master cylinder on my ole car that I've had for a few months, I still need to get a new gasket for my car to install new windscreens yada,yada,yada. I still have plenty of metal work on the truck to do like replace the rear cab corners... I did install my Heater assy back on the truck yesterday...
1964 BBC 402 4x4
Old 07-05-2014, 08:45 PM   #141
RANDY COX
RANDY COX's Avatar
Well got my heater assy painted and installed and radiator..
1964 BBC 402 4x4
Old 07-05-2014, 08:49 PM   #142
RANDY COX
RANDY COX's Avatar
click on that last pix and it will take you to my album and hear the motor running...
1964 BBC 402 4x4
Old 07-05-2014, 08:59 PM   #143
RANDY COX
RANDY COX's Avatar
I've noticed that with the cowl area exposed that a lot of the caulking has dried out and fallen off,I will definitely re-caulk these areas to keep water from coming inside. I have already re-caulked the roof seam a while back..
1964 BBC 402 4x4
Old 07-05-2014, 09:54 PM   #144
C@rnut001
It is looking great. Keep it up!
Old 07-06-2014, 01:08 AM   #145
mud.man.rj
mud.man.rj's Avatar
Looking good, little at a time gets it done.
5.0 4spd std.
7" lift w 35's.
Old 07-06-2014, 10:33 PM   #146
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Looking good dude!
Old 07-14-2014, 06:31 PM   #147
RANDY COX
RANDY COX's Avatar
Well gentlemen I found me a motor perch I need it's in a 69 4x4 with a 292, The gentlemen told me if I pull the engine I could have the perch or If I want to buy the engine he would let me have it for $100.00 bucks, I already have an extra engine now so I think I'll pass on the engine for now and just get the part I need... I need to get my car sold so I can buy some more for the truck so I can finish....
1964 BBC 402 4x4
Old 07-14-2014, 09:46 PM   #148
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I'd buy the engine...slap it in another truck and turbo it! Then drive it till she blows up! Then...not really a wasted motor...only 100 bucks anyhow.
Old 07-16-2014, 07:54 PM   #149
RANDY COX
RANDY COX's Avatar
My new SEXY wheels watcha think. Just kidding these will be the wheels but painted Alpine Green, with some kind of 16" tire.
got out there this evening and took out more rusty panel.
1964 BBC 402 4x4
Old 07-17-2014, 11:56 AM   #150
61K10
61K10's Avatar
Randy, you now can throw out your cold coffee without getting it all over the side of your tk lol! that work i did not enjoy on my tk. looking good though---
1961 chevy K10
