Old 04-02-2013, 03:32 PM   #1551
6lcummins
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by Ackattack View Post
Keep in mind, for a diesel, you don't want the return line just dumping into the top of the tank, you want to run a hose down into the existing fuel to avoid aeration.
Unless you have a good fuel system that traps and removes the entrained air in the fuel as sloshing entrains oxygen/air in the fuel so either way the oxygen/air is in the fuel.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 04-02-2013, 06:41 PM   #1552
watahyahknow
watahyahknow's Avatar
there might be some leaking happening with the return so high up in the tank and the lack of a breatinghole might put the tank under vacuum as the diesel gets used , the second idea about the return intoo the fuelsender might be a better idea
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-03-2013, 05:18 PM   #1553
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I've had it this exact way on my 95 F-350 for 2 1/2 years with no problem. It runs down a tube and into the tank from the very top. Factory ford engineered tank too.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-10-2013, 01:49 AM   #1554
Mustard72
Mustard72's Avatar
So do you Ryans end up with the tops of the GN hitches about 1" above the tops of the frames? I did a quick measurement on Old Mustard tonight and it looks like it would need to be 1" to be flush with the top of the bed floor. Just wanted to see if that's what you guys used, too. Looks like right around 1" from your pics. Mine's going in a wood bed C20.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 04-10-2013, 02:11 AM   #1555
Dieselwrencher
I had Ryan measure his for me and he said 3/4". That is the distance from the short bed supports to the frame on steel bed trucks. I measured a half ton steel bed truck I have here and the floor is 1", and the support does hang down 1/4". Hope this helps.
Ryan
Old 04-10-2013, 07:53 AM   #1556
ryanroo
ryanroo's Avatar
the hat channels that run under the steel floor on both the beds i measured were 3/4" and the bed floor ribs are ~1/4" so from the top of the floor ribs to the frame is about 1 inch. for me to make the hitch work, so the top of the plate was at the bottom of the floor ribs it was spaced up 3/4" and the center circle where the ball is is set up the 1/4" so it sits even with the top of the ribs. since the wood on a wood bed is sitting on the frame, you will have to cut several of the boards in half at the hitch and you will be able to see the entire hitch plate.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-12-2013, 01:38 PM   #1557
Mustard72
Mustard72's Avatar
Cool. Thanks. Yeah, I figured I'd have to support the boards where they need to be cut for the hitch.
Thanks again. I'm done pirating the thread now.
Nick
Old 04-15-2013, 03:39 PM   #1558
Dieselwrencher
Nick, it isn't an issue.
Ryan
Old 04-16-2013, 10:20 PM   #1559
Luther Grimace
Luther Grimace's Avatar
I like the gooseneck hitch. What did the top part you welded in come off of? I wouldn't worry about it breaking!
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 04-16-2013, 10:26 PM   #1560
jbclassix
Junk Yartist
jbclassix's Avatar
Ryan's new trailer.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-16-2013, 10:30 PM   #1561
6BT 56
6BT 56's Avatar
Originally Posted by jbclassix View Post
Ryan's new trailer.
I guess no matter how big the truck ....... When it breaks you will eventually need a bigger truck to get it home !
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 04-17-2013, 01:08 AM   #1562
Dieselwrencher
I doubt I could afford the air in the tires on that beast!
Ryan
Old 04-17-2013, 01:16 AM   #1563
jbclassix
Junk Yartist
jbclassix's Avatar
Yours and Ryan's goose neck builds could handle the stress I am sure.
-Jeremy
Rebuilding an NP205
Old 04-17-2013, 02:01 PM   #1564
Dieselwrencher
Ryan
Old 04-17-2013, 02:01 PM   #1565
Dieselwrencher
Thanks. It was a B&W from a 02 Dodge and I just unbolted the center section and junked the rest.
Ryan
Old 04-30-2013, 06:42 PM   #1566
Dieselwrencher
I went out to the shop and look what the wind blew off my truck.
I'm going to start boxing the frame tomorrow. I'll work on this until my parts show up for the wife's excursion, then it's go time on it until it's done.
Ryan
Old 04-30-2013, 06:47 PM   #1567
jbclassix
Junk Yartist
jbclassix's Avatar
Originally Posted by Dieselwrencher View Post
.....I'm going to start boxing the frame tomorrow. I'll work on this until my parts show up for the wife's excursion, then it's go time on it until it's done.
Cummins excursion?
-Jeremy
Rebuilding an NP205
Old 04-30-2013, 07:00 PM   #1568
6BT 56
6BT 56's Avatar
Excursion ??? Do tell. My wife needs a diesel family hauler as well. what you up to ?
Old 04-30-2013, 07:26 PM   #1569
6lcummins
Cummins excursion?
Would there be any other way to have it???
I'm pretty sure we are taking the VE24V out of the 76 and putting into the Excusion along with a 47RH. Both will be completely "stock" though. And possibly mate it up to my DLD I have laying around from my 96.
"STOCK"
ASSEMBLY THREAD
Old 04-30-2013, 08:01 PM   #1570
6BT 56
6BT 56's Avatar
I confused. Your building a cummins excursion as well. ? Ryan is building one and your helping ? Not trying to hyjack the longhorn thread but this has me interested. We need a excursion thread . Even if it has to go in alternate tinkerings !!!!
Old 04-30-2013, 08:24 PM   #1571
ryanroo
ryanroo's Avatar
Nick is helping Ryan
Ryan is starting another project because he hates working on the Longhorn, and got bored working on his car. Hehehe
72 K20 12v build
Old 04-30-2013, 09:00 PM   #1572
6lcummins
I'm his brother, so i get to help on a lot of the projects he does, just never in pictures.
"STOCK"
ASSEMBLY THREAD
Old 04-30-2013, 10:12 PM   #1573
6BT 56
6BT 56's Avatar
Ahhh... Now I see. So if I paid attention in class.... the 76 was the crew cab that used to be for lack of a better term a monster truck ? It was getting a 24V ve pumped 5.9?? and a short box conversion? Now that is going in a Excursion ? With a dodge auto? What transfercase? Yep build thread required . I like where this is going. I'd love to buy one of those. They can be found up here in Ontario with gas power for a good deal . Much easier swap than trying to fit a 5.9 in a 02 suburban , maby????
Thanks for setting me straight 6L
Old 05-01-2013, 01:30 AM   #1574
6lcummins
I personally like Excersions a lot better. I personally would do the Excursion way before a Suburban.
I'm pretty sure we are going to use my spare NP241DLD but I'm not 100% sure though. Once parts arrive there will more than likely be a thread.
The VE24V was in the "monster truck" but the Excursion will be a better home for it.
"STOCK"
ASSEMBLY THREAD
Old 05-01-2013, 01:55 AM   #1575
mosesburb
I had a V-8
mosesburb's Avatar
Is this the Excursion that was rhinolined on the outside??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
