Old 06-08-2011, 05:56 PM   #151
robnolimit
robnolimit's Avatar
Re: Bolt in steering rack
Before final assembly, we noticed that one of the u-bolts was hitting the crossmember so the excess thread was cut off. You will need to check this
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-08-2011, 06:07 PM   #152
rob32472
Smile Re: Bolt in steering rack
Looks like a good kit so far How much is it and when can we buy it?
rob32472 is offline   Reply With Quote
Old 06-08-2011, 06:21 PM   #153
aggie91
I'm just glad to be here!
aggie91's Avatar
I like it. Will this work on an '82 as well?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-08-2011, 07:51 PM   #154
robnolimit
robnolimit's Avatar
Talking Re: Bolt in steering rack
The complete kit will include the rack and pinion, the rack mount, all mounting hardware, tie rod adjusters, outter tie rod assemblies, steering shaft stablizer bearing and mount, 2 flaming river billet u-joints, and a section of steering shaft.
The list price will end up at @ 849.00 for the complete kit.
Old 06-08-2011, 07:54 PM   #155
robnolimit
robnolimit's Avatar
Forum Member Special
We are going to pre-sell 10 kits at a discounted price of $750.00.
This offer is only good for Forum Members, this will give member a good deal and help us with production cost. If you are interested in purchasing one of the first ten please call direct to our order line 909-386-7637.
Expected ship date is July 1st.
Old 06-08-2011, 07:55 PM   #156
robnolimit
robnolimit's Avatar
Yes the kits will fit from 1963-1987.
Old 06-08-2011, 09:24 PM   #157
chapster
chapster's Avatar
Rob,
you did not mention anything about driver side motor mount or requirement of notching the frame for tie rods. Can you confirm that the only modification required is the lip on the crossmember and the frame steering shaft hole/frame clearance.
A complete install pic would really be nice prior to us phoning for the discounted price.
Looks good so far
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 06-08-2011, 10:12 PM   #158
chapster
chapster's Avatar
Taking a second look I see that in the pic for making clearance on bottom frame leg for the rack that the rack boots will be well bellow frame.
Old 06-08-2011, 10:14 PM   #159
robnolimit
robnolimit's Avatar
Originally Posted by chapster View Post
Rob,
Looks good so far
Thanks, in the beginning it looked like a motor mount mod was in the cards. But, with a few changes to the rack mounting for input shaft position, and using a three U-joint steering system, this is no longer needed. No notching the frame for the tie rods. If you look at the bearing mount picts, we use the 'forward' hole on the top of the frame as a starting point for the pass through hole. There may be some motor mounts that interfere with this, but the stock V-8, and all of the aftermarket mounts use the back two. (I think the forward hole may have been for 6 cyl mouns. Any info?) We have done a lot of test fitting on all three series - 63-66, 67-72, 73-87, and only about 1/3 of the trucks need the little bit of rack clearance, ALL of the trucks need the clearance for the lower U-Joint.
Old 06-08-2011, 10:17 PM   #160
robnolimit
robnolimit's Avatar
While we will be taking pre-orders, progress on this instal will take a short break, (thurs,fri) as we have a install certification class going on. We will finish the install and test drive tuesday ad Adams Motorsports Park.
Old 06-08-2011, 10:44 PM   #161
Tmend
Tmend's Avatar
So will I be able to use my factory inline 6 power steering pump and hoses with this kit.
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 06-08-2011, 10:44 PM   #162
rob32472
I am in calling in the morning
Old 06-08-2011, 11:07 PM   #163
robnolimit
robnolimit's Avatar
Yes, that pump is fine, you wil need to change the end of the pressure hose. Does the six cyl mount use the back two holes? (there are three on the top of the frame)
Old 06-08-2011, 11:40 PM   #164
Tmend
Tmend's Avatar
Rob call me 8187939713 Thomas ill check out the frame over the phone
Old 06-09-2011, 01:01 AM   #165
Tmend
Tmend's Avatar
If your talking about the holes where the engine stands bolt to yes. My inline 6 bolts up to the 2 closest holes towards the fire wall.
Old 06-09-2011, 01:12 AM   #166
Tmend
Tmend's Avatar
http://67-72chevytrucks.com/vboard/a...3&d=1305320484. This post shows a pic hope it helps.
Old 06-09-2011, 01:13 AM   #167
Tmend
Tmend's Avatar
Does this mean I won't be able us the kit?
Old 06-09-2011, 02:00 AM   #168
Project1970
14.1 @ 96MPH
Project1970's Avatar
The way I read it, if your mount is in the rear two holes, you're set. Mine is in the front two.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 06-09-2011, 12:19 PM   #169
Fastfun
Fastfun's Avatar
Just ordered mine!!!!!
Fastfun is offline   Reply With Quote
Old 06-09-2011, 12:20 PM   #170
dnd1978
dnd1978's Avatar
My order is in.
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 06-09-2011, 01:52 PM   #171
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
crap.....this means I'd have to relocate the motor/trans and shorten the d-shaft.
my mounts are in the front holes...which I thought was the proper sbc mounting location?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-09-2011, 05:39 PM   #172
rob32472
Ordered mine...... Only a couple left so the operator says
Old 06-10-2011, 02:32 AM   #173
Project1970
14.1 @ 96MPH
You and me both. I can't remember what position my towers were in before the LS1, but I've got a ground running to the rear hole on the driver's side that I think has been there for ages (i.e. long before the LS1).
Looks like I'm back to my plan of ditching the rag joint for a U-joint and getting a quick ratio steering box. Shame, this does look nice.
Old 06-10-2011, 08:46 AM   #174
rob32472
In looking at the kit seems as if it would be simple enough to modify the steering linkage to work with front mounting hole. The mounting and other components are the hard part with a little tweaking this should work fine.
Old 06-10-2011, 04:37 PM   #175
robnolimit
robnolimit's Avatar
We took a look at that, and it seams that if you moved the pass through hole back, to be centered between the front two holes, everything would work fine. This would require drilling through both the motor mount and the chassis.
