02-06-2023, 12:54 AM | #1726 |
Post Whore
Re: Columbus..the 1957 IH 4x4..
Thanks Regan and Dale...it seems nothing's simple ..
I've ran all the wiring..checked pin locations, and continuity from plug to plug on cam and crank sensors..everthing checks ok.. guess my next step will be replacing sensors..
02-06-2023, 06:39 PM | #1727 |
Good luck Greg. I bet the crank sensor will fix it. And if it doesn’t, don’t forget a new part isn’t necessarily good.
02-10-2023, 01:08 AM | #1728 |
Post Whore
Thanks Doug. Put new crank sensor in..still wont start..hooked scanner up and it shows 0 rpm
03-09-2023, 08:10 PM | #1729 |
Post Whore
Long overdue updates...
I'm still fighting the no-crank issues.. I've done everything I know to do.. Checked all grounds...all good..doubled them up anyway Have constant 12v and key on and crank 12v Checked fuel pressure..58psi Checked crank sensor, it bench tests good and backpinned at the ecm plug it shows signal Checked cam sensor, it also bench tests good and backpinned at the ecm plug it shows signal Had 37 (haha) people telling me to change them anyway..so I did..still no crank.. Checked wire pin locations in plugs, all good Had ecm checked twice..no issues there.. put it in 2 diff trucks..both ran fine with my ecm.. Checked injectors multiple times ..all spray good.. checked injector solenoid with stethoscope, can hear them firing.. remove intake , raise up above engine ..crank it over..all 8 injectors are spraying.. Pull engine down to check cam , marks line up perfect.. still will not crank.. Pour gas in throttle..itll crank right up every time and run til poured in gas runs out.. Trying to get up with a different tuner and see if he can figure out what's going on.. Very very frustrating..so far 2 different tuners, psi tech, and 3 different mechanics all say theres no reason it wont run.. So til that happens ,on to other things...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 03-10-2023 at 12:49 AM. |
03-09-2023, 08:16 PM | #1730 |
Post Whore
When I did the exhaust, I didnt like how much side sway the pipes had,,
So i got some 3 hole mounts.. Fabbed up new support bracket.. Works great.. 3 hole mount vs the 2 hole mounts I was using
03-09-2023, 08:20 PM | #1731 |
Post Whore
Also moved the truck over to my temp paint booth..
Gonna have to touch up a few spots with epoxy primer.. Then the cab painting will happen.. Things have finally slowed down at work where I hopefully will have more free time for truck stuff
03-10-2023, 09:52 AM | #1732 | |
Just one random thought. When engine is cranking over, does fuel pressure stay at 58 psi? Since the engine runs with gas poured into it, it should run with injector sprayed gas. If it isn’t, then I am theorizing something is happening with the actual fuel supply through the injectors during crank. With a carburetor, we checked fuel pressure and volume. If a gas supply line is pinched off going to your injectors, it could display 58 psi static and drop off rapidly in crank as the injectors are firing. Or pump could be cutting off somewhat during crank. |
03-10-2023, 03:51 PM | #1733 | |
Equal opportunity joke ofender
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
03-10-2023, 04:19 PM | #1734 |
Post Whore
Doug, the way i have the gauge mounted I cant see it while I'm cranking.. but I have looked with key on shows 58psi, after cranking it still shows 58psi.. I'll need some help to monitor it while cranking..
But the injectors are spraying while I'm cranking it .. Richard..I know what you mean.. I dont have a problem with electronics..when they work..... but when they dont , I get aggravated, real quickly.. I've done several of these..but this is the 1st time I've had all these issues
03-14-2023, 05:43 PM | #1735 |
Proprietor of Dale's Corner
I wanna hear.....it runs!! Guess I should be patient.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
03-29-2023, 06:57 PM | #1736 |
Post Whore
Me to Dale..!!!.. I'm gonna do the paint 1st though..
So after getting a chance to do some sanding, I found a couple of spots on the back of the cab I just wasnt happy with.. these spots are where the inside cab brace is welded in.. it gave a high/low spot on the outer cab skin.. so I did some hammer dolley work on it and skimmed it with filler.. the drivers side was way worse than pass side.. Then after going over the cab ,I decided to just respray the whole cab with epoxy.. and high build.. So got it all resanded with 80g and started taping everything up today.. Hopefully paint coming soon This is the 2 spots I worked on .. I couldnt get it "perfect " but hopefully itll be ok
03-29-2023, 08:07 PM | #1737 |
Hey any news on this build is awesome. Keep it up and keep us informed.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
03-30-2023, 10:44 AM | #1738 |
Keep at it, thanks for the update.
04-09-2023, 11:14 PM | #1739 |
Post Whore
Well after several delays (of course) , I finally got all the sanding done,
Inventoried my primers and found that my 2k high build was bad.. probably didnt have enough to do several coats anyway, got plenty of epoxy.. so I'll hold off til next week, and grab some more high build .. I'm gonna do the epoxy, and follow that right up with high build inside the primer working window... hopefully eliminating one round of sanding So I've spent some spare time taping it up.. Hey!! Looky here...truck in a bag..!!!
04-10-2023, 05:51 AM | #1740 |
It's progress. You'll get it done. Almost on the downhill side of things now.
04-10-2023, 08:59 AM | #1741 |
"Truck in a bag". That was a clever attempt to cover up the disappointment of not being able to prime like you planned. Pun intended.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-12-2023, 04:40 PM | #1742 |
Post Whore
Primer day.....
Sorta...Well....... I reckon if theres a way to screw something up, I can find it.. Got up this morn... Mixed up my epoxy.. Laid down 3 coats...waited 40-45 min between coats... All good..epoxy layed down nice.. Plan is to come right over the top of the epoxy with the high build.. Spec sheet says 30min to 3 days window for topcoat.. Waited a full hour.. Layed down 1st coat..all good.. Waited another hr, sprayed second coat.. Went all the way around the cab ,all was going good til I got back to my starting point.. WHAT THE HECK!!!!!!!!!!!!! when I got back around the truck to my starting point I noticed this fancy paisley pattern in the primer.. Right before my eyes I watched the whole truck cab turn this pattern.. I'm bummed... dang it !!!!
04-12-2023, 05:17 PM | #1743 |
Wow! That is all I can say. You have some real talent. I don't think anyone else could make that pattern if they wanted to do so.
Sorry, but that is a true bummer.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
04-12-2023, 07:25 PM | #1744 |
Dammit! That sucks for sure. It almost looks like a chemical reaction. You seem to have the same kind of luck as I do.
04-12-2023, 07:31 PM | #1745 |
Post Whore
67C...your right..i have a "talent" alright...screwed up talent..!!haha
im gonna let it dry a few days and then start sanding and see what happens
04-12-2023, 07:35 PM | #1746 |
damn that sucks for sure. I would be kinda concerned that the primer is not bonded to the epoxy and might peel up
04-13-2023, 03:24 PM | #1747 |
Post Whore
Well...I agonized over what happened all last night...still dont know what I did wrong
I thought I may have used the wrong hardner with the highbuild..but the highbuild and hardner were both new and unused..I mixed up the 1st batch and sprayed it..while waiting for it to flash I mixed another batch..this is where I thought I went wrong.. so I poured the remaining hardner is a measuring cup.. the mix uses 4oz in my cup..there was exactly 8oz gone from the 32oz can.. so that's not what happened... so I'm back to i dont know.. But I did try some sanding.. luckily (I hope) ,it sanded well and smoothed out nicely.. maybe ,hoping, praying it's not as bad as it looks I'm gonna take it down with 220g, and (fingers crossed) I'm gonna do 1 more coat of high build and see what happens.. Now...sand sand sand.. On the brighter side, I got a call today saying my rear bumper was ready.. I dropped it off at the powder coater on Tues...it was ready this morn.. Sandblast-primer-powdercoat. Had it done in flat silver.. turned out awesome..they did a great job.. I tried to leave all the old farmer welds on it.. the beauty marks from yrs of use/abuse ,are all still there The stories this ol bumper could tell.. Gonna leave it wrapped til I get ready to mount it..
04-13-2023, 03:25 PM | #1748 |
Damn, that's gotta be a kick in the teeth Greg. Lots of work done and now need to be redone. Hate to see you go thru that but keep at it, you will come thru.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
04-13-2023, 03:33 PM | #1749 |
Sorry to hear about the primer. I hope a little extra sanding is all it will take.
On a different note, the bumper is way cool!
04-13-2023, 07:27 PM | #1750 |
Post Whore
this project has kicked me in the teeth so many times , my gums are sore..!!!..haha
like everything else , ill get thru it sooner or later
