11-01-2022, 06:01 AM | #1701 |
Re: Columbus..the 1957 IH 4x4..
Glad to see you working on it. You should be able to knock it out now.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
11-01-2022, 08:37 AM | #1702 |
Nice fix.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
11-01-2022, 10:54 AM | #1703 |
Proprietor of Dale's Corner
Looks great, get er done!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
11-01-2022, 04:56 PM | #1704 |
That's gonna' be one sweet rig when it's done! Love the attention to detail, that's what makes a nice restoration an outstanding restoration for sure.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
12-09-2022, 06:56 PM | #1705 |
X2! My grandad had one just like it for his monument business. I can still remember riding in it when I was a kid.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
12-12-2022, 05:17 PM | #1706 |
Post Whore
Thanks guys..!!!
one step closer... I've had all the wiring done for awhile ..havnt put gas in it yet mainly cause I knew I'd be welding close by.. Hopefully I've got the welding behind me.. I had some time this morn, so I bit the bullet, went to town and got 5gal of gas..poured it in the tank..hit the switch several times and primed the fuel system.. Nothing left but do it.. so I tried cranking it, it would hit a little, but never would fire.. fooled with it for about 20 min., still no crank.. there was a few ounces of gas left in the jug, as last ditch effort, I dumped it in the throttle... hit the switch and it came to life.!!!!!!!!!!!!!.. for about 10 secs..Haha So I'm betting the injectors are plugged ...at least that's my thinking..its been sitting for several yrs. I looked into new acdelcos , oreillys wants $117 each.. I'm gonna pull these and see if i can clean them..I've got a new ultrasonic cleaner Im itching to try on them ..
12-13-2022, 07:39 AM | #1707 | |
12-16-2022, 06:24 AM | #1708 |
Good luck with the injectors. I guess I better look into cleaning mine before I even bother to try to fire mine.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
12-17-2022, 11:29 PM | #1709 |
Post Whore
Thanks Regan and Zepp..
If anyone's wondering how I went about cleaning the injectors this is what I've done so far I machined me a aluminum adapter to go from a can of carb cleaner to the injectors I 5min epoxied one of the cleaner straws into the adapter The injector slides in the end and the oring seals it off.. I used o-ring lube on the o-rings to keep from causing any damage to them I bought a cheap injector controller off ebay..it allows for 4 different setting, I used #4 that is the continuous firing mode.. I cut a injector plug out of the old harness to connect the controller to the injector Then you simply mash the go button on the carb cleaner can and it blasts the cleaner thru the injector.. Found out quick you've got to hold the alum adapter onto the injector, it WILL build enough pressure to blow it apart... Dont ask..Haha 2 of them were completely jammed up and at 1st wouldnt fire..took some time to get them loose I'm gonna run them thru the ultrasonic cleaner for a while..I forgot to get the seafoam when I was in town..then I'll flush them all again with the carb cleaner setup, and keep my finger crossed that it works
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 12-18-2022 at 02:12 AM. |
12-18-2022, 08:11 AM | #1710 | |
12-19-2022, 01:04 PM | #1711 |
I’ve enjoyed catching up a bit Greg. Hope all is well and work has slowed for you. Nice work on the oil pan notch!
12-19-2022, 10:29 PM | #1712 |
Post Whore
Thanks Doug.!!.. nice blazer you acquired...
12-19-2022, 10:36 PM | #1713 |
Post Whore
Well, I ran the injectors thru the ultrasonic cleaner with seafoam..i ran it at 180deg for 30 min..
This is what came out of them so far, theres more crud in the drain After the 30min cycle I hooked each one up to the injector controller and suspended them in the seafoam, set the fire cycle on continuous, and ran each one at 180deg for another 15min cycle.. It got dark so I can't see how much ,if anymore crud i removed.. I'll spray them again with the carb cleaner setup and maybe thatll be good enough
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 12-19-2022 at 11:59 PM. |
12-21-2022, 10:58 AM | #1714 |
Post Whore
Got around to draining the ultrasonic cleaner this morn, I drained the seafoam thru a paint strainer..
This is what came outta the injectors during cleaning
01-05-2023, 08:12 AM | #1715 |
Post Whore
Well, I've still got a no start issue..cleaning the injectors was needed, but didnt help..
I'm thinking now I have a fuel pressure issue..got a gauge coming to add to my fuel rails to verify that..
01-05-2023, 08:17 AM | #1716 |
Post Whore
On another note, I had some decals made of the truck and the travelall..
I did the ruff drawings on these , then had stickermule do a redraw to clean them up I did these in a cartoonish style.. I was prodded into this by my IH buddy, he had them made of all his trucks.. These are to hand out to kids at the car shows.....if never make it to one..Haha
01-05-2023, 10:17 AM | #1717 |
Very cool stickers!
71 C10 72 K20 72 K10 Super Kirk |
01-13-2023, 03:27 PM | #1718 |
I like the stickers, they're very nice.
01-13-2023, 10:14 PM | #1719 |
Post Whore
Thanks Kirk and Dale..!!!
I'm still fighting this no start issue.. I've cleaned injectors...they spray very good now.. I've verified I have 12v at the injectors.. Cant find my noid light, think I loaned it to someone and it never made it back home.. Got a new set of noids on the way Should be here next week It will run as long as I pour a little gas in the throttle.. Sure got me buffaloed
01-14-2023, 09:19 PM | #1720 |
Post Whore
Noid lights showed up in the mail today... Injectors not firing ...no time to troubleshoot for a few days
01-22-2023, 02:38 PM | #1721 |
Good luck, I don't know enough about diagnosing the modern stuff.
01-22-2023, 02:55 PM | #1722 |
Post Whore
Thanks Dale..
still not having any luck with it running on its own..gonna call the tuner that did my ecm unlock this week and see what he says I've checked everything I know to check
02-01-2023, 11:51 PM | #1723 |
Post Whore
Got with my tuner guy today.. he looked thru his files where he did the ecm unlock.. he said it should be good.. and to double make sure, he hooked up and checked the ecm itself to make sure everything was there..it was .. he already had his suspicions as to what it might be.. crank sensor not reading.
He says you get the initial injector pulse, then the ecm needs to see engine rpm to continue firing the injectors...that's why I see the 1 time injector fire when cranking... since this was a running engine when I did the swap, he said I need to check the crank sensor wiring.. he said hes seen 3or4 harnesses that were pinned wrong in the past yr or so..and just to rule out the ecm ,were gonna put it in another truck tomorrow and make sure it runs.. ..Still not sure how to check the crank sensor..but he did say if I had a hand tuner I could check the crank sensor signal with it...gonna check wiring 1st..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-03-2023 at 08:23 AM. |
02-02-2023, 09:17 AM | #1724 |
Good luck Greg. We're ready to see this thing running.
02-04-2023, 07:36 PM | #1725 |
Best of luck, I hope it's something simple.
