Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-09-2013, 04:43 PM   #151
turp mcspray
turp mcspray's Avatar
Re: New member from the Black Hills
jaros, I will get back to you with some info today!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-09-2013, 06:51 PM   #152
turp mcspray
jaros, I used some 3/4" black pipe for the shift rail collars. It is a slightly loose fit. They are about 1 1/8" long. Then I used some 1/4" flat stock, cut to fit inside the pipe, as well as inside the shift rail slots. This is what gives it a nice snug fit. Looks like the tabs for the rod ends to bolt to are 3/16" by 1" wide. This is all stuff that happened to be in my metal stock pile.
I believe the main bolt is 1/2" by 4" long. I took my bolt and a shifter to Whisler Bearing, (they have a large selection of bronze bushings) and the measured both and found a bushing that was very close to matching both. I ran a drill bit through the bushing to open it up slightly, and sanded on the bolt for the final fit. The bushing is 1" long, which isn't as wide as the shifter hole. It was that or use two shorter bushings. Hope this and the pics make sense.
Turp Mcspray
Old 12-09-2013, 06:53 PM   #153
turp mcspray
Here are a couple of the bushing in the shifter.
Turp Mcspray
Old 12-09-2013, 07:11 PM   #154
jaros44sr
jaros44sr's Avatar
Great write up, thanks for taking the time outta your day.....
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-12-2013, 11:52 PM   #155
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Hey Scott, long time no see. Got off my butt and got a new password!
Great idea on the bushing from Whistler! I got some plastic ones from Sturdivants for brake pedal setups that are very similar to stock ones but they are a little wiggly to use on that adapter I got from you since the shifter bolt was different. I'm not doing a twin stick but the shifter bushing is the same idea either way.
Thanks---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 01-18-2014, 11:03 PM   #156
turp mcspray
I've been really slacking on my thread! Doesn't seem like I'm getting much accomplished. A fair amount of small stuff. Here are a few pics.
I had to turn my 71 doors, into 72's. Got them mounted, and the body shimmed and bolted down. Been mainly working on firewall and dash stuff.
Turp Mcspray
Old 01-18-2014, 11:08 PM   #157
turp mcspray
Painted some misc. pieces.
Turp Mcspray
Old 01-18-2014, 11:14 PM   #158
turp mcspray
And some assembly. Makes me feel like I'm getting somewhere!
Turp Mcspray
Old 01-18-2014, 11:18 PM   #159
turp mcspray
I went with some Rammat for the floor.
Turp Mcspray
Old 01-19-2014, 10:25 AM   #160
briank
Turp, looks good. Nice to see im not the only one that has thought about making 71 doors in to 72. Little things like thay bother me on my vehicles. I like factory stock and have nice California 71 doors to go on my 72 k5 but didnt know if I wanted the hassle to cut that piece out.....maybe I will now.
briank is offline   Reply With Quote
Old 01-20-2014, 03:49 PM   #161
mtully79
mtully79's Avatar
Re: Black Hills blazer build
Turp,
What are your plans with the floor now that the rammat has been applied? Are you going with a carpet or can you use line-x on it?
Love the build and all the great detail work!
mtully79 is offline   Reply With Quote
Old 01-20-2014, 10:18 PM   #162
turp mcspray
briank, It really isn't very difficult to add the 72 hole. Don't forget about reinforcment piece for the latch area, as well. My doors are actually off of a 71 pickup.
mtully79, I am going to add some of that foil covered bubble wrap stuff from Menards, and then a stock style carpet. I've used the foil/bubble stuff in many vehicles, and it really makes a big difference in keeping both sound and heat, out of the cabin!
Here are some more dash/firewall pics.
Turp Mcspray
Old 01-20-2014, 10:21 PM   #163
turp mcspray
Stock firewall pad and misc.
Turp Mcspray
Old 01-20-2014, 10:29 PM   #164
turp mcspray
Firewall pad and misc.
Turp Mcspray
Old 01-20-2014, 10:37 PM   #165
turp mcspray
Found a color that is VERY close to the factory heat/defrost box color.
Turp Mcspray
Old 01-20-2014, 10:51 PM   #166
turp mcspray
Heater box assembled.
Turp Mcspray
Old 01-20-2014, 11:24 PM   #167
YBNORML
YBNORML's Avatar
Looking awesome! As usual of course you do amazing work.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-22-2014, 10:47 PM   #168
turp mcspray
Thanks for the compliment ybnormal!
Years ago I found a couple of vacuum gauge dashes in a salvage yard, while driving through Nebraska. I added one, and a camaro tach to my blazer dash. I blasted an painted all of the dash housing stuff, but forgot to take pics. Rather than cut out a hole for the tach plate, I just flattened out the ridge in the factory tin, and drilled some holes.
Turp Mcspray
Old 01-22-2014, 10:54 PM   #169
turp mcspray
I bought a windshield and got it installed as well. I was expecting it to be a bear with the short 72 trim, but it went in really easy! Installed the dash harness and dashpad next. Went back and installed a trip odometer also.
Turp Mcspray
Old 01-22-2014, 10:57 PM   #170
turp mcspray
A couple pics of the a/c box, and another dash shot.
Turp Mcspray
Old 01-23-2014, 10:26 AM   #171
jaros44sr
jaros44sr's Avatar
Turp, glad to see youre gettin' to spend some quality time with the ol' girl.....nice work as usual, and good pics! For someone who forgets how it goes back together
PS, thanks for the help on the twin stick, starting to formulate a plan in my head, just want to make them wider apart......
SAFETY FIRST
AS usual, off topic
Jim
Old 01-23-2014, 04:32 PM   #172
muckmuck
Junior Member
muckmuck's Avatar
Looking good! Glad to see the updates... Btw, my Jimmy is from Rapid city. I used to live in Deadwood and there is some beautiful country up there. Good luck!
muckmuck is offline   Reply With Quote
Old 01-24-2014, 10:50 AM   #173
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Looking real good Turp. That tach sure looks factory!
Tom Vogel is offline   Reply With Quote
Old 07-20-2014, 07:31 PM   #174
tjsblazer
tjsblazer's Avatar
Late to the party but catching up. Looks great.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 07-21-2014, 04:55 PM   #175
truckeez
Next pics are with 6" skyjacker lift, 36"swampers, 6point cage. Blazer is a CST, Tach, air, am/fm (missing), Extreme tow hooks.
When I got the truck I didn't know any thing about the hooks. I thought someone put them on from a bus or something.HaHa!
Ruggedly handsome...... like Me
truckeez is offline   Reply With Quote
