Old 02-19-2013, 11:28 AM   #151
69CST-V
69CST-V's Avatar
Re: my 50 build... why not?
Nice job. That last picture is cool. Can't wait to see you squirt some color.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 03-04-2013, 11:39 PM   #152
nebdrummer
nebdrummer's Avatar
Thanks!
Rear end stuff came back from coating. Huge rave for crosslink custom coatings here in Lincoln. It turned out great! I couldn't be any more happy with it.
I have a set of tubular front control arms on order. Along with all new tie rod ends and steering everything new. Hope to come up with some extra cash quick here to get a diff ordered. Then it will be on its wheels and off to paint.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 03-05-2013, 09:41 AM   #153
99 to Life
99 to Life's Avatar
looks really good
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-05-2013, 10:01 AM   #154
xpickup
xpickup's Avatar
nebdrummer, Great job on the rear frame section. I have a question for you and your rear sway bar. Do you of anyone that sell torsion bars that are wider than the 30" ones that the sprint car guys are using. I want to make custom front and rear sway bars for the frame that I am working on. Keep up the great job.
Shannon
xpickup is offline   Reply With Quote
Old 03-06-2013, 04:31 PM   #155
nebdrummer
nebdrummer's Avatar
Thanks guys,
Shannon, thanks for the compliments, I went with competition engineerings magnum arb kit. These styles of arbs are much too stiff for use on the street as mine will only be hooked up during racing events. I will not be using the front sway bar either.
Here's my kit. Bottom of page.
http://www.competitionengineering.co...?catcode=13048
I'm not so sure on what is all out there for a universal sway bar though.
Old 03-06-2013, 04:37 PM   #156
xpickup
xpickup's Avatar
nebdrummer, Thank you. I will check out there site. I would think somebody would make a universal sway bar kit but maybe not. Chevette said about checking out some of the NASCAR stuff on ebay also.
Shannon
Old 04-12-2013, 12:41 PM   #157
nebdrummer
nebdrummer's Avatar
true trac ordered for the 3rd member. that should be in and done next week.
I also picked up a full set of SPC control arms for the front so, with any luck, i can have this purple thing on all 4 wheels.
I havent had any time to get to it in the last month and a half to block and reprime the cab. Ive been remodeling my whole basement. Thats just about to a stand still, so i should be getting back to this soon.
Old 04-23-2013, 11:11 PM   #158
superfly
you sure won't be takeing that one down the gravel roads.
Lookin good.
superfly is offline   Reply With Quote
Old 04-25-2013, 01:45 PM   #159
nebdrummer
nebdrummer's Avatar
lol thanks. sorry i didnt call you back. Ive been super busy lately. which is a good thing!.
Still waiting on the 3rd member. its going to be around 80 degrees this weekend, so i forsee the cab getting reprimed and possibly wet sanded to get ready for paint!.
Old 05-03-2013, 01:31 PM   #160
nebdrummer
nebdrummer's Avatar
I need to order so more stuff before the cab, doors and hood go off for paint. Need to make the seat brackets. A couple of braces under the dash. Lizzard skin the inside, run and plumb the brake lines.
If it actually gets above 50 this weekend, it will be on the front wheels. Still waiting for the diff to get back with the true-trac installed.
Did a little sanding and buffing on the rear fenders. Note the orange peel around the light reflections.
Sanded heavy 1000, light on 1500, dry 1500 on DA, then switched right to 3000 trizac. It buffed out super easy.
Buffed
Old 05-03-2013, 02:35 PM   #161
69CST-V
69CST-V's Avatar
Looks good.
Bryce
Company Trucks
Old 05-25-2013, 08:58 AM   #162
nebdrummer
nebdrummer's Avatar
3rd member is finished and in.
God I need new rims. Lol
Old 06-04-2013, 08:11 PM   #163
69short
69short's Avatar
Nice build!! I just moved away from Lincoln, NE. Im 99dakrt on scr, Ive read your build thread over there! I didnt realize you were on this forum. Ill check back for updates. Keep up the good work
69short is offline   Reply With Quote
Old 06-04-2013, 08:31 PM   #164
nebdrummer
nebdrummer's Avatar
Thanks. and Nice! Good to see you here too then.
Old 06-05-2013, 12:40 AM   #165
jdougla9
hey your build looks great. I was wondering who you went with on the 4 link kit? I am looking to do a 4 link and mintub this winter before i do the bodywork
jdougla9 is offline   Reply With Quote
Old 06-05-2013, 09:28 AM   #166
nebdrummer
nebdrummer's Avatar
Competition engineering is the company. I'd have to look at what exactly kit it was though. There's a LOT of measuring and a LOT of research on how to weld this in properly. If you don't plan on doing a lot of racing, then go with a made to fit 4 link kit as this is unnecessary otherwise. An improper installed 4 link can be just as dangerous as a bad set of welds. Just make sure it's the right kit for you.
Old 06-07-2013, 10:47 AM   #167
jeffrow62
jeffrow62's Avatar
nice work !! impressive!
jeffrow62 is offline   Reply With Quote
Old 06-09-2013, 11:21 PM   #168
nebdrummer
nebdrummer's Avatar
Thanks! Got a lot done on this busy weekend. Pulled some bushes out, planted a bunch of flowers for the lady, sold my 53 bel air, had a kickass show, and got the cab READY FOR PAINT!!
Everything masked up.
I had just a bit of touch up to do.
And sanded down again.
And perfection
Nice strait lines
Now I need to make the seat brackets, lizard skin the inside, make a bracket from the steering column bracket on the dash to the brake booster, then plumb the brake lines, and this thing goes off for color.
Old 06-09-2013, 11:50 PM   #169
99 to Life
99 to Life's Avatar
looks good, getting things in primer is fun. the before and after ahhhhh lotta work
Old 06-10-2013, 04:46 PM   #170
Bubba54
Trucks looking good, nice work.
Bubba54 is offline   Reply With Quote
Old 06-11-2013, 10:21 AM   #171
69CST-V
69CST-V's Avatar
Nice job. Looks great.
Bryce
Company Trucks
Old 06-13-2013, 01:57 PM   #172
superfly
I still hate you and your skillz.
Old 06-13-2013, 03:31 PM   #173
jeffrow62
jeffrow62's Avatar
Very nice work!! Do you have a compressor? What size?
Old 06-13-2013, 03:46 PM   #174
nebdrummer
nebdrummer's Avatar
Thank you guys!
Superfly, I'm sorry things haven't worked to get your cab down here. Maybe when things quit being hectic around here.
Jeffrow, yes I have a 60 gallon compressor. I got it new from max tool out of California shipped for free. For the price and what it puts out in CFM, it is the best one you can get. And it's all made in the USA. It's a BelAir compressor. 19.5 CFM, dual stage compressor. It just barely keeps up running a da sander for 10 minutes straight but I'm going to be hooking up a 100 gallon helper tank just so I can work till the compressor kicks in, then when it builds up again, I should have a good 5 minutes of sanding without the pump kicking back on.
Old 06-13-2013, 03:58 PM   #175
superfly
Neb my dads cab is at the body shp waiting to get redone all new one piece floor allcab corners and inner outer cowls the whole thing done, in primer ready to rock cant happen soon enough
when i back to the 50s i want to go,
