Old 05-31-2018, 05:29 PM   #151
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Sparky's 1978 Silverado Build "Addiction"
Nice work getting the pieces primed and painted!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-01-2018, 04:35 PM   #152
Gus350
68 C 10
Gus350's Avatar
What kind of paint did you use? I just read both of your projects from start to finish lol now I need a nap lol. Great work on both jayson is killing the paint on the other truck
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 06-01-2018, 04:43 PM   #153
Dads79GMC
Dads79GMC's Avatar
Summit DTM Epoxy, I believe, covered with.....1.5 quarts of Rustoleum Satin Black mixed 8:1:1 (hardener and reducer). Driver! Lol
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 06-06-2018, 12:29 PM   #154
Dads79GMC
Dads79GMC's Avatar
Should I replace this upper control arm stud? The rest of the upper control arm bolts are good. Thanks Mike
Old 06-06-2018, 12:38 PM   #155
moregrip
moregrip's Avatar
I would, probably ok but why chance it brother
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 06-06-2018, 12:41 PM   #156
Dads79GMC
Dads79GMC's Avatar
I'm 50/50 on it. My luck is that it wouldn't come out!!!!
Old 06-06-2018, 01:14 PM   #157
moregrip
moregrip's Avatar
Mine came out fairly easy, kind of like a wheel stud, I just put a sacrificial nut on the end of the stud and pounded it out (and penetrating oil)......this is for the stud that is pressed in the cross member btw, is that what you're asking about?
Old 06-06-2018, 01:43 PM   #158
Dads79GMC
Dads79GMC's Avatar
Yes, there are two studs on both sides that attach the upper control arm to the crossmember / frame. Should press in like a wheel stud.
Old 06-07-2018, 09:26 AM   #159
aggie91
I'm just glad to be here!
aggie91's Avatar
I'd replace it. Looking at the threaded portion, it appears in the picture that it has been stretched, and the corrosion has reduced its diameter in the unthreaded portion.
Better to do it now while you have it apart!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-08-2018, 12:56 AM   #160
Dads79GMC
Dads79GMC's Avatar
Great points! I’ve got four studs in the way! Thanks for the input. Mike
Old 06-19-2018, 04:22 PM   #161
Dads79GMC
Dads79GMC's Avatar
Small update!
Old 06-20-2018, 08:38 AM   #162
aggie91
aggie91's Avatar
Nice!
I see a two link and an airbag bracket too...
Karl
The LST Challenge:
Old 06-20-2018, 08:42 AM   #163
Dads79GMC
Dads79GMC's Avatar
................Observant!
Old 06-20-2018, 10:21 AM   #164
moregrip
moregrip's Avatar
Small update!
That's a nice wheel/tire combo. I think I'll be going with something similar, classic look FTW!
Old 06-20-2018, 09:24 PM   #165
Dads79GMC
Dads79GMC's Avatar
Thanks Chief!!!
Old 06-20-2018, 09:35 PM   #166
Dads79GMC
Dads79GMC's Avatar
So, got a lot done late this afternoon and this evening!!! I want to get the LS/Trans on this thing before the end of the week....lots of parts on the way!! Extensive kit front and back.
Pictures:
1. Drilling the holes for the upper air bag bracket....pain. At least the x-member wasn't on the frame and easy access!
2. Getting ready to install x-member.
3. X-Member attached and upper control arms mounted.
4. Got bored with the front and went to the rear end for a while. Test fitting panhard bar bracket. Will weld in place when I'm satisfied. I'm putting it in front of the rear end because I haven't decided if I'll put a rear tank in????? Or a narrow 6x15 spair tucked up tight, not sure that'll work???
5. Panhard test fitting. The panhard bar will attached to the frame with a welded in bracket.
1 of 2
Mike
Old 06-20-2018, 09:40 PM   #167
Dads79GMC
Dads79GMC's Avatar
2 of 2
I have not set the pinion angle, so I won't weld-in the perches to the axle tube until that is done. Haven't decided if I'm gonna remove the original spring perches????? I probably will. YA!
Pictures:
1. Up front done for the night.
2. Perches, or whatever they are called (engine stands??), are ready for install tomorrow.
3. And, a load of parts for the suspension ready for install as well.
Thanks Mike
Old 06-20-2018, 10:23 PM   #168
Jaysonb
Jaysonb's Avatar
Looks excellent Mike! Nice work!
Jaysonb is offline   Reply With Quote
Old 06-20-2018, 10:24 PM   #169
Dads79GMC
Dads79GMC's Avatar
Thanks Jayson
Old 06-21-2018, 10:05 AM   #170
aggie91
aggie91's Avatar
Looking Good!
Karl
The LST Challenge:
Old 06-21-2018, 09:31 PM   #171
Dads79GMC
Dads79GMC's Avatar
Looking Good!
Thanks Karl
Old 06-21-2018, 09:44 PM   #172
Dads79GMC
Dads79GMC's Avatar
Bottom line up front: I love the Western Chassis drop spindles. When I had the tire mounted and balanced, I told them to put sticky weights inside rather than the normal ones on the edge. My last set of spindles would just take them off at the tie rod connector with an 8" rallys. Now I need to take them back and have the wheels rebalanced with the normal weights...blah! I also manually tested the front air system...will have to remove the bump-stops....blah again!
Pictures:
1. Thought I'd have room between the bump-stop and the bag, not when deflated! off come the bump-stops.
2. Lots of room between rim and tie rod connector
3. Ready for the LS tomorrow!
4. Front shot.
5. Installed an old caliper to get a feel for the spacing.
I slammed the bags and there seemed to be plenty of room at the lower control arm for turning in both directions? We'll see when the LS is in??
Thanks Mike
Old 06-22-2018, 10:18 PM   #173
Dads79GMC
Dads79GMC's Avatar
Spent the evening taking apart the front end to remove the bump stops on the lower control arms and installing the calipers and brake hoses. I will be installing a new bump stops that work better with the air bags.
Pictures:
1. Woke up and remembered that I had this tool!!! It's a time saver.
2. Installed brake caliper.
3. Wrapped up for the night.
Thanks Mike
Old 06-23-2018, 01:11 AM   #174
BIGglaSS
BIGglaSS's Avatar
Lookin' good. I'm taking notes...
BIGglaSS is offline   Reply With Quote
Old 06-23-2018, 05:27 AM   #175
MrFinland
MrFinland's Avatar
Nice work Mike!
MrFinland is offline   Reply With Quote
