Old 03-17-2008, 09:24 PM   #176
jlaird
jlaird's Avatar
Re: progress pics
Originally Posted by Slmd92DIME View Post
Looks very clean. I really like the way the por 15 turned out. I didnt know that they made it in silver though?? Great work
A lot of people confuse this, so I'll try to clear things up here. POR15 comes in black, clear, gray, semi-gloss black, and silver. The traditional POR15 is not UV stable, so in my eyes, I consider it basically a metal primer. So it has to be topcoated. POR15 (the company) also makes topcoats. The two topcoats I used are products called Sterling Silver and Chassiscoat Black. These topcoats are UV stable and made to go over the POR15.
jlaird is offline   Reply With Quote
Old 03-17-2008, 10:22 PM   #177
Slmd92DIME
Slmd92DIME's Avatar
Re: progress pics
Thanks for clearing that up for me I didnt know that.. I might look into it for my control arms and steering components
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 03-17-2008, 10:29 PM   #178
abadsvt
abadsvt's Avatar
Re: progress pics
Man everything looks Great!!!!! Sweet Job!!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 03-17-2008, 11:08 PM   #179
billdo
billdo's Avatar
Re: progress pics
whats with the plates on the lower a arm nor more pocket
billdo is offline   Reply With Quote
Old 03-17-2008, 11:30 PM   #180
jlaird
jlaird's Avatar
Re: progress pics
just trying the plate out. With the pocket in the a-arms I cut, my frame was laying on the ground. I decided I want the frame when layed out to not touch the ground (for safety and cosmetic purposes) so i'm hoping raising the lower bag with the plate will put my frame right where I want it.
On a side note, my other lower arms will be for sale if I decide to stay with my plated arms. PM me if interested. Also if anybody is interested in the lower plates, I want to have some made, but so far, havent got enough replies. Let me know if you want a pair. Check my other post for details.
Old 03-18-2008, 07:01 PM   #181
jlaird
jlaird's Avatar
Re: progress pics
Heres some pics of the rear.
Old 03-19-2008, 11:11 PM   #182
steveo10
steveo10's Avatar
Re: progress pics
wow, looks like the wait has paid off.
steveo10 is offline   Reply With Quote
Old 03-20-2008, 02:20 AM   #183
jlaird
jlaird's Avatar
Re: progress pics
Thanks man, yes it's getting there. Just picked up a 700r4 a couple hours ago, so the engine and trans will be in soon. Next hurdle is either running brake lines or doing the air plumbing. Any body have any reasons why one should be done before the other??
Old 03-20-2008, 04:07 AM   #184
Slmd92DIME
Slmd92DIME's Avatar
Re: progress pics
Looks really good man.. how much side to side rearend travel to you get with the panhard bar?
My Build Thread
Old 03-20-2008, 09:00 AM   #185
PBFAB.COM
PBFAB.COM's Avatar
Re: progress pics
Do them both at the same time... or just make sure you plan it out well, so they flow together when the latter is installed.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-25-2008, 03:57 AM   #186
cflvulcan
cflvulcan's Avatar
Re: progress pics
lookin good
cflvulcan is offline   Reply With Quote
Old 03-25-2008, 08:01 PM   #187
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: progress pics
Looks nice man.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 04-18-2008, 09:53 PM   #188
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: progress pics
I like this project, looking good.
I have one question, What is the vertical center to center distance for your rear 4 link bars? I know that you said they are about 30" long, but how far apart are they vertically?
Anymore updates..??
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-18-2008, 10:08 PM   #189
aggie91
aggie91's Avatar
Re: progress pics
guys, heres a pic of the 4 link mocked up. My axle is at ride height which was derived from the slam bag being a little over 6" inflated at ride height. My issue is the angle of the 4-link. I thought it is supposed to be parallel at ride height. Is it ok the way it looks? I can't move the front mount any further up.
Post #25
Got the 4-link mounted and rear bags on. I changed from going over the axle to in front. Next is the panhard bar. Just ordered it today.
Post #49
Looking at the pictures between these 2 posts, did you change the rear 4-link brackets? They look different. The fronts look the same, just flipped over. If you changed them, did you do it because the the reduced angle of the bars at ride height? Who's brackets did you use?
Thanks.
Karl
The LST Challenge:
Old 04-19-2008, 02:04 AM   #190
jlaird
jlaird's Avatar
Re: progress pics
Anymore updates..??
The vertical center to center is 5.5".
I did change the brackets and your reasoning is correct: wanted to get the bars more parallel to the ground at ride height. I designed the shape of those brackets and had them cut on a CNC.
josh
Old 06-02-2008, 04:44 AM   #191
jlaird
jlaird's Avatar
Re: progress pics
Its been a while since I updated this, so here are a couple pics. I almost have the brake lines finished. I purchased straight stainless line from inline tube and bent everything myself. I started at the rear with a flex line from the axle to the frame.
Up the frame rail. The tubing is held on by these nice little stainless clamps that came in the kit from Inline.
Here is where the rear and front lines meet. I decided to route the lines on the outside of the frame as they go up to the MC.
Heres a pic of the front crossmember line. This one took me FOREVER. This was my first time doing this, so I started my making a rough mockup with thick wire that was bendable my hand. Then I transfered that onto regular steel line. After I got that one perfect, I copied it with the stainless.
I also got the valves mounted. I was bound and determined to get them all in a neat line across this cross member. At first it didn't fit, so I had to find an all male tee to save some space. After tracking one down on the web, it fit. I drilled and tapped the crossmember to mount the valves. 16 holes! Use Loctite 545. Awesome stuff to work with.
close-up:
Here you can see my compressor mounting plate and the other end of the brake flex line:
Compressors mounted:
And two 5 gal slim and skinny's
I still have to put clamps on those leader hoses.
That's it for now. Time for some body work!
Old 06-02-2008, 04:53 AM   #192
bedsled71
bedsled71's Avatar
Re: progress pics
wow that looks awesome
bedsled71 is offline   Reply With Quote
Old 06-02-2008, 05:04 AM   #193
scotts62
One day...
scotts62's Avatar
Re: progress pics
Oh ya im diggin that
Very nice work man keep it up!
Scott
93 crew cab build
Project 62
Old 06-02-2008, 06:22 AM   #194
Frizzle Fry
Frizzle Fry's Avatar
Re: progress pics
Very nice install!
Frizzle Fry is offline   Reply With Quote
Old 06-02-2008, 06:53 AM   #195
BACKYARD88
BACKYARD88's Avatar
Re: progress pics
Looking good man. Nice and clean
-Mike Owen-
Old 06-02-2008, 08:12 AM   #196
OLDIRON69
Re: progress pics
Work of art!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 06-02-2008, 09:17 AM   #197
Slmd92DIME
Slmd92DIME's Avatar
Re: progress pics
Turned out great.. keep up the good work
My Build Thread
Old 06-02-2008, 08:23 PM   #198
nhtc33d
Re: progress pics
WOW! You have some real attention to detail! Now that you have all that practice you can plumb my truck when you get tired of working on your own truck!
nhtc33d is offline   Reply With Quote
Old 06-02-2008, 09:36 PM   #199
jlaird
jlaird's Avatar
Re: progress pics
Thanks guys for all the compliments. Working on the plumbing has been kinda fun...change of pace from all the suspension work.
Old 06-02-2008, 10:57 PM   #200
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: progress pics
Man that is some clean instal work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
