Old 08-16-2016, 09:50 PM   #126
faribran
Re: 1967 Custom Sport Shop Truck
I like the changes you have made to your truck!!
faribran is offline   Reply With Quote
Old 08-17-2016, 09:12 AM   #127
bluex
bluex's Avatar
Originally Posted by Bubba4spd View Post
Thank you! I will pull up the website tonight. I've had my eyes open for a T5 out of a 4.3 S10 but the NV would work just as well.
No problem, for some more info here is my install write up that has inspired Jesse to swap his. It wont be exactly the same for you guys but the main differences would be where the shifter comes through the floor and where on the firewall you mount the master.
http://67-72chevytrucks.com/vboard/s...d.php?t=714465
Here is a write up that I referenced during my install, its on a 65 but gave me alot of good info for my swap
http://67-72chevytrucks.com/vboard/s...d.php?t=300087
If you were looking at T5's I imagine you know the limits of these transmissions. As long as your staying with a mild small block like Jesse and I are you should be fine with a NV3500. They get a bad wrap but thats because people try to put them behind 400hp 383s and do 5000 rpm clutch dumps....
bluex is offline   Reply With Quote
Old 08-17-2016, 03:28 PM   #128
67ChevyRedneck
67ChevyRedneck's Avatar
Yup, according to the research we did, the NV3500's have a "safe range" of around 300 ft-lbs of torque (they were also used behind the 305 and the newer "LS" 4.8L in the full size trucks as well. The NV4500 went behind the 350's and bigger motors). My crate engine will only have around 225 HP, maybe 250, 260 ft-lbs of torque? So as long as I'm not constantly dumping the clutch on it, it will probably hold up fine.
I will also give you a heads up that you would probably want an "S10" NV3500. There were two versions, a "close ratio" and a "wide ratio." The S10s got the close ratio and the full size got the wide ratio. Both have the same 5th gear 0.73 ratio, but I've read on multiple forums that the wide ratio "shifts like a dump truck" which isn't fun in a "toy."
https://en.wikipedia.org/wiki/New_Ve...0_transmission
What actually pushed me into the swap, Paul, was pushing in the clutch pedal in your truck. All I could remember from the old 3 speed days of my truck was how much of a ***** that clutch was to push in (I was also 16 and weighed about 140 lbs soaking wet). The hydraulic clutch pushed in as nice as the one in my 65 mustang.
Also, the 96/97 trans puts the shifter nicely in the middle like in Paul's thread. The 1998+ one I bought puts it 4-5" from the bench seat. I plan to remedy that with this and a core shifter base:
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-18-2016, 12:41 AM   #129
Bubba4spd
Bubba4spd's Avatar
Yes the close ratio would be better. I have a 99 Silverado (Betsy) with the 4.8 L and the transmission has worked flawless now for 17 years. So I am good with going the 3500. And yes the 1st gear in the wide ration box is a little low for a lighter non loaded fun truck but it's not bad.
Bubba4spd is offline   Reply With Quote
Old 08-18-2016, 03:14 PM   #130
bluex
bluex's Avatar
Man I bet thats a fun truck to drive there.
I think the ratios are well suited in the S10 box. I'm very pleased with mine anyway, I dont know that I would like the wide ratio one.
Old 10-06-2016, 08:52 AM   #131
67ChevyRedneck
I got a little tired of the top looking like total garbage and it doesn't take a lot of time to make it look decent, so the top got a "quickie."
Collecting more parts for the 5 speed swap. BlueX hooked me up with a set of pedals. I have everything but the hydraulic clutch for the firewall, which I plan on getting Captain Fab's kit.
I hope to start back on the truck this winter. Been having too much fun driving her to tear her apart.
Jesse James
Project "On a Dime"
Old 10-06-2016, 10:04 AM   #132
knomadd
knomadd's Avatar
Top looks much better, nice work!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 12-11-2016, 11:02 AM   #133
STAP54
Totally stalking your build threads! lol. Now it's time to move on to the vintage air thread.
Steve
STAP54 is offline   Reply With Quote
Old 12-12-2016, 01:32 AM   #134
67ChevyRedneck
Thanks guys!
The vintage air thread is definitely a little "out of date" as VA sells all of their kits as electronic now (no more cables to the dash), and the hoses come out of the cab a little different, but same idea. I installed one of the "newer" electronic kits in my 65 Mustang.
I had new windows installed in the house. Hail damage paid for 8 of 18, house is 17 years old, so we decided to have the entire house done. We bought a much higher quality window this time around and I worked out a deal that if I repainted the window jams and sills, and if I installed 6 of the windows myself (I had them do all the insurance windows and all the 2nd story, which left the 4 along the front under the porch and the two garage windows) that really stretched the insurance $ and were able to have everything done for $3,300 after insurance. Pretty happy about that, but it's taken up a lot of my time. ALL windows are now installed and I have most of the jams redone. I also finished our master bath remodel this weekend... SO, I hope to have updates on the truck soon....
Jesse James
Project "On a Dime"
Old 12-16-2016, 01:26 AM   #135
67ChevyRedneck
So I did stuff. It's not perfect, but I'm getting better.
Jesse James
Project "On a Dime"
Old 12-16-2016, 01:49 AM   #136
70LonghornCST
Moderator
70LonghornCST's Avatar
Nice work! Are those clips easy to work with? I'm tempted to install a toolbox door on my bedside...just a bit timid to cut out such a big section.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 12-16-2016, 09:23 AM   #137
67ChevyRedneck
They're neat clips if you have backside access. You can also use them without backside access, but its a little trickier and you need to be able to move the panel around to get the little bars in the back to fall out.
Heat sucks. I warped the area around the sidemarker filling them in (like... BAD many months ago)... ironically, not from welding, but from grinding heat. I'm pretty sure I have some form of ADD and have a hard time going slow. I did MUCH better with this patch! I guess it's going to work out though, because I got the whole end section of that green patch (was a longbed). It turns out my taillight housing has a lot more rust than I would like, so I'm going to cut out and replace the back 8-10" of the bed too.
It's a learning process. I think I paid $350 for the complete bed and another +/-$100 for the patches. I should have a decent "original" bed without too much filler when I'm done... fingers crossed.
I could just buy new bedsides, but side by side, the curves just don't look right at the bodyline and around the wheel well to me.
Jesse James
Project "On a Dime"
Old 01-07-2017, 08:55 AM   #138
rusty76
rusty76's Avatar
I am late as usual but I spent some time this morning reading through your build and of course I dig it. Cool truck and lots of good info.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-06-2017, 01:59 AM   #139
67ChevyRedneck
Don't worry about being late, I'm already a couple years behind schedule on this one. At least I've been driving it all that time.
Made some more purchases. Kinda can't help myself. I think the bedsides are better than what I have. They still need quite a bit of work though. The front fenders are really nice, PS needs typical cup, but they came with a new one already which was nice.
I've also spent the past month+ just cleaning my garage out so I can use it again. It was pretty bad. In doing so, I was able to get my crate engine up on the stand and somewhat ready for assembly.
Racing along at a snails pace...
Jesse James
Project "On a Dime"
Old 02-06-2017, 02:17 AM   #140
67ChevyRedneck
Just realized I don't have any recent pics with the caps and rings on the wheels.
A few of the incredibly rare 4" snowfall we got back in early January. One from getting the Christmas Tree from a couple hours away in NC in November, and one from Sept/Oct for a local show where I somehow placed in the truck section.
Jesse James
Project "On a Dime"
Old 02-06-2017, 08:21 AM   #141
flashed
Jesse ,it was nice to finally meet you the other day ,blew the leaves out and still did not find our sockets ,will keep looking .
flashed is offline   Reply With Quote
Old 02-06-2017, 11:32 AM   #142
67ChevyRedneck
Same here! You'll find them both in the spring with the lawnmower. I'd mow that area with the chute facing the field for a while!
Jesse James
Project "On a Dime"
Old 02-06-2017, 07:52 PM   #143
rusty76
rusty76's Avatar
Cool pics.
My build thread
Crossmembers CC
Old 02-06-2017, 08:58 PM   #144
GR8-68
GR8-68's Avatar
This is one cool shop truck, was glad to get the opportunity to check it out.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 02-07-2017, 10:26 PM   #145
67ChevyRedneck
Originally Posted by rusty76 View Post
Cool pics.
Thanks! I've taken up photography as kind of a side hobby. I like taking pics, but I have more fun editing them. Since everything is digital now, after you buy a good camera and a couple lenses, you don't need anything else!
Thanks man! Old girl ran great up and back! Now get yours done!
Jesse James
Project "On a Dime"
Old 02-08-2017, 08:50 AM   #146
GR8-68
GR8-68's Avatar
I also enjoy photography although I have not picked up my camera in several months, I need to start shooting again.
Larry
"Project 68"
paypal.me/ldgrant
Old 02-12-2017, 01:06 AM   #147
67ChevyRedneck
So, I had one hell of a mess on my hands and my garage was absolutely unusable in it's current state. I had to kick my 67 bird outside. It's under a good quality cover until I can work on it in 10 years :P
Jesse James
Project "On a Dime"
Old 02-12-2017, 01:11 AM   #148
67ChevyRedneck
I added cabinets, built a bench, painted it blue and hung up a ton of signs I've been collecting for years. The area that's still white is because I need to have an electrician add a sub panel so I can add a couple more outlets and a 220 plug for my compressor.
Jesse James
Project "On a Dime"
Old 02-12-2017, 01:14 AM   #149
67ChevyRedneck
I'm still cleaning it out and up, but I saw the weather was going to be in the 70s this weekend and I just couldn't pass up a weekend to finally work on the truck bed. I did clean up a little between welding/grinding sessions.
Jesse James
Project "On a Dime"
Old 02-12-2017, 01:15 AM   #150
67ChevyRedneck
So, I bought this bed floor like 6 or 7 years ago. It's STUPID nice. Because it was a longbed no one wanted it. I think I gave like $150 for it.
Jesse James
Project "On a Dime"
