Old 11-15-2016, 11:21 AM   #126
Flysocal
Re: 1949 Chevy 3100 Build Thread
Originally Posted by iowaboynca View Post
so what's that radiator/fan combo? It looks good.
Bought off eBay the seller handle is dissrad. http://m.ebay.com/itm/1947-1954-CHEV...257Ciid%253A10
Flysocal is offline   Reply With Quote
Old 11-15-2016, 11:54 AM   #127
iowaboynca
iowaboynca's Avatar
Thanks for the reply! I'm getting close to that stage on my build and i'll give them a look.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 11-15-2016, 09:51 PM   #128
e015475
e015475's Avatar
You need the later Trailblazer waterpump. It looks like this-
e015475 is offline   Reply With Quote
Old 11-16-2016, 01:46 AM   #129
Flysocal
Yep looks like the trailblazer water pump would have been the right choice. I'm gonna try and make this work. I cut a couple inches off it and should have enough room now. Got new joints in the mail today and steering is better. Starting to mock up front suspension.
Old 11-17-2016, 12:30 AM   #130
51Chevy3100
Coming along nicely!
1951 3100 Patina "Under Construction"
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=636116
87 V30 1 ton Mud Truck
51Chevy3100 is offline   Reply With Quote
Old 11-19-2016, 02:30 AM   #131
Flysocal
Worked on the rear suspension today. Scott's hotrods 4 bar with panhard. Spent a good bit of time getting the rear axle position at 116" wheelbase. It's a Moser 9" housing. Shocks are set at 10 degrees. Pinion angle is set 2 degrees up on the housing and 2 down on the engine. Everything looks good so far my only concern is the shock crossmember is 2.5" from housing and shock travel is 3" so I'm gonna have to modify the crossmember somehow. Everything is tacked into place for now.
Old 11-19-2016, 02:34 AM   #132
Flysocal
Old 11-19-2016, 08:51 AM   #133
Advanced Design
Advanced Design's Avatar
Nice work getting the rear dialed in and positioned. Kinda like juggling? Or did it go pretty smooth?
Advanced Design is offline   Reply With Quote
Old 11-19-2016, 12:26 PM   #134
solidaxel
solidaxel's Avatar
Does 116" wheel base put the rear tire in the center of the wheel opening?
We ended up using a 15" rear shock and moving the shock mount up higher to get more travel in the rear axle
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-19-2016, 01:37 PM   #135
Flysocal
Once I welded my axle in place everything went smooth. Not so much prior to that
Old 11-19-2016, 01:46 PM   #136
Flysocal
With my no limit tank in place there isn't any more room to bring the axle back any further than 116.5". I wanted some space between the coilover and tank so I settled on exactly 116" and will hope for the best. Where that puts the wheel I have no idea. I don't have a bed yet so can't mock it up. As far as the shocks they are 300lbs and have 3" of compression. Thats what Scotts hotrods sold me as part of my kit. Sure doesn't seem like much travel in the rear for a daily driver but I have not idea.
Old 11-23-2016, 10:13 PM   #137
Possmguts
Possmguts's Avatar
Boy... you've been getting a lot done since I last checked. Looking good! I only wonder about having the 2 U-joints in that steering shaft... Is that gonna work right?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 11-23-2016, 10:18 PM   #138
joedoh
joedoh's Avatar
I count three, there is one under the motor mount.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 11-23-2016, 11:03 PM   #139
youngrodder
youngrodder's Avatar
Looks good..I just finished mocking up my steering. I too used 3 universal joints. Mine moves smoothly but I was concerned with the angle but mine looks very close to yours.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-24-2016, 03:21 AM   #140
Flysocal
Three joints one is a vibration reducer. I built this according to borgeson guidelines with a support so nothing binds. It's smooth as silk no problems.
Old 11-29-2016, 11:13 PM   #141
Flysocal
Marc
You got a build thread going? Would be cool to see what you got goin on
Old 11-29-2016, 11:22 PM   #142
Flysocal
Switched gears a bit today. I love the utility I get out of my 08 ranger. This truck will replace the Ranger as my daily driver so I'm trying to keep it simple and driver friendly. Little things like a modern gas door is one of those simple details. Cut from a 99 blazer I grafted it into my fender. I wasn't happy to cut a hole in a perfectly good OEM fender but it's all good.
Old 11-29-2016, 11:25 PM   #143
Flysocal
All done
Old 12-06-2016, 09:02 PM   #144
Flysocal
Got the rear suspension crossmember figured out. I used a transmission crossmember and welded shock bungs in place. It has much better clearance. Also got drive shaft loop tacked in place.
Old 12-18-2016, 11:49 PM   #145
Flysocal
I decided to go with a new engine and tranny. Got this 5.3 from summit a few days ago. It just doesn't make sense to run a junkyard motor/tranny since everything else will be new. Got a great deal just a bit more than the going rate for a rebuild.
Old 12-18-2016, 11:56 PM   #146
Flysocal
Got the rear suspension squared away. Got a coilover spanning wrench to remove springs then worked my suspension through full range of motion to check for smoothness and binding. All good! I'm ready for a bed now just waiting for the next mar-k sale
Old 12-19-2016, 01:34 AM   #147
Curt - TN
I did not know you could get a 5.3 from them, what price range are they going for and is that an iron block?
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 12-20-2016, 01:07 PM   #148
Flysocal
Summit is treating me well. Good prices (price match) and fast shipping. Return label in each box makes returns easy. I was surprised to find the stock iron block 99+ vintage for $3000 shipped when a rebuild runs $2200 around here so it's a no brainer. If I'm not happy with the power I can cam it down the road. I expect 275hp to be just fine in a 3000 lb daily driver.
Old 12-20-2016, 01:11 PM   #149
Curt - TN
That is pretty sweet, did it come just as you have it in the picture with the covers and water pump?
Curt
Brentwood TN
1957 GMC 100
Old 12-20-2016, 01:41 PM   #150
Flysocal
Yes it did. From steam tube to oil pan. Even had spark plugs. Looks like they are out of stock at the moment.
