Old 02-17-2016, 08:33 PM   #151
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: Mike's 60 Suburban build
Man! Looking really good!...Now is when the real work begins! A good paint-job is easy when EVERYTHING is prepped correctly/perfectly!!!
Modges'66 is offline   Reply With Quote
Old 02-29-2016, 04:50 PM   #152
mikesacs
mikesacs's Avatar
Tried some rust prevention ideas on the new front fender. I cut a copper tab to fit under the support. It is sloped to divert the dirt entering from the top. Seam sealer was used to fill the gap at the front edge of the support that faces the tire. I left the two weep holes at the bottom of the support open. Then coated everything with 3M undercoating.
mikesacs is offline   Reply With Quote
Old 03-01-2016, 06:58 AM   #153
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
nice work!
I drilled a hole at the very bottom under the lowest mounting bolt to let any water or dirt drain out and keep it from rusting out
gostranger is offline   Reply With Quote
Old 03-07-2016, 11:14 AM   #154
mikesacs
mikesacs's Avatar
I've been sanding a lot lately!
Old 03-07-2016, 11:27 AM   #155
mikesacs
mikesacs's Avatar
It doesn't look much different, but it is. My basic primer process so far is grey epoxy primer, then tan high build primer sanding with 120, high build and 180, high build and 320. Then I go over everything lightly with 400 or maroon scuff pad depending on if it's flat or hard to sand. If I sand through to metal then I spray grey epoxy first. If I was an experience body man, I probably would have used fewer layers of high build. It is amazing to see the body get better every time. I have many of the parts completely sanded. The hoods, hatch, and body are on the last sanding (I hope).
It's nice to use the two colors. As soon as the tan looks transparent I stop.
Old 03-07-2016, 04:00 PM   #156
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Question: Why are you prepping two different hoods?
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 03-07-2016, 04:58 PM   #157
mikesacs
mikesacs's Avatar
I bartered for a second hood thinking it was in better shape than the one I had. It turned out to be similarly rusted and dented. Each took 5-6 metal sections to be replaced. I decided to use it as my auto body practice hood and try each step out on it first. It's come to the point that I'll just put the best one on my burb.
On an interesting note, I did find that the two hoods are slightly different. One is a 60 and the other a 61. It might be due to the year or a different manufacturing plant. The angle of the slope down to the middle flat section is steep on one and more rounded on the other.
Old 03-16-2016, 09:09 AM   #158
mikesacs
mikesacs's Avatar
I sealed my drip rails with Eastwood's 2K self leveling seam sealer. You do need to use it pretty fast so it doesn't harden in the mixing tube. It worked really well in all the flat areas. It took 2 tubes to do the entire drip rail. I used a thicker seam sealer first in the rear corners where the drip rail has a steep incline. A little wax and grease remover on paper towels was used to clean any mistakes as I progressed.
The burb is now in the paint boot and I hope to spray the interior this weekend.
Old 03-22-2016, 07:40 AM   #159
mikesacs
mikesacs's Avatar
The inside and outside are now painted. The interior colors are the very close matches to the original metallic silver and metallic charcoal. I did a clear gloss finish over everything and then went back with a flat clear over the dash. I still have 2 more loads to paint in the booth. I hope to have that done this week.
Old 03-23-2016, 06:42 AM   #160
gostranger
gostranger's Avatar
wow looks great!!!
Old 03-23-2016, 06:49 AM   #161
The_Hub
The_Hub's Avatar
I love that body line paint. I just read through your whole build. Seems like you've got it together. I'd love to get the same two tone set up on my '60 but with a flat original yellow and white up top. I'll be checking back in on this one for sure.
"There are seven days in a week. Someday isn't one of them."
http://67-72chevytrucks.com/vboard/s...d.php?t=686078
The_Hub is offline   Reply With Quote
Old 03-23-2016, 08:01 AM   #162
mikesacs
mikesacs's Avatar
I want it to look somewhat original, but I didn't like the 1960 two tone paint line. This paint line was done later than 1960. It looks much better.
I have the doors, tailgate and hatch along with a bunch of small parts in the booth now. I hope to paint them tonight.
Old 03-23-2016, 08:49 PM   #163
piratexpress1369a
piratexpress1369a's Avatar
Looks awesome
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 03-24-2016, 02:55 PM   #164
mikesacs
mikesacs's Avatar
another load in the paint booth. One more load to go!
Old 03-25-2016, 06:51 AM   #165
notsolo
notsolo's Avatar
Burb is looking Great, Paint turned out awesome.. did you find some gray seat belts, or are you going with a different color?
notsolo is offline   Reply With Quote
Old 03-25-2016, 07:53 AM   #166
mikesacs
mikesacs's Avatar
I found a business online that will replace the webbing in my seatbelts. I think I'll go with charcoal webbing and then spray the plastic base with charcoal vinyl spray paint. I need to contact the company and make sure they will do it.
Old 03-25-2016, 06:15 PM   #167
rwade
rwade's Avatar
What is the green paint color code and name? Love it
Wade
rwade is offline   Reply With Quote
Old 03-25-2016, 09:16 PM   #168
mikesacs
mikesacs's Avatar
Wade
The paint is Nason spectramaster. They don't have names except the white , but the codes are:
Green GS069, white 546840 (India Ivory), silver metallic 658282, charcoal metallic 344708.
I think the green looks like olive in the bright light and avocado in indirect light.
Old 03-25-2016, 10:09 PM   #169
rwade
rwade's Avatar
Is that made by PPG paint? I appreciate the info. It's gonna be awesome when your done.
Wade
Old 03-25-2016, 10:29 PM   #170
Classic v6 GMC's
Classic v6 GMC's's Avatar
Paint looks great!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 03-26-2016, 07:36 AM   #171
mikesacs
mikesacs's Avatar
Wade
I think Nason is the economy paint line from DuPont.
Old 03-28-2016, 07:42 AM   #172
mikesacs
mikesacs's Avatar
I painted the last load in the paint booth and started on interior assembly. I did find a piece of the steering column that I forgot to paint.
Old 03-28-2016, 08:18 PM   #173
kchampagne
kchampagne's Avatar
Awesome job!! I love that green and ivory combo!!! I was thinking about a dark blue and ivory for my burb, but your colors having me rethinking my plan.
kchampagne is offline   Reply With Quote
Old 04-04-2016, 07:52 AM   #174
mikesacs
mikesacs's Avatar
I've been bolting everything back together. I still have all the glass to do and my high beams are not working. A relay went out, but it could be caused by a pinched wire.
All my door window felt is on back order. If I don't hear anything by tomorrow, I'll cancel my order and try another company.
I did buy the felt and gaskets for the side slide window. I looked at them again and decided to postpone rebuilding them. I've been postponing other projects for 6 months and decided not to spend 1-2 weekends rebuilding the sliders now. I'll just bolt them back in and plan a rebuild when I do the headliner in the future. The bottom rail is rusted out and it looks like I'll need to replace it with new metal.
I have an appointment with a glass shop to install the other 4 pieces of glass this Thursday.
Old 04-04-2016, 08:39 AM   #175
Classic v6 GMC's
Looks great!!!
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
