Old 09-24-2012, 09:02 PM   #151
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: My Unexpected '66 SWB-Fleet-Restomod Project!
Originally Posted by Bomp View Post
Great heads up. I have been kickin around the idea of power windows too. You always pull it off so nicely when an obstacle gets in the way.
Hey now!
I did a bunch of R&D work,(none) and I am sure that it will all work out!
BTW...I do look slick, but my door switches look slicker!...Just noticed the typo.
P.S. Obstacles are just an opportunity to polish one's skill level!
Modges'66 is offline   Reply With Quote
Old 09-25-2012, 09:33 PM   #152
Modges'66
Modges'66's Avatar
I started to work on widening my rear wheel-tubs.
I want to confirm the fact that I can get at least a 20 x 10 wheel under this thing without buying some custom offset wheel...If I'm buying custom offset wheels, I want for it to be because I WANT to, and not because I NEED to.
So here is the quick story on that:
1.) Cut the tubs in half.
2.) Bend up a piece to extend them.
3.) Weld them back together.
Sounds pretty easy, right?...What a pain in the a$$!
I learned a lot. I learned that I wish that I had about 3 sets to widen, as I could throw the first 2 sets away! And that I will get good at this at about the same time that I am finished!
I suppose that it is like anything, practice makes perfect!
Old 09-25-2012, 09:55 PM   #153
Modges'66
Modges'66's Avatar
Here's a few more pics.
Just 1 small draw-back....I still have 1 more to do this to. (I didn't want to ruin both of them at once)
Old 09-26-2012, 08:40 AM   #154
clemdaddy
clemdaddy's Avatar
nice work... wheel-wells matched up real well
clemdaddy is offline   Reply With Quote
Old 09-26-2012, 09:20 AM   #155
Bomp
Bomp's Avatar
Guess going with skinny rear wheels is out? lol Great job.
Bomp is offline   Reply With Quote
Old 09-26-2012, 05:58 PM   #156
flips72
flips72's Avatar
nice, when do you want me to send you mine?
flips72 is offline   Reply With Quote
Old 09-27-2012, 11:48 AM   #157
Modges'66
Modges'66's Avatar
Be Careful, I may take you up on that!
If yours turn out better due to my experience, and most likely they will, I will then send mine to you, and keep yours!
Old 09-27-2012, 12:16 PM   #158
1963c-10
1963c-10's Avatar
Nice job...very cool thread
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-27-2012, 06:05 PM   #159
Budman56
Budman56's Avatar
Originally Posted by Modges'66 View Post
I received my "Direct bolt-in" power window kit this week...Yeah, right. It is only direct bolt-in after you drill several holes in your door that will be exposed when the job is completed. I am NOT good with that.
After a great deal of pondering on the issue. I decided to make an adapter plate to mount the power-window mechanism to, and in-turn, mount that plate to the door in areas that would be concealed by the door-panel.
I used two of the door-panel holes as a reference in my adapter plate, to get everything into the proper location, as they did in the installation instructions.
Here are some pics of what I came-up with.
As you can see by the instruction sheet, a good deal of measuring was done to accomplish this!
hello i really like your mods to the electric windows, did you make the brackets your self, did they work? if so i would be interested in a set of your brackets.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 09-27-2012, 06:59 PM   #160
Modges'66
Modges'66's Avatar
Yeah, I made the brackets myself with the plasma cutter & A bunch of measuring...I can't say that the brackets will work perfectly for sure, as I won't put the entire door back together until after paint, i.e. hang the glass, install the weatherstrips, etc. But everything seems to line up perfectly as far as I as my measurements calculate. Probably won't know for sure until spring.
But even if I need to make some adjustments, there are a few spacers between the door & the bracket, that I can change the thickness of to get the proper alignment if needed.
The only thing that I am not sure of, is if they will vibrate & cause a rattle in the door.
I may add a rubber bumper to one area to rule this possibility out.
I'm Pretty positive that it will work just fine though!...Again, I won't know positively until painted & assembled.
Old 09-29-2012, 07:12 PM   #161
chad64chevy
chad64chevy's Avatar
how much did you widen your tubs?? i got another set of tubs, so when i get ready to widen mine they will be 3.75"-4" wider! yours look really good
chad64chevy is offline   Reply With Quote
Old 09-29-2012, 11:02 PM   #162
Modges'66
Modges'66's Avatar
Hey Chad!
Thanks for the comment.
I made my tubs 2-1/2" wider.
I looked a a guys C-10 a few weeks back that had 20 x 10 wheels on it, and all he did was cut the fender lip.
I don't want to do that, but I can't see any reason to go any wider, unless you are gonna Pro-street it...My opinion.
If you think those pics looked good, look at the ones that I will soon post-up of the tubs in primer!
Old 09-30-2012, 12:14 AM   #163
Modges'66
Modges'66's Avatar
Since I hurdled through the learning-curve in the first wheel tub, the second turned-out significantly better!
They both are to my liking, but I had a better fitting/welding sequence figured out for the second one, so virtually no warpage.
On the first, I hammered & dollied it to make it look nice, but the second was good-to-go!
I was so geeked with the results! It was so much easier to finish the second, as compared to the first one.
Here are some pics...Really happy with the end results of both!
Old 09-30-2012, 07:54 AM   #164
chad64chevy
just a heads up, incase you dont know the 67-72 wheel wells dont fit are trucks bed sides without some trimming to the inside of the bed were they bolt up at!! i had to trim mine and it comes reall close to cutting the support brace thats in there! because of the lip on the wheel well, so i just notched that lip around the area were the brace was!! the 70' steel floor on mine has the ridges in it and i just went to the next ridge to make it look kind of factory looking
the tubs look alot better in primer and yes you did do a better job on the second one!! the one thing i hate when i get to work on my truck i want it to look good, but i only work on it on the weekends so i rush myself at what i'm doing! i really dont want to do that to the body work, that and two days i have off i'm there from sun up til the sun goes down, the wife really loves it when i'm gone that long, lol!!
Old 09-30-2012, 04:12 PM   #165
Modges'66
Modges'66's Avatar
just a heads up, incase you dont know the 67-72 wheel wells dont fit are trucks bed sides without some trimming to the inside of the bed were they bolt up at!! i had to trim mine and it comes reall close to cutting the support brace thats in there! because of the lip on the wheel well, so i just notched that lip around the area were the brace was!! the 70' steel floor on mine has the ridges in it and i just went to the next ridge to make it look kind of factory looking.
Thanks for the heads-up Chad.
I have already trimmed the box-sides and welded & moved a few of the mounting holes in the wheel wells to better accommodate my application.
I liked these because they are a little taller than the correct ones, thus I can get a little lower with these.
I also only get to work on the truck on mainly weekends, as it it located about 35 miles from home. I usually work on it friday night till 10:00 p.m. Saturday all day till about 10:00 p.m. & Sunday all-day till about 7-8:00 p.m. because I need to get up at 4:00 a.m. for work.
Once in awhile I can sneak a weeknight in on it too.
I have no personal life outside of this right now...Not married & college aged kids...
Old 09-30-2012, 07:40 PM   #166
flips72
flips72's Avatar
tubs look great, mine are in the mail,
Old 09-30-2012, 09:32 PM   #167
Modges'66
Modges'66's Avatar
Ha-Ha-Ha!
Good one Flips!
seeing your post really made me laugh!!!...Seriously!
Old 09-30-2012, 10:29 PM   #168
Jeff La
How about I send you a pair and you keep the best two and send me the other two back.Pretty good deal........ LOL
Jeff La is offline   Reply With Quote
Old 09-30-2012, 10:39 PM   #169
Trsmotrhed
Trsmotrhed's Avatar
Nice build and looks like you're doing an awesome job. You got your build thread on your signature just fine.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 10-01-2012, 11:50 AM   #170
Modges'66
Modges'66's Avatar
I learned a few more things this weekend!
I learned that almost everyone wants wider rear wheel tubs, and that pretty much nobody wants to make them themselves!
LOL!
Old 10-01-2012, 12:14 PM   #171
CRGRS 66
CRGRS 66's Avatar
LOL!
Sounds like a business opportunity to me...
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-01-2012, 08:17 PM   #172
chad64chevy
LOL!
i plan on doing mine in a couple weeks, if the weather will let me, lol!! its been raining for the last two weekends when i have been off work
Old 10-01-2012, 08:22 PM   #173
chad64chevy
my kids are going to be 3 and 4 this yr. i also have a 9yr. old girl in cali. that i hope will be coming to live with me in the next week or two finely!! thats one of my biggest reasons i havent got any real updates on my truck lately, i've been trying to get her out here for awhile now!!
Old 10-01-2012, 08:34 PM   #174
Jeff La
Talking Re: My Unexpected '66 SWB-Fleet-Restomod Project!
LOL!
when I do mine I'm gonna measure tubs and tires really close, hopefully I'll get the width I want without having to do what you did.
Old 10-01-2012, 10:07 PM   #175
Modges'66
Modges'66's Avatar
And what if the wheel-maker doesn't offer the style wheel that you want with the backspacing/offset that you need?...Custom? $$$
All that I'm saying, is that you have a lot more choices of wheels if you have a little extra room...
My opinion.
Secondly, I didn't want to have to do this after it was painted & assembled.
These were the last pieces that I need to prep for paint, and my painter isn't ready to spray it quite yet.
I want 20 x 10's on the back of this thing, and I think I have my bases covered!
