#151 |
Junk Yartist
Re: Crewcab "the rolling resume build"
Wow. It's been a little bit since I updated this, huh. So here I am, looking at what to do with the rockers, and I get this crazy heavy-duty idea. Since they are going to be so long, why not run a length of 0.125" wall tube? Something like this crude drawing. I will have to figure out what diameter tube I can use to make it look right, but I think it would be good for strength. Thoughts?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#152 |
I happened to come across this build thread this evening. I have been using your NP205 rebuild thread...Big thank you BTW for that one!! And decided to click on one of the other links in your sig. I think this is an amazing project!! And will be checking in regularly to see the on going progress.
#153 |
The outter rocker is as strong as it needs to be already, I think it would be a waste of time.
It would also give water an extra place to collect and cause rust. Last edited by Xeen; 09-24-2013 at 01:04 AM. |
#154 |
Great build, looking forward to seeing more progress.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 ![]() |
#155 |
67cheby
![]() Join Date: Sep 2008
Nice work !
#156 | |
6>8 Plugless........
![]() Join Date: Sep 2007
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#157 |
Back to the truck. cleaning up the frame and the dana 60.
#158 |
Looks good! Enjoy the no snow.
#159 |
Junk Yartist
Only when working outside off the clock.
Here's one more.
#160 |
Looking good! I wish I was closer to you
#161 |
Junk Yartist
New king pins, king pin master kit, axle shaft seals, and cross over steering arm. Once we figure out M14 studs for the hubs, we'll hang this hog.
#162 |
Junk Yartist
So one of the hold ups to getting the chassis to a roller has been studs. The rear axle is a 2006 AAM 10.5 with M14-1.5 studs, while the front is a 1982 Dana 60 with 9/16-18 studs. The original thought was to convert the front studs to metric to match the rears. Out comes the Dorman catalogue...
The 77-91 GM Dana 60 uses 610-283 ![]() Knurl 0.650" Length 2.53125" Shoulder 0.9375" Closest M14 stud for the Dana 60 610-437 ![]() Knurl 0.628" (-0.022") Length 3.0" Shoulder 1.0" The biggest issue I saw with this was that the Knurl Diameter was 20 thousanths smaller. Converting the rear seems like a better choice 2002+ AAM 10.5 (14 bolt) 610-431 ![]() Knurl 0.620" Length 3.16" Shoulder 1.378" Closest 9/16-18 stud for the 14 bolt 610-194 ![]() Knurl 0.621" Length 3.53125" Shoulder 1.3125" One reason the rear seems to be the easier choice, is that the 610-194 is the wheel stud for GM 73-91 DRW rear axles. So, the wheel studs that came out of the DRW Dana 70HD that we took off the chassis seem like a decent choice. Any input on this choice would be appreciated.
#163 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
How's the project coming?
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#164 |
Junk Yartist
Man, what's a better word for slow?
I don't think either of us have really had time to spare for anything this year! We have been slowly crossing off to-do's on getting the chassis into a roller, and then we'll probably be shifting gears, I'll work on getting the sheet metal on the frame, because I will be doing all that at my house, and my brother will probably work on selling 2 of his trucks. Next time I am down in Lancaster I will probably pick up the front and rear hubs to get them prepped for install. That's where we're stalled.
#165 |
I'll go along for the ride, looks like a sweet build. Keep up the great work
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#166 |
Junk Yartist
GM Dana 70HD DRW 9/16-18 stud on the left
GM AAM 10.5 SRW M14-1.5 stud on the right ![]() Dana 70 studs installed on 14 bolt hubs. ![]() The help messing with my settings ![]() Next time I am out at my brother's we should have the chassis in a roller.
#167 |
subscribed! Nice build!
1968 Chevy C-10 Suburban - 350/350 1969 Chevy C-10 Panel Delivery - 454/400 1972 GMC K1500 Jimmy - 350/350/np205 1978 Chevy Corvette Silver 25th Anniversary reddit.com/r/chevyc10 <-Join it! |
#168 |
Junk Yartist
Picked up a few more essential pieces of the puzzle this weekend
#169 |
So it seems like its been awhile since we've made headway on this build. We've taken on other projects that have taken way more time than I think either of us anticipated
#170 |
Both the 1ton and burb are 6.5's and I think the 1ton has permanently ended mine and my brothers relationship with the motor!!
#171 |
Now we are back on track and making progress!!
#172 |
Looking nice! That white crew needs 2 less cylinders!
#173 |
Junk Yartist
Hook it up! If I could find one for less than a kidney (hopefully with a 5 speed attached) We'll drop that 6.5 like a... well, like a 6.5.
Especially since I cant get the cab out with where the truck is sitting now. Ryan, seriously.
#174 |
More progress... next stop Ridgecrest to fit the cab!!
#175 |
Junk Yartist
Slow slow build, but not stopped...
Got one of these made for my burb, and one for this truck. That counts as progress I am leaning toward using 10-32's to hold the spring on the back. I'll punch those holes when its time for that. ![]()
