Old 09-04-2014, 11:33 PM   #151
steve aleve
Re: You guessed it, 1950 s10 swap.
That's all great info. Thanks guys!!! I know the truck intake will provide more power but I ended up snagging an ls1 intake, rails and injectors. I'm not overly worried about horsepower and part of the reason I went with an ls is cause I love the look of the ls1 with the rail covers in a truck like this. I have an l98 350 supercharged that I decided not to use in lieu of the ls. I can already see the dollar signs add up but it will be exactly what I wanted. All rambling aside, I wanted to know what you did for your steam lines and did you use the truck throttle body? Now I've gotta keep my eyes out for a 4l60e trans. All of the newer silverados and sierras are stripped to the bones within minutes of hitting the yard and I'm too ignorant to know what other vehicles have the same trans (able to use with no mods). Any thoughts or ideas would be much appreciated!!! Thanks again and this thread is my motivation.
steve aleve is offline   Reply With Quote
Old 09-09-2014, 12:19 AM   #152
dirtybirdindian
dirtybirdindian's Avatar
Originally Posted by Layedoutsonoma91 View Post
Updates!!!
How wide are those whitewalls?
1953 3 Window Short Box
dirtybirdindian is offline   Reply With Quote
Old 09-09-2014, 01:00 AM   #153
Layedoutsonoma91
Layedoutsonoma91's Avatar
I used the truck throttle body. The steam ports i ran a line to the waterpump spacers i used. I tapped the spacer.
The white walls are 2 inches i think
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 09-09-2014, 07:32 AM   #154
tattooedblue
Looks Awesome!!
tattooedblue is offline   Reply With Quote
Old 09-14-2014, 08:59 PM   #155
Layedoutsonoma91
Thank guys. Havent been working on it layely been so busy. More updates soon
6.0 ls swap/4l80e
Past build thread
Old 09-17-2014, 05:49 AM   #156
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Subbin in for this awesome build
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 09-21-2014, 12:19 AM   #157
steve aleve
Dude I don't know where I would be without your build. So I got the block back together and the ls1 intake in and it's looking like the fuel rail is going to hit the coil pack on the drivers side. Did you run into this?
Old 09-21-2014, 12:24 AM   #158
Root2812
Root2812's Avatar
Truck coil packs and ls1 fuel rails? You will run into that. Just lightly bend the fuel rail nipple up to clear the coil pack. Its a simple fix and commonly done over on ls1tech.com
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 09-21-2014, 01:29 AM   #159
steve aleve
Awesome thanks!!!! I guess I should spend a little more time over at the ls1tech forums. Thanks again
Old 09-22-2014, 01:31 PM   #160
Layedoutsonoma91
I had to bend the fuel rail up a little. No big deal just dont kink it.
6.0 ls swap/4l80e
Past build thread
Old 10-10-2014, 12:13 AM   #161
whiteheadcycle
Great looking truck! I would change a thing. Just curious if you could give me a lenght of your lower 4-link arms (center of axle tube to center of front mounting bolt. I'm trying to rap-up my suspension work while in the proses of getting the title for my 55 1st ser. I don't want to tear the body off untill I have that title in my hand. Also what backspacing are you running front and rear on your wheels?
whiteheadcycle is offline   Reply With Quote
Old 10-10-2014, 12:17 PM   #162
tlorber
tlorber's Avatar
Layedout,
Can I please get some specs on the steering column you used? Brand, length etc.
Your headers look like the same ones I bought, so I figure if your linkage clears, I should copy it. Did you move the steering hole in the firewall from the stock location?
Thanks for any input you can supply.
tlorber is offline   Reply With Quote
Old 10-10-2014, 06:52 PM   #163
Advanced Design
Advanced Design's Avatar
Awesome truck and great job on the build! Thanks for sharing it.
Advanced Design is offline   Reply With Quote
Old 10-10-2014, 06:58 PM   #164
Layedoutsonoma91
The lower link bars are roughly 21.5 inches center hole to center axle. They are adjustable ends tho and can be changed. I also moved my front leaf spring perch back about 5 inches. Not sure on my back spacing 15x7 with s10 back spacing. I have spacers on front and 4x4 rear end.
6.0 ls swap/4l80e
Past build thread
Old 10-10-2014, 07:01 PM   #165
Layedoutsonoma91
Originally Posted by tlorber View Post
Layedout,
The steering column is an ebay one. I have no clue on how long it was. I think it was 46"?? Dont quote me tho. I moved the firewall hole down where it was in the floor part more. None of it in the wall portion. Also moved it over about an inch to the driver side to clear the headers better. I had to buy a couple joints and fab the linkage to make a turn around the headers anyway.
6.0 ls swap/4l80e
Past build thread
Old 10-10-2014, 07:33 PM   #166
whiteheadcycle
Thanks for the info! Are you still using the small tank (13.3gal) that came with the s10 or did you move up to the 18gal tanks? Also what setup did you use for the fuel pump?
Old 10-11-2014, 10:59 AM   #167
tlorber
tlorber's Avatar
Ok, thanks for the reply.
Old 10-19-2014, 11:21 AM   #168
Layedoutsonoma91
Still using the stock s10 tank. The transmission took a dump on me. On the search for a rebuilt 4l60e now....
6.0 ls swap/4l80e
Past build thread
Old 10-19-2014, 11:40 AM   #169
99 to Life
99 to Life's Avatar
sorry to hear about the trans. are you running a standalone harness for the trans?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 10-19-2014, 11:45 AM   #170
Layedoutsonoma91
Im using the stock harness for everything
6.0 ls swap/4l80e
Past build thread
Old 10-19-2014, 11:51 AM   #171
99 to Life
99 to Life's Avatar
right on, so with that are you only able to run the 60e? could you run an 80e?
Old 10-19-2014, 12:12 PM   #172
Layedoutsonoma91
To use a 4l80e i would have to change the harness. Also the yoke is different and i would have to remake the trans crossmember. Then i would have to buy a shifter. Mine wouldnt go over a 4l80
6.0 ls swap/4l80e
Past build thread
Old 10-19-2014, 09:51 PM   #173
99 to Life
99 to Life's Avatar
cool, good to know. haven't dove into that info yet.
Old 10-31-2014, 07:32 PM   #174
mr incredible
mr incredible's Avatar
find your trans yet
USN RETIRED
there are two things you don't need in the navy. that's a wife and a pick up truck. cause when your out to sea someone else is using them
mr incredible is offline   Reply With Quote
Old 11-21-2014, 08:18 AM   #175
pigpin
Looks great. I'm just getting started on my '51. What size are the tires?
pigpin is offline   Reply With Quote
