Old 07-17-2017, 04:15 PM   #126
cooperhw
cooperhw's Avatar
Re: 78 downlow-littledough
Originally Posted by Derek@AccuAir View Post
I saw that truck for the first time when Crawdadfox owned it, and honestly that truck is the reason I went out and bought my 73. If my truck didn't have clean factory paint, it would already have been repainted this color combo. I absolutely think you should run that color combo!
Agreed. I really like that it looks somewhat old school and understated, but still has just the right amount of pop in the color contrast. As far as I can tell from research a "buckskin tan" from 78 is close in color. I will buy a small amount for a spray out.
Originally Posted by daddyjeep View Post
That color combo seems to suit your build for some reason. Maybe because it is close to the color it started out with.
Yeah, I think the artist really knocked that rendering out of the park. I did one (68 one ton dually) about a year ago that was close, but no cigar. This brown has a lot more red in it and looks cool.
My wife mentioned that "it looks like the same color". To which I added, no way, my original color was way more yellow.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-17-2017, 06:54 PM   #127
rusty76
rusty76's Avatar
I've seen a similar color combo before and I like it. I like two tones with a white on top of the cab. Gives them a classic look.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-17-2017, 10:09 PM   #128
cooperhw
cooperhw's Avatar
I totally agree. I did a 1 ton dually i finished & sold last March. I did it in a similar color combo but the tan was much lighter. I like this darker ram a while lot more.
Later,
Wayne
Old 07-18-2017, 10:52 AM   #129
cooperhw
cooperhw's Avatar
Here's a pic of my truck I did (and sold) last year. Too light n the tan for sure.
I totally love the darker tan against the white. It may even be darker than the buckskin color from 1978?
Later,
Wayne
Old 07-19-2017, 08:20 PM   #130
rusty76
rusty76's Avatar
I have to say that truck looks white. Ha. But man that is one kool dually.
My build thread
Crossmembers CC
Old 07-19-2017, 08:25 PM   #131
cooperhw
cooperhw's Avatar
It's actually a light tan with white cap.
I have a build thread in the 67-72 projects & build section called Meet Homer. Check it out. I shortened it 60 inches & widened the bed 6 inches.
Later,
Wayne
Old 07-20-2017, 04:22 PM   #132
rusty76
rusty76's Avatar
I'll check it out.
My build thread
Crossmembers CC
Old 08-06-2017, 10:35 PM   #133
cooperhw
cooperhw's Avatar
Been slowly moving forward with the fenders & doors. Got them in final prime. Got the cab in first coat of 2k high build.
Later,
Wayne
Old 08-06-2017, 10:46 PM   #134
tinydb84
tinydb84's Avatar
Looks good
David
Instagram: myfabguy
Old 08-07-2017, 12:04 AM   #135
cooperhw
cooperhw's Avatar
Originally Posted by tinydb84 View Post
Looks good
Thanks.
Later,
Wayne
Old 08-07-2017, 05:45 PM   #136
rusty76
rusty76's Avatar
Nice pic.
My build thread
Crossmembers CC
Old 08-14-2017, 10:59 PM   #137
swamp rat
swamp rat's Avatar
Funny, your moving slowly forward is sure faster than my moving forward, the truck is looking great!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-20-2017, 07:32 PM   #138
cooperhw
cooperhw's Avatar
Nice pic.
thanks.
Later,
Wayne
Old 08-20-2017, 07:42 PM   #139
cooperhw
cooperhw's Avatar
Thanks. I appreciate it. Yeah, I sometimes think it's going slow when I am grinding through the bodywork and priming, but I gotta sit back and remind myself, I just bought this truck in mid April of this year. Should be in color within the next month. Hopefully finished by years end. Goals, anyhow, sometimes those get moved but I like to have target dates in mind. It helps me plod along thru this heat.
I did get some progress made though.
Finished block sanding the cab, doors, and front fenders so I could marry em all back up and start dialing in my hood. one I had was junk and couldn't find a decent one so I bought this aftermarket hood off craigs yesterday. took it out of the trailer this morning and within 3 hours had it hung, centered, stripped off the primer coating, and levelled across the fender to hood. was then able to do a little more filler work away from that leading edge and bury it all in epoxy primer. gaps look great.
Later,
Wayne
Old 08-20-2017, 07:45 PM   #140
cooperhw
cooperhw's Avatar
little levelling and gap work at the fender to hood area. come out good.
Later,
Wayne
Old 08-22-2017, 06:54 PM   #141
rusty76
rusty76's Avatar
Nice work. What are using to set the gaps?
My build thread
Crossmembers CC
Old 08-22-2017, 07:44 PM   #142
tinydb84
tinydb84's Avatar
Working fast! What will the final color be?
David
Instagram: myfabguy
Old 08-23-2017, 11:55 AM   #143
cooperhw
cooperhw's Avatar
I use the yard sale signs you get at the local hardware store. They are the perfect size for tight gaps and plastic filler will not stick to it. First use anyways. Must have some kind of a releasing agent on it from when they make the stuff. I force a little into the gap on each side of the board and leave it a little high on each side too. After about 10 minutes just pull straight up and it comes right out. These edges will never be in contact with anything so they should never chip out.
Later,
Wayne
Old 08-23-2017, 12:00 PM   #144
cooperhw
cooperhw's Avatar
Thanks. I just think of it as a chess match and try to keep advancing the pieces a little each weekend.
Final color (already purchased) will be PPG#2829 Buckskin" with a white insert and roof. I am copying "leisure suit" in color selection. I love the combo.
Here is his rendering of the truck he is currently building. Hope he doesn't mind me sharing, but ,
Later,
Wayne
Old 08-23-2017, 12:14 PM   #145
flashed
Love that color combo.
flashed is offline   Reply With Quote
Old 08-23-2017, 12:37 PM   #146
tinydb84
tinydb84's Avatar
I like the color combo. Should look real nice.
David
Instagram: myfabguy
Old 08-23-2017, 05:37 PM   #147
cooperhw
cooperhw's Avatar
Thanks Flashed. Me too. Trying to decide if I am gonna paint the trim on or buy poke holes. Probably paint.
Later,
Wayne
Old 08-23-2017, 05:38 PM   #148
cooperhw
cooperhw's Avatar
Cool. Hope it turns put half as nice as his rendering.
Later,
Wayne
Old 08-27-2017, 04:47 PM   #149
cooperhw
cooperhw's Avatar
Finally got the inside of the cab ready so I shot it in color today. Really like the color. Gonna pop against that white outside.
Later,
Wayne
Old 08-27-2017, 11:09 PM   #150
oldman3
oldman3's Avatar
Very nice...Jim
oldman3 is offline   Reply With Quote
