Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 07-27-2012, 11:25 PM   #151
bulldog2513
bulldog2513's Avatar
Re: Project Ol' Blue
after looking, i see now that it actually did move the rear end a little bit forward in the wheel well. i never would have figured simply flipping the axle would alter the placement that much. i have to say that i am intrigued in this learning experience. thank you so much for your input dragginmetal. you have taught me something.
I'd Rather Push My Than Drive A Floppy Ol' Ford
1988 GMC Sierra SLE, 2 door, shortbed (Ol' Blue) (http://67-72chevytrucks.com/vboard/s...d.php?t=528216)
1995 GMC Sierra SLT Z71, ext-cab, long bed (The Beast) (http://67-72chevytrucks.com/vboard/s...d.php?t=531244)
1996 Chevrolet Tahoe LT, 4 door grocery getter (Mama's Ride)
bulldog2513 is offline   Reply With Quote
Old 07-28-2012, 08:02 AM   #152
dragginmetal
here, just not logged in
dragginmetal's Avatar
[QUOTE=bulldog2513;5509170]
no i didnt. i put them back on like they came off. i didnt measure the tire in the wheel wells before hand. i guess i took for granted that they were centered from the factory. this is my first time doing an axle flip. so by your pic it looks like i measure forward 1" from the center of the existing holes and drill new ones?
Yes
and on the plate that goes between the top of the u bolt and the spring...will that still allow the u bolt to properly seat on that plate?
Yes, your looking at the top down in my pic. The U-Bolts sit where the red lines are.
it looks like your hole is drilled in the seat rise.
Yes
and with the holes being offset will the retention strength still be there?[QUOTE]
I dont know but every "Flip-Kit" on the market pulls the rear end back.
dragginmetal is offline   Reply With Quote
Old 07-28-2012, 11:54 AM   #153
bulldog2513
thank you very much. ill get that done today sometime. you have a been a HUGE help.
Old 07-28-2012, 04:32 PM   #154
dragonwrecker
dragonwrecker's Avatar
I will have to admit with all the flips I have helped with this is the one detail that I have never noticed. So with that said I too have learned something here.
I would rather push a than drive a junky ol ford!
my build thread project dragons breath http://67-72chevytrucks.com/vboard/s...d.php?t=526625
please read my emergency dept thread http://67-72chevytrucks.com/vboard/s...98#post5442798
dragonwrecker is offline   Reply With Quote
Old 07-28-2012, 07:16 PM   #155
bulldog2513
got-er-did! took the rear end back out, drilled the holes and set her back 1". the drive shaft mounted up perfect! (thanks dragginmetal) dragonwrecker got the parking brake hooked back up and we bled the brakes out, then took her down the road. dang what a rough ride LOL need to get me a set of drop shocks and that's that. once i get them on i may have a clearance issue with my brake lines where they attach to the pumpkin. (didnt have that issue before i learned the rear end was too far forward hehe) have to see when i get the new shocks on. and another good thing.....my son actually came out and worked on it with me some. which he BETTER since this truck will be passed down to him one day. GOOD TIMES!
NOTE: in the second pic you can see im out there working with my cast shoe on for my broke toe. yeah i know....im dedicated to my build
Old 07-28-2012, 07:21 PM   #156
bulldog2513
here are some daylight pics of her new stance......
Old 07-29-2012, 09:10 PM   #157
dragginmetal
No problem. Glad i could help. It's looks good dropped.
Old 07-29-2012, 11:21 PM   #158
bulldog2513
thanks. the 4" shackles just wasnt doing the trick. im actually thinking the front is a little high now. if it is its not by much. have to get the bed back on and get it out on level pavement. if so i think ill just cut a little bit out of my front drop springs to bring it down. thats all i have on the front drop. everything else is stock. any thoughts on that? i guess i should wait to get the drop shocks on to see how it sets complete?
Old 07-31-2012, 10:47 AM   #159
dragginmetal
You can cut 1 full coil off. Thats good for around 2". Any more and you might run into your coils being to short. I've read and allways been told, if you get them to short they can come out while driving. Never seen this tho. The common way is spindles with drop coils or spindles with 1 coil cut off stock coils. This set up is good for around 4" of drop. You will need drop shock when you go more than 2" in the front. You can do a search on this site for cut coils. There's a ton of info on it and a lot of debates over whether or not you should cut a coil or buy drop coils.
Old 07-31-2012, 10:53 AM   #160
dragonwrecker
He has drop could on the front now but they still may not be quite enough
Old 07-31-2012, 11:15 AM   #161
dragginmetal
Drop coils alone are not gonna get him low enough. Even if he cut them enough, more than likely he'll never get the wheels aligned right. Keep in mind, i'm not saying it cant be done, just IMO he's not gonna like the outcome.
Old 07-31-2012, 11:33 AM   #162
dragonwrecker
im with you i told him to get a set of spindles to go with them now that the rear is done.i was just chiming in on the springs to get you to say what you just did
Old 07-31-2012, 12:23 PM   #163
bulldog2513
yeah i have drop coils and i [I]believe[I] that they are 3" drops. i was figuring if i did cut em it would only need about a half coil out. also thought about adding drop spindles to go with em if need be. ill do a search on here and check all options. thanks.
Old 08-02-2012, 06:38 PM   #164
98GMCSierraGuy
Hey there was a guy over here selling a chrome grille
98GMCSierraGuy is offline   Reply With Quote
Old 08-02-2012, 07:24 PM   #165
bulldog2513
still trying to figure out if im going custom chrome or a customized grill with body color. had a custom chrome over here for 100 bucks but its gone. how much did he want for it and what kind was it?
and where the heck you been? aint heard from ya in a while lol hows the green machine coming along?
Old 08-02-2012, 07:26 PM   #166
98GMCSierraGuy
$75 it was a chrome one like mine in mint condition he also had a painted one I was looking at now it can't find either. I'll let you know if I find them again.
Old 08-02-2012, 07:29 PM   #167
bulldog2513
thanks. you check out my finished frame work? shes ridin low now lol
Old 08-02-2012, 07:30 PM   #168
98GMCSierraGuy
Yeah man she lookin so fine I use to want mine that low
Old 08-02-2012, 08:54 PM   #169
bulldog2513
man im 42 and this is the first one ive ever lowered. im a redneck so ive always put em in the air lol
Old 08-02-2012, 08:57 PM   #170
98GMCSierraGuy
I was 14 when I wanted to I'm not much for lifted trucks They're good I wouldn't want one I guess I've changed a lot in a year lol
Old 08-02-2012, 09:06 PM   #171
bulldog2513
yeah just wait till you turn 16 and start driving her around and all the ideas start flowing rapidly through your mind lol heck with ol blue i had her stock height, then beefed up the rear suspension equal to a 1 ton for hauling and towing, then lifted a lil bit with 31's and now......well you see her now its a never ending revolving door of ideas lol
Old 08-02-2012, 09:08 PM   #172
98GMCSierraGuy
I'm already like that haha
Old 10-24-2012, 05:09 PM   #173
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
Updates?
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 12-03-2012, 09:56 PM   #174
bulldog2513
no updates as of yet. been having financial issues and no time. shes still sitting the yard lookin pretty (well in my eyes anyway)
Old 12-03-2012, 10:58 PM   #175
98GMCSierraGuy
Bulldog! were have you been?
