Old 04-29-2021, 02:37 PM   #126
WilliamFd55
Re: His name is "George" 84' C10
Originally Posted by SCOTI View Post
Looks 'complicatingly' good. I bet wrapping was fun as well.
Ha, the turbo side with the waste gates was tricky for sure.
WilliamFd55 is offline   Reply With Quote
Old 05-03-2021, 12:48 PM   #127
WilliamFd55
Picked up the last big ticket item of the build (Driveshaft). They did a hybrid setup, steel front/ aluminum rear. Got it installed and while I was under there, reworked the fuel delivery lines. Got rid of that weird loop.
Old 05-03-2021, 12:54 PM   #128
tinydb84
tinydb84's Avatar
Whats the purpose of half and half? I thought about going aluminum but the driveshaft shop told me steel would be fine for my needs and cheaper.
David
Instagram: myfabguy
Old 05-03-2021, 01:45 PM   #129
SCOTI
SCOTI's Avatar
No way to remove those restrictive fittings? I've read where those hard/fabbed 90° fittings are the equivalent of adding >10' of additional line per fitting.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-03-2021, 02:31 PM   #130
WilliamFd55
I wanted to go all aluminum, just like the look of it. Fabricator said that the front section to the center bearing was basically an extension of the trans, so steel would be fine. He said the rear section being aluminum would handle torque better.
Old 05-03-2021, 02:42 PM   #131
WilliamFd55
I couldn't figure out a way to get the shut off fitting and first filter before the pump while keeping everything low, without all the crazy loops.
Old 05-18-2021, 09:38 AM   #132
WilliamFd55
Been working on a way to get inner fenders in while keeping it semi stock looking. Going to be a lot of cutting/ metalwork around turbo and back by the firewall, but this is where I have the most fun. So lets cut up some new fenders! Lap welds is where its at with this thin metal. Ended up raising the mounts about 2-1/2".
Old 05-18-2021, 09:42 AM   #133
daddyjeep
daddyjeep's Avatar
Looks like a good time. Do you have one of them fancy tools to form the lap joints?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-18-2021, 09:49 AM   #134
WilliamFd55
Nothing too fancy "Harbor Freight" punch/ Flange tool. Really got in those tight spaces easily. Think it was around $35.
Old 05-20-2021, 10:26 AM   #135
daddyjeep
daddyjeep's Avatar
yeah.... that's the one I was talking about. It appears to work good.
04 1500 crew cab
Old 05-24-2021, 09:09 AM   #136
WilliamFd55
Progress on the inner fenders. Ended up with around an 1-1/2" bump out against the firewall. Also added 1/4" Round bar to the inner lip of the wheel well to give some support and mimic a rolled edge. A little finish work and this side is a wrap. Plan on installing a rubber skirt to fill in the front to the radiator support. Passenger side is going to be a fun! Working on the exhaust now. Want to get all the obstructions in place before I start that side. Will most likely template this inner fender. Its going to be like Tetris.
Old 06-03-2021, 10:26 AM   #137
WilliamFd55
One fender complete and installed. Fresh paint on the rad support and inner fender. Closed up some holes on the fender with some dimpled plates like I did on the last. Decided to upgrade the headlights with a retro kit. New lights do not fit in the OEM housings. Had to make them a touch bigger.
Old 06-03-2021, 10:29 AM   #138
WilliamFd55
Rad support is aftermarket, so nothing really lines up. All the headlight adjusters did not fit. Ended up using ones off a Toyota and they worked perfectly.
Old 06-11-2021, 09:06 AM   #139
WilliamFd55
Exhaust is a wrap, literally. 5" straight down and out the side. Exhaust tip is also kind of obnoxious 7". Pics have it sticking way out the side, but it will not be that way when complete. Going to do some metal work to form around it instead of those stainless rings or stars. Might bump the fender out 1-1/2".
Old 06-11-2021, 09:11 AM   #140
WilliamFd55
Also got the radiator mounted. Was able to utilize the OEM mount with a little modification and yes.......More dimple dies.
Old 06-11-2021, 02:23 PM   #141
lunatic1968
very nice work.... subscribed .
lunatic1968 is offline   Reply With Quote
Old 06-11-2021, 03:23 PM   #142
WilliamFd55
Thank you. Honestly can't wait to see your truck complete. One bad machine!
Old 06-14-2021, 12:01 PM   #143
lunatic1968
Thanks a ton. I appreciate it. I guess ill get to work and stop goofing off, ha.
Old 06-14-2021, 01:52 PM   #144
WilliamFd55
Ha, right. Get to it!
Old 06-14-2021, 01:59 PM   #145
WilliamFd55
Ok, Ok. It looks a little crazy. The pictures make it look like I glued a pumpkin to the side of the fender, but it really only sticks out around 2" towards the front. Since no one wanted the old fenders I decided to put them to use. Started by stealing a section and fanning it out. Then used a ring roller to get the diameter needed and a true circle. Once the tip was mocked in there, it was all welding from there. Time to mud.....
Old 06-14-2021, 02:01 PM   #146
WilliamFd55
Some more pics......
Old 06-16-2021, 08:44 AM   #147
daddyjeep
daddyjeep's Avatar
I didn't see that coming. I am anxious to see it on the truck now.
04 1500 crew cab
Old 06-23-2021, 08:38 AM   #148
WilliamFd55
It's going to be like a "Move that bus" reveal, hahaha. Won't be able to fully see it till the truck is out of the garage. I guarantee it will be different for sure.
Old 06-23-2021, 08:45 AM   #149
WilliamFd55
While I'm doing the body work, did some multitasking. Crew at Autozone were nice enough to let be go thorough all the hoses in the back with a template I made out of wire. Got all the hoses set and ran the piping for the intercooler. Was a little wobbly where the blow off is, so I made a little bracket to stiffen it up. Also made a cheap bead tool. Kinda need a He-Man grip, but it worked out pretty well.
Old 06-23-2021, 08:47 AM   #150
WilliamFd55
Rounding the homestretch!
