Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 03-18-2019, 09:24 AM   #151
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1963-1966 Chevrolet & GMC C10 / C20 Aluminum Radiators!
Yes, its fine to put in on the passenger side on a downflow. We've been building this style like that for a decade with no issues.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 04-01-2019, 10:00 PM   #152
SparkyRnD
SparkyRnD's Avatar
we appreciate the support!
Old 05-03-2019, 02:20 PM   #153
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 06-10-2019, 10:14 AM   #154
SparkyRnD
SparkyRnD's Avatar
up top again
Old 06-27-2019, 09:30 PM   #155
SparkyRnD
SparkyRnD's Avatar
back up again
Old 07-19-2019, 05:57 PM   #156
SparkyRnD
SparkyRnD's Avatar
remember to ask for your discount when ordering
Old 09-05-2019, 11:21 AM   #157
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 10-16-2019, 10:20 AM   #158
SparkyRnD
SparkyRnD's Avatar
up top!
Old 12-23-2019, 10:36 AM   #159
SparkyRnD
SparkyRnD's Avatar
Thanks for the continued support, we appreciate it!
Old 01-18-2020, 10:27 AM   #160
rodstored-72
chevy truck fan
rodstored-72's Avatar
Hi,
I have a 86 2wd C10 with a 4.8/4L60. I am looking for a reliable radiator/fan setup (this is a daily driver), I have a VA air conditioning unit. Can you please give me recommendations for a good radiator here in the desert? The engine is stock W/O any upgrades. ��
Thanks ��
rodstored-72 is offline   Reply With Quote
Old 01-20-2020, 02:19 PM   #161
SparkyRnD
SparkyRnD's Avatar
Sure, our standard radiator will be fine for that. With A/C and being in the desert, I'd go with our upgraded single 17" dual-speed fan. I assume you'll use the PCM / LS harness to control the fan?
Old 02-17-2020, 08:19 PM   #162
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have an LT L83 with Ac and in Tx, what would you suggest and could you PM me the cost please?
I would like the best shroud & fan option also.
Clyde65 is offline   Reply With Quote
Old 02-19-2020, 10:59 PM   #163
scf100
scf100's Avatar
I see your located outside of Atlanta I am in Athens,
I am working on a 1970 Blazer 2WD factory 6 cylinder but PO dropped in a 454 stroked to a 496 and automatic no ac.....not hooked up yet so not running
What radiator, shroud combo do you have for this setup
1970 2WD Blazer 454
1972 C-10 Extended Cab 350 SBC
scf100 is offline   Reply With Quote
Old 03-13-2020, 11:38 AM   #164
SparkyRnD
SparkyRnD's Avatar
sending PM shortly.
Does the 6-cylinder use the same radiator mounting / supports as the V8? If the width and mounts are the same, it'll be easy. If you wish, you can PM me pictures and a few measurements to confirm.
Sorry for the delayed reply, the forum didn't notify me there were replies.
Old 03-23-2020, 10:01 AM   #165
SparkyRnD
SparkyRnD's Avatar
up top!
Old 04-22-2020, 09:48 AM   #166
SparkyRnD
SparkyRnD's Avatar
we can build radiators for most any application!
Old 05-05-2020, 11:13 AM   #167
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 05-27-2020, 01:00 PM   #168
SparkyRnD
SparkyRnD's Avatar
up top again!
Old 06-19-2020, 04:21 PM   #169
SparkyRnD
SparkyRnD's Avatar
remember to ask for your discount when ordering!
Old 07-10-2020, 10:23 AM   #170
SparkyRnD
SparkyRnD's Avatar
thanks for the support!
Old 07-30-2020, 06:23 PM   #171
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 08-26-2020, 08:38 AM   #172
SparkyRnD
SparkyRnD's Avatar
thanks for the orders!
Old 09-05-2020, 10:21 AM   #173
SparkyRnD
SparkyRnD's Avatar
we can also build radiators for most any application!
Old 09-23-2020, 11:09 AM   #174
Black66C20
Looking for a radiator, shroud and fan for a 1966 C20 build that will be running a 400 SBC built for ~500hp.
Black66C20 is offline   Reply With Quote
Old 09-23-2020, 12:32 PM   #175
SparkyRnD
SparkyRnD's Avatar
We can easily build that! pm me your zipcode and I can put together a full quote with recommendations.
