Old 08-03-2015, 06:13 PM   #151
padresag
Re: Where is my 60-66 Chevy or GMC vin number?
Originally Posted by chevy55-77 View Post
IF IT IS DIFFICULT TO WHAT inch sizes
I guess that you are demanding an instant answer by using all capitals/ you know if you are going to input new ser.# onto another frame, i wouldn't tell the world
ron
padresag is offline   Reply With Quote
Old 11-06-2015, 03:02 AM   #152
sgt g
I have a 1961 Chevy short bed with VIN # 1C144K108380. I'm trying to figure out if it was originally a Fleetside or Stepside. Where can I find the model # on it?
sgt g is offline   Reply With Quote
Old 11-06-2015, 04:35 AM   #153
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
You can't. You need to look for clues. Does it have or has it ever had the little triangle fillers at the back of the cab just inside the cab corners? All stepsides had those little fillers.. its also possible it was a cab and chassis and didn't have a bed originally.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 11-06-2015, 04:42 AM   #154
sgt g
The triangle pieces are what first got me trying to figure it all out. My truck currently has a stepside bed on it, but not the triangle pieces. Also the truck has been repainted at some point prior to me buying it and the paint under the respray doesn't match from the bed to the front of the truck. I have a Fleetside shortbed I was going to put on it but just wanted to know what it originally was.
Old 11-06-2015, 10:05 AM   #155
66-PMD-GMC
66-PMD-GMC's Avatar
If you look under the cab where the little filler parts would attach. There will be 3 screw holes to hold the edge of the filler on and one hole further forward for a support bracket. No screw holes means it wasn't originally a stepside.. but if they are there.. it most likely was.
Projects..
440CID 2X4 Pontiac
Old 11-06-2015, 05:49 PM   #156
sgt g
Alright I checked the cab on the 61 and it has the three screw holes. I also checked under my 62 fleetside longbed and it has the holes as well. The 62 is all original...so I'm thinking maybe they all have those holes.
Old 11-06-2015, 08:18 PM   #157
66-PMD-GMC
66-PMD-GMC's Avatar
No they don't have those screw holes unless it had those fillers..
Projects..
440CID 2X4 Pontiac
Old 11-07-2015, 02:50 AM   #158
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
all my trucks, even the c/ 60's have the screw holes.
Old 11-07-2015, 07:23 AM   #159
66-PMD-GMC
66-PMD-GMC's Avatar
I have 7 cabs here.. 2 stepside with.. 5 cabs without
Projects..
440CID 2X4 Pontiac
Old 01-24-2016, 06:41 PM   #160
Killer Bee
Killer Bee's Avatar
many thanks OP.. couldn't find the vin plate in the usual places and never would have found the frame stamps under all that gunk..
Killer Bee is online now   Reply With Quote
Old 03-16-2016, 12:13 AM   #161
Winmon
Winmon's Avatar
Just picked up my first C10 ('64 Chevy) and am checking the VIN out. Mine is 4C144H143128
Looking at this chart, I am not seeing "H" designation for the assembly plant as is in my VIN?
Winmon is offline   Reply With Quote
Old 03-16-2016, 01:21 AM   #162
padresag
are you sure that it is an h
ron
Old 03-16-2016, 07:59 AM   #163
Winmon
Winmon's Avatar
ron
Yes, here is a pic
Old 03-16-2016, 09:21 AM   #164
Nanook
Nanook's Avatar
Canadian VIN Plate located on the left hand front door jam
Nanook is offline   Reply With Quote
Old 03-16-2016, 04:19 PM   #165
jonzcustomshop
1961 crewcab
my 64 owners guide shows "H" as Fremont.
Old 03-16-2016, 07:01 PM   #166
Winmon
Winmon's Avatar
Cool, thanks!
Old 11-24-2016, 08:06 PM   #167
AngryPirate
AngryPirate's Avatar
So, I tried to get a title for my truck and part of that process is taking the vehicle to the sherriff office vehicle theft unit and they give you a forum so you can complete the process.
They weren't accepting the door frame plate with the serial number and wanted the vin from the chassis, which they believe to be on the drivers side on the top of the frame rail, just in front of the rear cab mount. So, since I might be replacing the cab anyways, I cut open the floor to expose that part of the frame and there was nothing there.
There was nothing that I could see on the front part of the frame (horns? area).
From what I've read, Chevys may have had these stampings on the frame, but the GMC's didn't, especially my year of truck, 1960.
Thanks for any tips.
Any thoughts on this?
AngryPirate is offline   Reply With Quote
Old 11-24-2016, 08:20 PM   #168
66-PMD-GMC
66-PMD-GMC's Avatar
There is no VIN on a GMC frame..
That's a fact that many argue with. It's not a chevy. Gmc is a different comany in the 60s. So chevy info does not apply to your gmc.
Projects..
440CID 2X4 Pontiac
Old 11-25-2016, 12:18 AM   #169
AngryPirate
Thanks for confirming that PMD-GMC.
Might I ask where your serial # / vin is located? Is it the drivers side front door jam?
Old 11-25-2016, 05:38 AM   #170
66-PMD-GMC
66-PMD-GMC's Avatar
On my 63, it's on the A pillar at the front of the door jam.
On my 66, at the top.
Projects..
440CID 2X4 Pontiac
Old 11-25-2016, 10:45 AM   #171
AngryPirate
Much appreciated!
Old 02-26-2017, 11:19 AM   #172
One63chevy
Hello all, I need help. I know this thread has been quiet for awhile but I'm going to bring it back to life. I recently came into possession of what I thought and what the title said was a 63 GMC C10. After reading most of the post on this thread is decided to verify the VIN # to the title and could not find and plates on the Cab. So I decided to check the LH frame and found these 0151610 in the two places mentioned in previous post. I can't find any information about this # anywhere, and it does not match the title VIN# any help would be appreciated. "0151610"
One63chevy is offline   Reply With Quote
Old 02-26-2017, 11:54 AM   #173
66-PMD-GMC
66-PMD-GMC's Avatar
Gmc does not have have a vin on the frame.
If indeed you bought an original gmc.
Gmc is not a "C10". C10 is a chevy designation.
A 1/2 ton GMC is a 1000 series.
IF your GMC is a coil rear suspension, but was built in the US, it has probably received a frame swap.
The vin on a 63 is on the drivers side door jam next to the windshield. If it's an earlier cab, it could be on the drivers kick panel in front of the vent.
Projects..
440CID 2X4 Pontiac
Old 02-26-2017, 12:52 PM   #174
One63chevy
Thank you for the information I did not know any of that, I'm just learning bits and pieces again thank you. So now my problem is that I have no way to find out what the real VIN# is since someone removed all tabs and placards from inside the cab.
Old 01-16-2018, 01:38 PM   #175
Lobotie
Lobotie's Avatar
I just picked up a '60-63 with no paperwork. I've been trying to decode the VIN but I can't figure it out. Please help!
GMC 1502CG2592B
Lobotie is offline   Reply With Quote
