Old 02-23-2023, 01:58 PM   #151
dsraven
Re: 57 Fleetside C4 build
I also try to remask the previous masking because it seems to always have a little dust on it that blows up onto the wet paint. another good reason to use painters masking paper over other stuff, like newspaper, as the raw paper tends to offgas paper fiber hairs. using the plastic works as well but be careful with removal is it tends to shed the oversprayed paint from the plastic as it is removed and that stuff sticks to the new paint job. sometimes I eemove the plastic while the paint is still tacky, and roll it as I go, so it sticks to the plastic and doesn't come off in chunks as the plastic bends when removing. I always do a perimeter of tape around the body and then stick the masking to that so it comes off easily and then the perimeter of tape comes off after that with no masking materials attached to it. thats just what works for me. more tape used but it's cheap enough compared to fixing a problem.
Old 02-24-2023, 10:18 AM   #152
57FleetsideC4
Thank You dsraven for you comments and suggestions. I do have the underside masked off very tight so won't let overspray through. I will recheck my bodywork as I go through the painting but believe it is good. I do go through a lot of tape and always checking to see if anything is loose. Like you said tape is cheap. It will be pretty much down hill once painted and I can clean up my shop for the last time. Still trying to figure out if someone has a booth I can borrow. Looking forward to seeing it done. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 02-24-2023, 02:51 PM   #153
dsraven
I have painted stuff in my shop, as required, but even when the walls and shelves are masked off the overspray and dust clean up takes a lot of time. I used a 2x4 frame with furnace filters stapled on, the hanging furnace filter type, and put that in the garage door opening, then let the door down on top of that. then removed the windows and covered the openings in the same way-minus the wooden frame- then placed a fan outside the windows to get some ventilation going. I wet the floor down and squeegee'd it off so the floor dust is down to a minimum prior to spraying. I use a supplied air full face mask with the compressor outside in the fresh air (upwind). I use a tear away mask cover so if it gets overspray on it I can tear it off and stick a new one on. I have some smooth hardboard scraps usually stuck to the wall somewhere so I can check my spray gun pattern before spraying. I have several air dryer methods and a air supply hose large enough to supply constant pressure with no pressure drop once the gun is actually spraying. this is a common problem with home spray painting, the air supply lines are too small and the gun quick connect is also a restriction so when you give the gun a shot to check the pattern it looks good but a few seconds of constant spraying and the air pressure at the tip is too low so the pattern changes. a pair of disposable coveralls and lots of rubber gloves with a easily accessed garbage can is a must as well. I usually have a gun mixed up and another paint cup full ready to go before I start spraying. then hope there is no problems. when doing the wax and grease remover it is important to use clean, dry, not laundered with a dryer sheet, painting rags and use lots of grease remover with lots of rags so you don't wipe contaminants from one spot to the next. then allow the whole thing to flash off dry before you spray. otherwise it will be a mess because the grease remover is like a contaminant to the paint. trust me on that one. use the correct reducer for the shop temp and mix according to the instructions. a viscosimeter would be great but I don't have one and haven't had much of a problem over the years. I have sprayed a lot of cars and truck, equipment, motorcycles etc. most of them in my shop. I am lucky enough to have a paint booth available in Calgary but it isn't the cleanest place around. I try to get the last booth times for the day so it can sit in the booth overnight and then I gotta arrive right at opening so I can get it outta there.
Old 02-28-2023, 09:42 AM   #154
57FleetsideC4
Thanks for all the suggestions. I have painted complete cars in my shop. I spend a lot of time cleaning, taking all the lights down and cleaning, vacuum the walls, take everything on wheels out of the shop the wash everything down. Once I get the top and inside of the cab painted I will paint in 2 batch's. The cab with doors on, fenders and hood then the bed will be second batch. I just have to be consistent so everything matches. Steve
Old 02-28-2023, 11:39 AM   #155
dsraven
yeah, especially tough when doing a metallic paint as it blushes so easily if doing shortl passes. it's good to do a long pass, covering fender, door and out to rear of cab. that way there isn't a double layer at the overlap of the fender to the door. it does make it harder to get the passes in a nice long straight line though.
I have shelves in my shop about 18" down from the ceiling and I store milk crate style bins up there. I have pegboard below that with tools hanging. when I paint i usually hang plastic from the cieling down to the floor and staple it to the baseboard area. that way all that stuff is covered. it does get a little iffie when a gust of wind blows and the plastic tends to billow up. I also hang a tarp over my toolbox so if I need a tool in a hurry, like the paint gun has problems or an airline has issues etc, I have easy access. I store a lot of stuff in lateral filing cabinets so those are easy to plastic off. on a dry day I will wet down the lawn outside the shop and also the dirt alley behind the shop doors. I usually spray the furnace filters a little as well, so the dust will stick to them easier.
Old 02-28-2023, 11:48 AM   #156
dsraven
always good to clean those overhead door tracks before starting too, they hold dust that only drops when you're painting something, haha.
Old 03-05-2023, 07:58 PM   #157
57FleetsideC4
Thanks, I try and vacuum, blow out everything as best I can. Steve
Old 04-29-2023, 07:06 PM   #158
57FleetsideC4
Made some more progress on the truck. Got the roof, dash, glove box, ash tray and the second color on the dash. Now to paint the rest of the inside of the cab. Slowly making progress. Steve
Old 04-30-2023, 04:35 AM   #159
OKGMC4
OKGMC4's Avatar
Looks really good!
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 04-30-2023, 08:28 AM   #160
Jason 56
Nice work. You’re making great progress!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 05-01-2023, 09:02 AM   #161
57FleetsideC4
Thanks for the comments guys. It seems as I get older they take a lot longer to do. One other thing thoughts on painting the whole cab instead of just the inside. It's a stock chevy silverado dark brown and the only thing I worry about is color match painting things at different times. I guess the worse thing that could happen is paint match. Steve
Old 05-01-2023, 02:13 PM   #162
Dan in Pasadena
Dan in Pasadena's Avatar
Everything looking nice. Your color reminds me a lot of my truck when it was in it's "shop truck" look. This was before I tore it all down for a full paint job.
Mine was rattle can stuff just to get it all one color....and then I couldn't help myself. I added another color to the palette.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 08-15-2023, 07:49 PM   #163
57FleetsideC4
I am going to get this thread up to date. In May I painted the inside of the cab. It was pretty hard reaching into all the areas with hitting something but got it done. Here are some pics Steve
Old 08-15-2023, 07:55 PM   #164
57FleetsideC4
More updates this was from June. Painted the inside of the doors and door hinges. Steve
Old 08-15-2023, 08:03 PM   #165
57FleetsideC4
Another update. Painted the inside of the hood, inner fender wells,core support fillers and core support. Here are the pics. Steve
Old 08-15-2023, 08:07 PM   #166
57FleetsideC4
Another update. Painted front filler panels and the bed rails. Here are the pics. Steve
Old 08-15-2023, 08:12 PM   #167
57FleetsideC4
These are pics from last week. Painted the cab, doors, hood and fenders. Here are the pics. Steve
Old 08-15-2023, 08:15 PM   #168
57FleetsideC4
Last update for now. I pulled all the paper off, put the tires back on and rolled it outside. Now to get the bed painted. Steve
Old 08-15-2023, 08:28 PM   #169
Rickysnickers
Looks great!!!
Old 08-16-2023, 11:07 AM   #170
dsraven
that looks really good, nice job. keep the pics coming, its great to see forward motion on a project and really good to see it when the parts get put together for the final time.
Old 08-16-2023, 02:05 PM   #171
youngrodder
youngrodder's Avatar
Looking great. Final assembly is the best.
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 08-17-2023, 11:33 PM   #172
Jason 56
Looking good! I like the original white roof look.
Old 08-18-2023, 07:16 AM   #173
Oldtruckwelder
Oldtruckwelder's Avatar
Hi, The measurements I went with were 3" from the outer point of the V to the edge of the door and 3/4" from the body line to the middle point of the V. That is the same measurements on the front fender emblem 3" front fender edge to the front of the emblem and 3/4" from the body line to the lowest part of the emblem. Steve
Thank you for the V placement info !!
Somehow missed your response back all the way back in February.
Caught back up on your build, great job on your painting skills in your home garage. What type paint single stage? Clear coat / base coat?
Thinking about trying to do it in the home garage also.
JT from SC
Oldtruckwelder is offline   Reply With Quote
Old 08-18-2023, 09:28 AM   #174
57FleetsideC4
JT from SC
I used base coat / clear coat. I just clean up everything the best I can. Still got some crap in the paint but will sand and buff most of it out. Steve
Old 08-18-2023, 09:29 AM   #175
57FleetsideC4
Originally Posted by Rickysnickers View Post
Looks great!!!
Thank You. Steve
