Old 09-08-2009, 01:09 AM   #151
brian69longbed
brian69longbed's Avatar
Re: 1970 VA Longbed Project
those turned out great
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 09-08-2009, 01:13 AM   #152
VA72C10
VA72C10
VA72C10's Avatar
Finished grinding by smoothing out the CPP notches a little more...
We came up with and fabricated a custom rear crossmember out of angle iron to hold the air tank. I did a lot of measuring to make sure it wouldn't stick up too high and hit the underside of the bed or a crossmember and won't be too low to show under the bumper...hopefully all the measuremements are right
In this picture the frame is upside down so that's why the bumper brackets are that way.
Here it is welded on. It may not look it due to the notch for the bumper bracket, but is so strong, Jason used that bar to lift the whole frame on his end when we moved it.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-08-2009, 01:15 AM   #153
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by brian69longbed View Post
was there like an undercoating on your frame? almost tar like and not full frame. it was on mine and im pretty sure its factory
Certain areas seemed like they had an undercoating on them and they would burn up/fill up the sanding disc. I would wire wheel those sections first and then grind them down smooth with the disc.
Thanks. His welder died after the notches so he had to tig that...I think he did a really good job for tigging around the oval shape in a fairly tight spot.
Old 09-08-2009, 01:17 AM   #154
brian69longbed
a 5 gallon air tank?
what's the diameter?
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-08-2009, 01:18 AM   #155
VA72C10
VA72C10
VA72C10's Avatar
Let the paint begin!!!!!!!
I Used Rustoleum products because I've had success in the past with a Camaro I restored and have heard others have good experiences as well. Even though the frame was smooth and clean and I'm using a hammered paint, I decided to prime the frame to ensure the best possible adhesion.
Products used:
Old 09-08-2009, 01:19 AM   #156
VA72C10
VA72C10
VA72C10's Avatar
Look how smooth that frame is in that picture
It's a thing of beauty.... I am really happy how it all turned out if you can't tell. There is a LONG way to go but it's a nice step in the process.....
Old 09-08-2009, 01:23 AM   #157
brian69longbed
yeah i didn't go that far into detail but i'm going to have it sand blasted and powder coated. yours is coming along great. are you going to rattle can your frame for its final finish?
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-08-2009, 01:25 AM   #158
brian69longbed
come to think of it i used rustoleom today on my frame too just a different can! lays out nicely
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-08-2009, 01:27 AM   #159
VA72C10
VA72C10
VA72C10's Avatar
Well, I told you I had decided to mix things up a bit. Decided to go two tone on the chassis. I did all the frame in a black hammered finish and all of the suspension/steering will be in hammered silver. Will do the brake parts with a smooth gloss black made for calipers/drums so those parts won't stand out so much behind the wheels.
Going for a silver and black theme with the body color being the splash. Will have chrome and black on the engine as well as body color.
Exhaust will be ceramic coated (headers) or polished (mufflers)
Here is the steering box...before. (after cleaning and paint prep)...
Once coat and the tools I used
After
And a closeup of the finish
Also got the trailing arms done....will get better pictures once installed...
Old 09-08-2009, 01:29 AM   #160
VA72C10
VA72C10
VA72C10's Avatar
Yep, rattle can because of things like when we moved the frame we scraped the edge of the notch on the concrete and it scraped a little paint. A little scuff, primer, and more hammered topcoat and it was never there. With powdercoat it would be noticeable....
Old 09-08-2009, 01:29 AM   #161
brian69longbed
i like the finish
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-08-2009, 01:30 AM   #162
VA72C10
VA72C10
VA72C10's Avatar
THE FRAME
Primered
One side painted and it's flipped back the right way for hopefully the final time
Old 09-08-2009, 01:33 AM   #163
VA72C10
VA72C10
VA72C10's Avatar
THE FRAME IS PAINTED
Texture looks even better in person....very similiar to the silver vein powdercoat (only more of a chassis black color)
Loving it
Old 09-08-2009, 01:36 AM   #164
VA72C10
VA72C10
VA72C10's Avatar
Couldn't resist throwing the chrome air tank on to see the contrast. It looks so sweet
We will be making a gusseted bracket to capture the bottom bolt hole on the tank...but it's pretty secure already with the hand tightened bolts.
Going to be easy access if i ever need to help someone with a flat tire....should just hide behind the sport bumper.
Old 09-08-2009, 01:54 AM   #165
VA72C10
VA72C10
VA72C10's Avatar
I'll add for those planning to do this...It took three of the large cans of Stop Rust Primer and 7 cans of hammered paint. I laid the hammered paint on thick to create a more noticeable hammered pattern. Plus it will be nice and durable. Basically three coats of the hammered applied right after each other with extra coats in areas that didn't have as much texture as the rest.
I prepped the frame after grinding by first blowing it off with air. I used a brake bleeder air tool because the extension got into tight areas. Then I wiped the entire frame down inside, outside, top, and bottom with paint thinner. Finally, I went over it with a high powered air nozzle and made sure all the thinner had dried off and there was no more dust or dirt anywhere.
Proceeded to spray two light coats of the stop rust primer followed by three to four of the hammered black topcoat as mentioned.
Old 09-08-2009, 07:36 AM   #166
my67chevytruck
Under Construction
my67chevytruck's Avatar
WOW, loving the progress, you are making strides.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-08-2009, 07:43 AM   #167
splehigh
splehigh's Avatar
The hammered paint looks great! Awesome progress!!!
splehigh is offline   Reply With Quote
Old 09-08-2009, 09:37 AM   #168
VA72C10
VA72C10
VA72C10's Avatar
Thanks! It really is good to be making appreciable progress on the truck. I've actually gotten to the point where I have to order some parts before I can button up the frame which is both good and bad
Old 09-08-2009, 09:46 AM   #169
gcburdic
Restoration Virgin!
gcburdic's Avatar
Yep....I've decided when it's time to do my FREE frame, it'll be hammered!!!...Great progress this weekend...I can feel the excitment building!!wooohooo
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-08-2009, 09:57 AM   #170
70k52wd
Blaze-Air
70k52wd's Avatar
I love the hammered paint, turned out real nice.
Tank mount looks great.
Are you painting the truck tutone black and silver?
70k52wd is offline   Reply With Quote
Old 09-08-2009, 10:03 AM   #171
VA72C10
VA72C10
VA72C10's Avatar
Thanks Geoff
Thanks Charlie....Actually I am pretty sure I'm going to be doing a deep red somewhere between fire engine and cranberry....need to look at color samples where my fab man's buddy works....
Second choice is a deep blue pearl. I painted my Z28 the dodge viper blue pearl metallic and my wife and I both loved the color...but it's pricey and hard to spray being both pearl and metallic....
Old 09-08-2009, 10:06 AM   #172
VA72C10
VA72C10
VA72C10's Avatar
Oh...by the way Charlie....
GET OUT TO THE GARAGE AND WORK ON YOUR BLAZER!!!
You said you wanted someone to push you, right?
Old 09-08-2009, 11:19 AM   #173
70k52wd
Blaze-Air
70k52wd's Avatar
You sir are correct. I need the push.
I've been out there a little, very little. I don't want to muddy your thread, but I re did my intake.
I'm getting really fast at removal and reinstalling things.
My .02 on paint, make it pop. Blue is nice, but red is fast just sitting still.
Personally, With all the great work you're doing, I would just have to do a tutone paint scheme such as red and black, red and silver, or my fav combo, black and silver.
I like the way tutone on a lwb truck makes it appear even longer. And lower.
Truth is, if it were my choice(and it's not)I would go with some kind of a crazy tutone, Canary yellow and black,
Anti freeze green and black, Cobalt blue and black, Comp orange and black. You get the idea.
Old 09-09-2009, 02:03 AM   #174
VA72C10
VA72C10
VA72C10's Avatar
Went by Home depot...got Grade 8 bolts 3/8 X 4"...those seem like they will work well for the rear bags. Going to make some square washers to space them up on the trailing arms and spread out the load. Have some drops of thick steel I will use.
Tonight I simply mocked up the rear airbags, have a template made for drilling out the fitting for the bags, did some touchups on the frame, did a third coat on the control arms to give them more of a hammered texture, and mounted the power steering gearbox. I'm very happy with the silver next to the black. The black is almost a dark charcoal grey and looks great!!!
PS Gearbox mounted up
The frame as it sits
Old 09-09-2009, 07:52 AM   #175
my67chevytruck
Under Construction
looking good... have you posted pics of your Z28? I'm partial to blue myself...... keep up the great work...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
