Old 12-03-2014, 09:46 PM   #126
68basket
Re: 1960 chevy parkwood wagon!
I got 3 of my 4 level sensors installed, these are the rears and happy how they turned out.
68basket is offline   Reply With Quote
Old 12-03-2014, 09:48 PM   #127
68basket
This is the left front. I am not 100% happy with it cause i wanted to mount it on the upper control arm, but could not find a good place to get the correct amount of travel. I used a weld on bracket and hung it below the frame behind the lower control arm. Has ok travel and will work.
Old 12-03-2014, 10:09 PM   #128
Crash'd Artwerks
Originally Posted by 68basket View Post
Loving that 60 parkwood posted above, I know i have seen a writeup on it somewhere also. Looks like my rear end may tuck lugs when laid out?? Are you bagged guys running bump stops? I dont have any right now and was wondering if i should set some up.
Also i always wonder what the person looks like associated with a screen name, so here is a pic of me after getting some new glasses this last weekend. I was driving my beater Mercedes wagon.
I don't have any bump stops setup on my car.
Here's me and my mini-me that I took a few days ago.
Crash'd Artwerks is offline   Reply With Quote
Old 12-03-2014, 10:18 PM   #129
68basket
looks like my driveshaft may hit the floor pan. I could run rear bump stops to keep it away or section the floor out and let the shaft go higher. Is there a reason to do or not do either one?
Old 12-03-2014, 10:19 PM   #130
68basket
awesome! Looks just like you.
Old 12-03-2014, 10:22 PM   #131
Crash'd Artwerks
I cut a section of the top of the frame out, and I am planning on raising the small hump at the very rear most part of the floor pan, where it goes under the seat, to make sure the driveshaft doesn't hit it.
When my dad and I built the driveshaft, I also put a slip yoke in the rear driveshaft like the 4 wheel drive guys use, so the driveshaft wouldn't be trying to move forward and backward and beat out my carrier bearing.
Old 12-03-2014, 10:23 PM   #132
Crash'd Artwerks
Haha, thanks. Yeah, she's always been my little mini-me (only way prettier). 😃
Old 12-03-2014, 10:25 PM   #133
68basket
hard to see in this pic but this is a whole new dirveshaft with cpp carrier bearing setup and slip yolk in the rear shaft, so i am set on that. I am thinking about cutting out the floor pan section you are talking about. I need to put the shaft in there to see how much room i need.
Old 12-03-2014, 10:46 PM   #134
Crash'd Artwerks
As much work as I've done to my car (and you have done to yours), I look at it like its a no-brainer to go ahead and cut the floor and raise the tunnel as a "just-in-case" measure. I don't want to get all of the interior redone and start driving the car and have problems and have to pull all of the rear upholstery out and redo it.
Old 12-09-2014, 10:23 AM   #135
68basket
Kept my oldest up past his bed time last night to help put the engine back together. New camshaft, lifters, timing set, valve spring kit and seals, all new gaskets. valves are not adjusted. cleaning the rest of the parts to go on it now.
Old 12-09-2014, 10:27 AM   #136
yahoos
yahoos's Avatar
Heck ya keep it up!
yeah buddy
yahoos is offline   Reply With Quote
Old 12-16-2014, 09:57 PM   #137
68basket
I almost had this 2002 firebird from an auction that i go to. But it went for a little too much. WOuld have been a perfect ls1 swap car. Found this wagon and sweet c10 in the newest Mac tools calendar !!
Old 12-16-2014, 09:58 PM   #138
68basket
Still plugging away working on the engine. Assembled and painted.
Old 12-16-2014, 09:59 PM   #139
Crash'd Artwerks
That wagon belongs to a guy named Cody Walls. Super cool guy and amazingly talented. I followed the build of that car on the HAMB and Instagram. There's some really kick ass work that has been put into that car!
Old 12-16-2014, 09:59 PM   #140
68basket
High heat paint on the manifolds. Mocking up the brackets with ac compressor, alternator, and power steering pump. It all fits well. Pulling brackets back off for paint.
Old 12-16-2014, 10:12 PM   #141
Crash'd Artwerks
That contrast looks great!
Old 12-16-2014, 11:54 PM   #142
68basket
Just registered for the Power Tour 2015. Booked all hotel rooms. I better get my ass in gear and make this car run!!
Old 12-16-2014, 11:55 PM   #143
68basket
Thanks! I do think the engine looks pretty good. I just hope it runs well and reliable.
Old 12-17-2014, 12:00 AM   #144
yahoos
yahoos's Avatar
sexy!
yeah buddy
Old 12-17-2014, 11:57 PM   #145
68basket
Small progress tonight. I hate it when i feel like i didnt get much done. But all the little things will add up to one day the car will be on the ground and running. Stabbed the distributor, and spent forever routing the plug wires. Installed and shimmed a brand new starter.
Old 12-18-2014, 11:26 AM   #146
RDrancher
RDrancher's Avatar
Looks great! I may have missed it, but did you decide on a cam?
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 12-18-2014, 11:36 AM   #147
68basket
Yes. I went with the summit brand k1102 camshaft kit. It's basically a copy of the edelbrock performer cam just cheaper. I was trying to save a few bucks on the engine. All I really wanted was a little rumble at idle and a good drivable power band
Old 12-19-2014, 10:18 AM   #148
68basket
I went by a local upholstry shop last night as the owner stayed late for me to come check it out. He moved his schedule around to get me an appointment on April 20 to do the complete interior!!!! I can not wait. He said it will take 2 weeks. That gives me plenty of time to get ready for the Beatersville show just a few miles from my house on memorial day weekend. If any of you are close enough to Louisville KY its well worth coming to the show. This is the shop that will be doing the work www.sewntight.com we looked at a lot of samples, should end up being turquoise vinyl and houndstooth inserts.
Old 12-19-2014, 12:31 PM   #149
Advanced Design
Advanced Design's Avatar
Cool, I checked out the link and he does nice work. Should look really good!
Advanced Design is offline   Reply With Quote
Old 12-19-2014, 03:02 PM   #150
yahoos
yahoos's Avatar
Man Love the engine!
yeah buddy
accuair, bagged, elevel, parkwood, wagon
