07-06-2016, 09:30 PM | #151 |
Re: LIL ERV the 50
I saw your question on the door window install and came across these pictures from MotherTrucker on the Hamb, hope they help.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
07-07-2016, 05:33 AM | #152 |
Re: LIL ERV the 50
wow! thank you.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
07-12-2016, 06:36 PM | #153 |
Re: LIL ERV the 50
Installed the new gages today.
07-12-2016, 06:42 PM | #154 |
Re: LIL ERV the 50
nice, those are about the only aftermarket gauges I can stand. They look good.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
07-12-2016, 07:41 PM | #155 |
Re: LIL ERV the 50
thank you! they are a nice fit.
07-22-2016, 05:46 PM | #156 |
Re: LIL ERV the 50
A little more done, Assembling front clip and running wires. Should have all parts back from paint tomorrow, And yes its hot here 92 in garage with fans.
07-22-2016, 11:41 PM | #157 |
Re: LIL ERV the 50
coming together. So hot here too, Im dreading working tomorrow in the humidity. I have to go buy a fan cause I don't have a work fan. keep it up, you'll be cruising soon.
07-27-2016, 06:53 PM | #158 |
Re: LIL ERV the 50
So today I set the new glass in the frames with setting tape. I did a small how to on this, hope this helps someone.
The new tape has a cloth face and a rubber back with a peel off liner, there is no adhesion on the tape. Place rubber side on glass and use electrical tape to hold it on. Cut small notches at corners as you go around the window. Slide window in frame, It may be snug so tap easy, I put mine on a bath towel. Leave the tape on it's so thin its fine. Assemble then take a razor blade and trim around the frame and your done.
07-27-2016, 07:35 PM | #159 |
Re: LIL ERV the 50
nice job
07-27-2016, 08:45 PM | #160 |
Re: LIL ERV the 50
Good tutorial, looks very nice!
07-28-2016, 05:31 AM | #161 |
Re: LIL ERV the 50
thanks
08-12-2016, 07:20 PM | #162 |
Re: LIL ERV the 50
So today I put the wind lace in, not a fun job so after trying dish soap,Vaseline,WD40 I found the perfect stuff to use. The goop that electricians use to pull wire. Menards has it and it worked perfect.
Be liberal in its use you cannot use too much. Goop the back of rubber then do the tracks and outside of tracks.
08-12-2016, 11:20 PM | #163 |
Re: LIL ERV the 50
looks great!
I wish more things applied to this advice!
08-13-2016, 02:21 PM | #164 |
Re: LIL ERV the 50
I have used that to pull cable, good idea!
Be sure to wipe up the excess before it dries, seems like it desolves with water
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-13-2016, 06:49 PM | #165 |
Re: LIL ERV the 50
Works great and cleans up with a damp rag.
08-13-2016, 07:16 PM | #166 |
Re: LIL ERV the 50
good job, I just screwed mine in. Wasn't wanting to go in, maybe I'll have more patience next time and try this!
08-14-2016, 08:43 AM | #167 |
Re: LIL ERV the 50
10-27-2016, 05:51 PM | #168 |
Re: LIL ERV the 50
So today I finished running the fuel and return lines.
I put a large canister filter in back and a 40 micron in front of carb. I ran aluminum lines down the frame rail.
02-22-2017, 07:26 PM | #169 |
Re: LIL ERV the 50
Rear brake lines in and radiator in, Getting close now!
02-22-2017, 11:36 PM | #170 |
Re: LIL ERV the 50
nice, just in time for spring!
06-17-2017, 04:58 PM | #171 |
Re: LIL ERV the 50
Its been a while but more work this week.
Shifter and boot+ring in. Under dash A/C in, still have to plumb it. Parking brake handle, lines in. Engine hoses, fuel, vacuum in. Carpet in.
06-19-2017, 10:48 PM | #172 |
Re: LIL ERV the 50
looks good! I bet you are chomping at the bit to run with it.
06-20-2017, 06:27 PM | #173 |
Re: LIL ERV the 50
ah the final stretch, can seem never ending too!
06-22-2017, 12:49 PM | #174 |
Re: LIL ERV the 50
getting close!
09-16-2017, 04:50 PM | #175 |
Re: LIL ERV the 50
Getting closer, however the hyd clutch does not engage far enough to shift. Going to have to look for a longer throw. But it sounds sweet!
