Old 07-24-2015, 01:24 AM   #126
tinydb84
tinydb84's Avatar
Re: Used Parts Build
I am also pushing the engine back further. I am going to clearance the firewall a hair. Bad picture but check out where the first cylinder is compared to the front wheel center line. In total the engine is back 3 inches from the stock position.
David
Instagram: myfabguy
Old 07-24-2015, 02:58 PM   #127
77K10Silverado
77K10Silverado's Avatar
Gracious! LS fever!!
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 07-25-2015, 03:05 PM   #128
Hankster
Hankster's Avatar
Engine looks good sitting in there,
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 08-02-2015, 11:57 PM   #129
tinydb84
tinydb84's Avatar
LS swap everything! (well eventually...)
Thank you sir.
David
Instagram: myfabguy
Old 08-02-2015, 11:57 PM   #130
tinydb84
tinydb84's Avatar
Started on my trans crossmember. I am thinking I might try to make something kinda like the Porterbuilt center section (but poorer and uglier....we'll see where that ends up).
Was going to use the old mount but later decided against it.
I always jig everything perfect and forget to prep the area to weld first...
Since I was looking at the "mig like tig" thread earlier
Dropped some weld into the channel of the backside
So far
Cut my next piece of tube and realized the company sent me 1.75'' end pieces so thats as far as I am going to get today.
David
Instagram: myfabguy
Old 08-03-2015, 10:04 AM   #131
Justin@EntropyRad
Justin@EntropyRad's Avatar
coming along nicely
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 08-09-2015, 11:36 PM   #132
tinydb84
tinydb84's Avatar
Originally Posted by Justin@EntropyRad View Post
coming along nicely
Thank you sir.
Finished the crossmember for now. Ordered more tabs and bent tube to start the frame stiffener.
David
Instagram: myfabguy
Old 08-09-2015, 11:38 PM   #133
tinydb84
tinydb84's Avatar
Started drilling the holes for my crossmember and decided to work on something else (I hate drilling holes).
Decided to cut my tunnel up to use it to create the new tunnel.
Ended up moving it back and triming the front part back then made a filler plate in the center. Looks like I am only adding about an inch or so in height and most of it in the center.
Tried to make a filler piece that matches the original floor.
Where I left it for now
David
Instagram: myfabguy
Old 08-11-2015, 12:30 AM   #134
tinydb84
tinydb84's Avatar
More metal shaping...I get why the professionals charge so much!
Got low on gas so I pulled my tank to exchange it while I'm at work tomorrow since the welding shop is a couple blocks away
Sooooo since the tank was off, I used it to make some bends. I really want a shrinker/stretcher!
But what do I do with it now....jk
David
Instagram: myfabguy
Old 08-11-2015, 12:30 AM   #135
tinydb84
tinydb84's Avatar
Then I saw this....
So I bought one for my 66. Didn't need it now but couldn't pass up the deal...
David
Instagram: myfabguy
Old 08-14-2015, 02:15 AM   #136
tinydb84
tinydb84's Avatar
I took today off just to work on my truck (I never take days off). Thought I would have got more done....
Once I did one side the second took half the time
I was running stringers and totally forgot about stitch welding. This looks much better than my stringers. Too bad I didnt think of it until I was almost done...
All done with the rear. I will start on the front this weekend. More curves....yay...
David
Instagram: myfabguy
Old 08-16-2015, 10:20 PM   #137
tinydb84
tinydb84's Avatar
Wasted a bunch of time trying to make one piece to fit the front of the tunnel before just patching it. Working extra slow...
Got my front bars in. Here is what I am thinking of doing.
David
Instagram: myfabguy
Old 08-23-2015, 10:29 PM   #138
tinydb84
tinydb84's Avatar
Look at this monstrosity!
Hey at least it is done! Now I am going to strip the floors (top and bottom) and epoxy everything...Next weekend lol
David
Instagram: myfabguy
Old 08-23-2015, 10:30 PM   #139
tinydb84
tinydb84's Avatar
Started my welding class. Got about 10 of these:
and all the students work:
There are 15 MIG's, 4 O/A, 10 Stick, and a ton of metal fab stuff.
Didnt get a pic of the rest of the shop but check out their machine shop class...
I am going to take that next semester.
Then I bought this so I can practice between classes:
David
Instagram: myfabguy
Old 08-31-2015, 12:37 AM   #140
tinydb84
tinydb84's Avatar
Finished welding my floor, stripped it, and painted it.
It got dark before I could paint so I fish plated my notches since I hadnt got around to doing it. I had a bunch of 1/4'' steel...a bit over kill but whatever. Since I already was mixing paint I figured I'd paint them since I work slower than rust....
David
Instagram: myfabguy
Old 09-05-2015, 11:24 PM   #141
tinydb84
tinydb84's Avatar
Not much of a pic but it feels great to actually put something back together. The carpet almost fits. Need about an inch or so on the side but it is good enough to use the original one for now.
David
Instagram: myfabguy
Old 09-08-2015, 01:22 AM   #142
tinydb84
tinydb84's Avatar
No cool pictures but since it was 95 degrees out today I figured I'd do more dirty work.
Not perfect but I stripped the bottom of my cab and painted it in epoxy. The hvlp gun didnt like the angles so I am sure it is spotty and has runs but for the underside of my cab I am fine with it.
David
Instagram: myfabguy
Old 10-04-2015, 12:35 AM   #143
tinydb84
tinydb84's Avatar
Started to redo my motor mounts. I didnt want to build a bridge to the upper control arm and make it look half assed.
I have been having a ton of problems with my Alphatig. I just sent a request to return it through Amazon. All I can tell is that there is a gas problem. Tried all kinds of thing but it randomly has a flow or contamination issue...
Then....
Ended up using my mig to finish it. Really pissed that I spent all that time perping everything to then mig it....
David
Instagram: myfabguy
Old 10-12-2015, 12:18 AM   #144
tinydb84
tinydb84's Avatar
Did a bit of work on my mounts. Will probably add a bit to the bottom just for looks.
David
Instagram: myfabguy
Old 10-13-2015, 02:09 AM   #145
tinydb84
tinydb84's Avatar
Finished my motor mounts. Had to move over my steering bracket from my last mounts:
Was wondering if I could still mig. Havent done it in so long.
Just need to paint them.
David
Instagram: myfabguy
Old 10-13-2015, 11:30 AM   #146
slammed427
slammed427's Avatar
Love the work! I'll be following along.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 10-18-2015, 02:56 AM   #147
tinydb84
tinydb84's Avatar
Thanks. Hopefully I can pick up the pace a bit.
David
Instagram: myfabguy
Old 10-18-2015, 02:57 AM   #148
tinydb84
tinydb84's Avatar
Painting everything today. The gun broke in the middle so ignore the runs in the paint...
David
Instagram: myfabguy
Old 11-18-2015, 01:24 PM   #149
tinydb84
tinydb84's Avatar
I didn't really like the weld I did on the bottom of my SFBD. It didn't look up to my standard but I didn't fell comfortable just grinding it smooth. So I came up with this:
and welded them to the frame:
Did three of them on each side. Should be solid as can be.
Then I didn't like the por15 on there. It was starting to peal in some areas (and rock hard in others). It seemed like if you hit it just right it would come off. So instead of worrying about it I stripped it all off and shot it with epoxy instead.
Going to toss the engine and trans back in. Going to change the trans mount a bit (because I don't feel like drilling that many holes). Then start on the rear.
David
Instagram: myfabguy
Old 11-30-2015, 10:32 PM   #150
tinydb84
tinydb84's Avatar
Engine in and clip on!
Gotta make an adjustment on the trans mount and pull the bed next week I hope.
David
Instagram: myfabguy
