Old 12-31-2008, 02:12 PM   #151
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: 1969 Chevy CST/10 comes home [Long-term project "OrangeCrush"]
Originally Posted by texanidiot25 View Post
They need to be 1.5 inches thick for the rear. But the hub sizes are different between my axle and this rim (Dana 60 hub is bigger than the rims center hole). But if you were to do custom spacers, the side that faces the axle can be machined for the axle's hub, and then a new hub "lip" can be machined on the spacer to center the rim. Atleast that's just what I thought up last night.
Just the 2 for the rear, I'll see how the wheel and tire fit on the front today
Your thinking is right there, and I will need to know the Diamaters of the hub on the axle, and the hole on the wheel so I can make em right. What I am going to do is machine a 1.5" thick spacer with two 6 hole patterns on it, then I am going to counter bore every other hole on each side so as that you can bolt the spacer individually to the axle, torque it properly, and then with a new set of wheel studs you can mount the wheel directly to the spacer instead of trying to find ridiculously long wheel studs.
Also this will make it easier to mount and unmount everything.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 12-31-2008, 02:24 PM   #152
texanidiot25
Eat My Rust
texanidiot25's Avatar
Originally Posted by kcjones View Post
As long as the wheels and lugnuts are lug-centric (most are), the spacer doesn't actually have to match the wheel's hub, only has to be large enough for the axle hub.
True, but stock GM wheels are still hub centered as well, helps with ride.
And I'd bet be stronger than long wheel studs too.
The OD of the axle hub is 9.5cm. Can't get the callipers to extend out inside the wheel to measure it's hole
texanidiot25 is offline   Reply With Quote
Old 12-31-2008, 02:34 PM   #153
allen123
It'll buff out
allen123's Avatar
how much did your rims and tires cost all together
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 12-31-2008, 02:47 PM   #154
texanidiot25
Eat My Rust
I got the rims for free (Off a used trade-in, pitted chrom on the inside of the wheels, but not on the face. And one has curb rash), and that tire was just a worn one used for mockup. Haven't bought any tires yet.
Old 12-31-2008, 03:01 PM   #155
allen123
It'll buff out
allen123's Avatar
oh ok thanks
1972 Chevy c10 swb
My Build
Cody Allen
Old 12-31-2008, 03:10 PM   #156
MrBeast
high-Tech Red Neck
MrBeast's Avatar
see if you can get the measurement some how, look at things like pop cans, what ever else you can find that might fit snug in that hole. It needs to be a snug fit, but if you can't get it, then we will need to find some one with that model of truck to give us a measurement.
Old 12-31-2008, 03:20 PM   #157
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Does that thing have standard 1/2" wheel studs on it?
Old 12-31-2008, 03:47 PM   #158
texanidiot25
Eat My Rust
Still can't find anything. I'm waiting for my dad to get home though, haven't talked to him yet. The wheels are off a late model GM truck, one of the GMT-800s. I'll see if I can find someone.
Measures 5/8" studs.
Old 12-31-2008, 04:17 PM   #159
texanidiot25
Eat My Rust
Doh, your right 1/2" studs, I was measuring outside diameter.
My dad is going to bring home a set of calipers from work that can measure the inside diameter of the rim tomorrow, so I'll get that then.
Mr Beast, you are awesome.
Old 01-01-2009, 08:01 PM   #160
LuckyHenriksen
LuckyHenriksen's Avatar
Texan I like your new avatar pic, it looks great. I saw it full size in another thread and I like the angle
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 01-01-2009, 08:52 PM   #161
texanidiot25
Eat My Rust
If you like that, check out www.texanidiot25.deviantart.com
Old 01-02-2009, 12:56 AM   #162
19723DR
19723DR's Avatar
That's a nice truck you've got.
I've been running wheel adaptors for about 3 years on my Sonoma. Seems I get more vibration. I'm not saying don't use them, I saying make sure they are EXACT!
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 01-02-2009, 01:12 AM   #163
LuckyHenriksen
Cool link, great pics. I like photography also
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 01-02-2009, 10:06 AM   #164
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Lately I have been turning as accurate as .0005" Hopefully that will get the job done
Old 01-03-2009, 01:11 AM   #165
N2TRUX
Happy to be here
N2TRUX's Avatar
Tx have you considered trading those wheels for a set that will fit better? Give a call to Tire & Wheen Connection and see what they can do for you. They are located on 1960 beside Beck and Masten Pontiac/GMC
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-03-2009, 08:57 PM   #166
texanidiot25
Eat My Rust
I'll give them a call soon.. What is out there in the way of 5 spokes for our 6 lug trucks? I'm not much of a wheel/tire guy, and it's useless trying to search wheels online for our trucks spefically.
Got some awesome things left at my front door today:
At first when I saw the brown box, with a big CPP (Classic Performance Parts, where the rotors I bought come from) logo on the side, I was excited that it was my rotors! That the CST10 would be on the road before the end of the break. Rip the box open, and it's my springs and a turnsignal lense I ordered from Classic Parts, in the CPP box. Why? Classic parts sells the CPP springs and ships them in a CPP box. Deception!
But, here are my new headlights:
They aren't normal old school sealed beams despite the looks. Their really tricky. Their made to use modern halogen bulbs, while keeping the classic looks. And also have a small running light too:
Eventually I may toss a red or orange filter on the bulb and have some trick looking lights while cruising, EVIL EYES
PC'd the headlight bezels black like stock:
And in they went!
Than off goes the 5 inch drop springs, and in goes the 3 inch drop springs:
Nice stance, a slight rake. The rear will sit a tad bit lower once the springs settle in, but other than that, it's damn close to the road!
Fixed all the exterior light problems, bunch of bad grounds and bad connectors.
Just waiting on CPP...
Old 01-05-2009, 02:08 PM   #167
kcjones
I wish I was a cowboy
kcjones's Avatar
Nice stance, a slight rake. The rear will sit a tad bit lower once the springs settle in, but other than that, it's damn close to the road! ...
Perfect rake, you've done well, grasshopper!
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 01-05-2009, 03:57 PM   #168
LuckyHenriksen
Awesome stance, you took out 5 inch drop springs and put in 3 inch springs? What are you going to do with the 5 inchers'
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 01-06-2009, 10:04 PM   #169
texanidiot25
Eat My Rust
Thank you, master.
Another member offered to buy them, and I shipped them out just today. CPP rotors came in, this saturday I'm hitting up Charlies for all the 73-87 parts and starting on it this weekend. Next weekend is a 3 day weekend so should be able to get a lot done then.
It's mainly seat belts, tires, horn (fixing it), brakes, fixing the carb (runs like hell), and some odds and ends to get it on the road. I'm way ahead of my 2000 budget. I have 1400 or so left after the past two weeks, and brakes aren't going to break the bank either.
Also got a new sony expode head unit for 21 bucks after gift cards I think it aught to do better than the old sony tape deck player already in. A friend is going to hook me up with a pair of 6x9s to replace the clarions that are now peeling off the door..
Old 01-07-2009, 02:40 AM   #170
LuckyHenriksen
Cool man, I can't decide what to do with my stereo..... it's nice but it doesn't work, and I have no idea how to fix it. Can't wait to see this thing get on the road! And dang, someone beat me to those springs.... I was going to offer to buy them
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 01-07-2009, 03:52 PM   #171
texanidiot25
Eat My Rust
It's all pretty easy to toss in a head unit if your starting from scratch Like I'll have to. The wiring that's in it is redneck at it's finest.
Old 01-08-2009, 06:27 PM   #172
texanidiot25
Eat My Rust
Opinions? Found these in six lug 16 x 8, and if they have the back spacing I need I'll see if Tire and Wheel connection has any in stock and trade.. Still probably needing a spacer (have to measure backspacing on the steelies I have now and compare) but I dig them a good bit more than the Niche Throttles I have sitting around. My only gripe with the design is the fake rivets, makes the wheels almost ghetto style..
Old 01-14-2009, 04:51 AM   #173
royo
royo's Avatar
Hello i like the headlights. could you tell me where you found them thanks
nickle and dime
royo is offline   Reply With Quote
Old 01-15-2009, 10:22 PM   #174
texanidiot25
Eat My Rust
I sent you a PM back, hope that helps..
My dad's been tearing down the front suspension this week while I was gone, so hopefully we should be able to get it back together this weekend and test it some
Old 01-15-2009, 11:34 PM   #175
adpostel
New Member
Congrats on a nice truck. It looks really nice. I am "ALMOST" finished with my power plant swap on my 68, "ALMOST" is the family inside joke. Hopefully when we get them done, we can cruise somewhere. I am on the south side of town in Clear Lake. I'll keep up with your build, and good luck, your doing a fine job.
1968 C10 LWB Project 454/400
http://www.cardomain.com/ride/2417713
adpostel is offline   Reply With Quote
