Old 10-08-2009, 12:56 AM   #151
Frizzle Fry
Frizzle Fry's Avatar
Re: 2" Drop Trailing arms
Somethin's interesting about the front of those TA's...
Frizzle Fry is offline   Reply With Quote
Old 10-08-2009, 01:01 AM   #152
SCOTI
SCOTI's Avatar
It's a clever idea no??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-08-2009, 01:43 AM   #153
Frizzle Fry
I'm diggin it. He made an awesome choice for what to plug in there too.
Old 10-08-2009, 09:51 AM   #154
SCOTI
SCOTI's Avatar
He listens to his customers.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-08-2009, 11:30 AM   #155
vegaschevy
Originally Posted by jasonb72 View Post
I need a new pair of drawers
I did not see any woodworking tools in there
vegaschevy is offline   Reply With Quote
Old 10-09-2009, 12:49 AM   #156
jasonb72
PorterBuilt Man Crush
You actually made me go look it up on the urban dictionary. Too many hours at work = second guessing yourself.
Drawers:
(noun) Underwear; Underpants
Drop your drawers!
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 10-11-2009, 08:48 AM   #157
lo04chevy
With these Drop trailing arms. If I were to buy them and a 6" drop coil for the rear. That is a 8" drop for the rear. Am I going to have to notch? Pinion angle? 70 swb truck I am building.
"You have your way. I have my way. As for the right way, the correct way, and the only way, it does not exist.”
Friedrich Nietzsche
lo04chevy is offline   Reply With Quote
Old 10-11-2009, 10:02 AM   #158
SCOTI
SCOTI's Avatar
Originally Posted by lo04chevy View Post
With these Drop trailing arms. If I were to buy them and a 6" drop coil for the rear. A)That is a 8" drop for the rear. B) Am I going to have to notch? C) Pinion angle? 70 swb truck I am building.
A) Correct.
B) At the minimum.
C) Would still be acceptable. Could be on the edge if forward drivetrain components are not ideal. It's always a good idea to verify & correct w/shims if needed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2009, 02:45 PM   #159
lo04chevy
A) Correct.
B) At the minimum.
C) I'm wanting to do a 5.3L.
Also on doing the drop. cpp spindles are 2" and coil is 2.5 and rear coil is a 6". Reason being on using Nathans drop trailing arms, is to get rid of the rake. Or will I have a rake at 4.5/6?
Friedrich Nietzsche
Old 10-12-2009, 09:29 PM   #160
shifty
Questionable
shifty's Avatar
i got a couple of gifts from Spohn today....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-13-2009, 06:08 PM   #161
shifty
Questionable
shifty's Avatar
Hmmm....i got some more interesting little machined pieces in the mail today too. not sure what they are yet
it's like...every day a new gift! i like this!
Old 10-13-2009, 06:23 PM   #162
lolife99
67-72 parts collector,…
lolife99's Avatar
Hope they weren't mine, sent to you by mistake,...
Keith
Convert to disc brakes.
Old 10-13-2009, 07:22 PM   #163
SCOTI
SCOTI's Avatar
I KNOW they weren't mine .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-13-2009, 10:14 PM   #164
VA72C10
VA72C10
VA72C10's Avatar
I might have missed this...but do you make the arms longer or space the mounts on your crossmember to center back the rear in the rear wheelwell, or just have the person drill new holes further back if they want to...?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-14-2009, 12:46 AM   #165
SCOTI
SCOTI's Avatar
It's a personal choice as any of the above will work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2009, 12:57 AM   #166
PBFAB.COM
PBFAB.COM's Avatar
Drilling the new holes will be the easiest solution. This will allow the rear axle center-line to be moved wherever one desires.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-14-2009, 01:09 AM   #167
SCOTI
SCOTI's Avatar
I chose spacers because you can change your mind & adjust as needed (not that I have a commitment problem ).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2009, 01:12 AM   #168
VA72C10
VA72C10
VA72C10's Avatar
Sorry, don't want to muddy this thread...but I think it shows a good reason to buy your product
Since I'm already way over budget, I'm gonna work with what I have...
I assume moving the crossmember back the necessary 1 1 1/4" will affect the carrier bearing mounting? (2pc driveshaft)
Did you just buy 1" stock and drill out the holes and install behind the original brackets?
Old 10-14-2009, 01:15 AM   #169
SCOTI
SCOTI's Avatar
Does this affect the carrier bearing mounting? (2pc driveshaft)
I can't say. This is the first one I've done like this & I don't know if it will be a 1 or 2pc shaft (all my previous trucks have been 1pc).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2009, 01:43 AM   #170
PBFAB.COM
PBFAB.COM's Avatar
The necessary distance to center the rear wheels in the wheel well will depend on how low you are wanting to go. It will be anywhere from 1" to 1.5" depending on preference.... and depending if you want the wheels centered at ride height, or when deflated. Careful measuring will allow one to set it up just how they want!
I also build trailing arms that are extended behind the bag mount in order to move the center-line back... all I need to know is how far one wants them extended (normally 1.25"). I am also building them with a 3" drop.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-14-2009, 01:44 AM   #171
PBFAB.COM
PBFAB.COM's Avatar
no problem at all....
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-14-2009, 01:47 AM   #172
SCOTI
SCOTI's Avatar
Hey, I never said I was decisive; I said I was an idea man.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2009, 01:49 AM   #173
SCOTI
SCOTI's Avatar
Bingo. I tried it out w/wood to get my notches centered & for general set-up purposes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2009, 02:14 AM   #174
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Great info gentleman, I appreciate you sharing your insight and experience.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-14-2009, 03:02 PM   #175
shifty
Questionable
shifty's Avatar
I got two very large, very heavy packages today.
I opened the longer, heavier one up. Guess what's inside?
