Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-07-2008, 11:34 PM   #151
VROD383
VROD383's Avatar
Re: LFD's Project Traizer 2WD closed cab.
VROD383 is offline   Reply With Quote
Old 03-08-2008, 09:00 AM   #152
Rokcrln
Rokcrln's Avatar
Originally Posted by kyle4381 View Post
Looks sweet Kevin.... Keep up the good work..
Kyle how is your blazer comming along, did you get the motor problems all taken care of?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-08-2008, 10:28 AM   #153
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Man Kev you are the man ....Looking awsome cant wait to see it done.
Angelse68cal is offline   Reply With Quote
Old 03-12-2008, 09:42 AM   #154
kyle4381
Kevin
LFD Inc.
Not much progress over here. I got a new toy and it has been burning up my free time.. But have been having a blast.
kyle4381 is offline   Reply With Quote
Old 03-12-2008, 04:46 PM   #155
ColoradoK5
ColoradoK5's Avatar
That thing has Glamis (sp?) written all over it!!
ColoradoK5 is offline   Reply With Quote
Old 03-20-2008, 12:53 AM   #156
70STOVEBOLT
70STOVEBOLT's Avatar
Did this project stall out?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-20-2008, 05:46 AM   #157
Rokcrln
Rokcrln's Avatar
Well here is a bit of todays progress!
I had some rocker panel problems so I am sectioning and slicing to get everything to fit right. I also patched the drivers side door inside and out and coated everything as it was going together. Drivers side is 100% done now and I hope to have the pass side finished up by Thursday and maybe ready to go back on the frame.
Kevin
LFD Inc.
Old 03-20-2008, 05:48 AM   #158
Rokcrln
Rokcrln's Avatar
I also drilled the door hinges to help align them when going back on after patching.
Old 03-20-2008, 05:50 AM   #159
Rokcrln
Rokcrln's Avatar
A few more.
Kevin
LFD Inc.
Old 03-20-2008, 05:53 AM   #160
Rokcrln
Rokcrln's Avatar
The pass side needs to be longer and taller by about a 1/4". I tried two other rockers and they were the same. I checked the dimensions off a factory rocker and their was about a 3/16" diff so I figured why not just make it fit right.
Kevin
LFD Inc.
Old 03-20-2008, 06:18 AM   #161
Rokcrln
Rokcrln's Avatar
Sorry I missed this before posting pics. I would not call it stalled out but it has been slower than I had hopped. I have a full time job 80 miles away as well as a 8month old son that I pick up on my way home and my wife does not get home untill 6pm so my time has been limited. But I have some time off work right now so I hope to get my part all finished up in the next week or so.
Kevin
LFD Inc.
Old 03-20-2008, 07:34 AM   #162
kyle4381
Even "stalled out" your projects move faster than most all I have seen.... Nice Work. Do you sleep?
Old 03-20-2008, 05:36 PM   #163
70STOVEBOLT
Kevin, I actually made that post after reading page 2, without realizing there were 7 pages in the thread. Sorry about that, I know from reading your threads that you are very busy, I don't know how you have time to work on anything with your schedule. Keep up the awesome work!
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 03-22-2008, 03:59 AM   #164
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Kevin, what did you do to the inside of the doors to account for the rust? Blast and then coat? I pulled my door skins and did that before re-skinning them. Just wondered what you did that might have been easier. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 03-22-2008, 06:58 AM   #165
Rokcrln
Rokcrln's Avatar
Well I cut out all rust before the vehical was blasted. They did blast in side the door as much as they could then scrapped down inside as well. Then they epoxy coated everything. As I did the patch repairs I cleaned all areas that I could get to and coated them with rust encapsulator prior to any welding. Then once the patches were done and the doors were back up right I sprayed a heavy coat of encapsulator down in to the doors were the patching was done.
Is this perfect, No but it sure is alot better then factory and should last a real long time. I also sugest a few times a year that you check your drip holes in the bottom of the doors to make sure they are clear.
Kevin
LFD Inc.
Old 03-22-2008, 07:01 AM   #166
Rokcrln
Rokcrln's Avatar
For todays progress I finished sectioning the pass side rocker and got it all installed and coated. I then replace the rocker box covers with new hardware and anti seize before puttin the fender brace's back inplace. I have one patch left to do to the pass door and it will be re-hung using the holes I drilled in the hinges.
Kevin
LFD Inc.
Old 03-22-2008, 07:22 AM   #167
Big J
Its lookin' like a Blazer!
Big J's Avatar
Thats lookin' good. I wish I'd of drilled some holes in the hinges like that. Oh well, lol.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 03-23-2008, 01:40 AM   #168
Rokcrln
Rokcrln's Avatar
We are almost their! The body will meet the chassie for the first time in its new state in about 20min. Today I finished the pass door, spot welded part of the upper fire wall lip because the factory spot welds did not make contact. I installed a nut insert into the pass side upper fender mouint because the stock one was missing, installed the pedal asembly, sterring column, sterring box and cleaned the frame for the body drop
I also installed the tailgate hardware and gate to the new bed sides and had to slot some holes to get the gate to line up right. Once the gate was test fit I them welded the rear gate posts to the bed. My 68 tilt front end will be going on this blazer Monday and by Tuesday it should be ready to head out. This thing will be a body mans dream with it being all new and very straite almost ready for blocking and paint.
Kevin
LFD Inc.
Old 03-23-2008, 02:08 AM   #169
Pop's72
It's ok to stare...
Pop's72's Avatar
Looks damn good Kevin... Excellent work as always!!
Pop's72 is offline   Reply With Quote
Old 03-23-2008, 07:24 AM   #170
Rokcrln
Rokcrln's Avatar
Now for the good pics! They talk for themselves.
Kevin
LFD Inc.
Old 03-23-2008, 07:55 AM   #171
jugernot
Life, Be In It.....
jugernot's Avatar
Sweet. Is that the shop across the street? Nice of them to let you use the lift. Maybe one of these days when I have a day off, I can meet you at your house after work and give you a hand.
Let me know when you start the air ride suspension work on the blazer. I would really like to help with that. I think I'm free on Monday March 31.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 03-23-2008, 10:08 AM   #172
Rokcrln
Rokcrln's Avatar
Yes that is the shop. Paul has given me free rain of the lift if his guys are not using it. We do alot of trade work back and forth so it really does work out nice. Plus all I had to do was roll a body down the street to his shop, walk home and roll a frame down the street and a few minutes later I was pushing a rolling blazer home. I really need to get a lift at my house but first is my frame table and rotissory so I can start my Blazer build.
I will let you know next weekend what my shedule is looking like
Kevin
LFD Inc.
Old 03-23-2008, 06:27 PM   #173
Big J
Big J's Avatar
I imagine thats a relief getting it on the chassis. I can't wait to get that far. Lookin' good.
BAZINGA!
My Build
Old 03-23-2008, 06:56 PM   #174
lyrikz
PITbut
lyrikz's Avatar
Kevin
LFD Inc.
Great work K.
lyrikz is offline   Reply With Quote
Old 03-24-2008, 08:29 PM   #175
Dinos63
chevy only
Dinos63's Avatar
kevin like always your work is unmatched. and i like the way you document all the steps
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
