Old 10-03-2009, 10:15 PM   #176
Joemomma1
Joemomma1's Avatar
Re: 1964 Suburban Pics
Originally Posted by protrash64 View Post
I never found them useful except for blowing crap off the floor and into my eyes! Will glass them soon.
Is'nt that the truth! I thought I was the only one. How do you seal them from the elements?
Joemomma1 is offline   Reply With Quote
Old 10-03-2009, 10:26 PM   #177
daverod
SSN 706
daverod's Avatar
Love the build. Guess I know where to come when I need to hook up my bags.
daverod is offline   Reply With Quote
Old 10-04-2009, 11:29 AM   #178
protrash64
Resistance is Futile
protrash64's Avatar
Originally Posted by joe231 View Post
Right on!!!
We are planning on deleting the vents also, the benefit of them is outweighed by the crud in the eyes factor
......definitely. I figure the vent windows do a better job anyway.
no you're not! I briefly thought about that and I mite just place a sheetmetal piece over the hole. If I take the handle off the vent I may be able to use the original to seal the hole.
Thanx daverod....I was checking out your suspension parts and looks like you have plenty going on, too. If I can help with the bags I will. It was confusing at first but it will all come together and make sense as you go, I assure you.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-04-2009, 11:50 AM   #179
joe231
joe231's Avatar
I'm thinking about welding a bowl in there and using the space to mount some speakers, but it is probably kinda high.
might have to mount some mid-bass speakers there.....
CHEVY ONLY
Old 10-04-2009, 09:55 PM   #180
protrash64
protrash64's Avatar
It's a good hite but too far under the dash IMO......mite work well for the mid-bass but would need an enclosure for sure.
Tested my valves today and they work great..no leaks. I pumped up the valves and left the truck sitting there and it didnt move. Looks funny as hell though! Looks about a foot higher.
Here are the kick panels with the resin. I need to let them dry and then do some bodywork to them to get them smooth. They turned out better than my last set. Two different colors cuz I used two different T-shirts
Old 10-04-2009, 10:31 PM   #181
kyle4381
NICE
kyle4381 is offline   Reply With Quote
Old 10-05-2009, 12:23 AM   #182
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
You just use cotton T's?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-05-2009, 12:34 AM   #183
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Sweet man !!
What are you using on your threads ? Please don't say Teflon tape (?!?)
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-05-2009, 12:51 AM   #184
joe231
joe231's Avatar
Originally Posted by ChiefRocka View Post
Sweet man !!
what do you use?
CHEVY ONLY
Old 10-05-2009, 09:14 PM   #185
protrash64
protrash64's Avatar
Yeah!! I went and got fleece on the first set and it was a waste of $$ and too fuzzy. I think I read about a t-shirt in Frizzles thread. I had a couple I recently put in the rag bin and pulled them out and put them to use. After 3 coats of resin they are extremely stiff. I will then sand them a bit to rough them up and then use fiberglass body filler over that.
Sweet man !!
I used fiberglass resin...
Old 10-06-2009, 12:16 AM   #186
ruffrida2005
I knew everyone used fleece, didn't know cotton T's would work as well. I got some things I need to build, well practice first.
Paul
Old 01-17-2010, 11:59 PM   #187
protrash64
protrash64's Avatar
.......OK.....been awhile being that I've been working on the pickup. I'm going to continue my bodywork/paint while shifting gears to do some more work on the 'burb. I'm trying to make the March Goodguys show in Scottsdale; its the timeframe, not the drive!! I finished the kick panels and have a stereo and thats where I stopped working as I was sidelined by a few things ($$$$$).
I'm back on track and starting a new phase for the 'burb. Engine time!!!.......picked up a running 454 and a T400. Pulled from a 73 pickup. I will go with the 700r4 but took the tranny as a spare. I pulled the stuff and out comes a damn near brand new trans!!!! Anyway, here are the picks...a little grimy, but a smooth solid running engine. Also notice the aftermarket A/C compressor....made by Tehcumsah ???? Thats what the tag shows.
It's already cleaned up some and will be getting a re-seal and a serp kit that I've had for years.
Old 01-18-2010, 02:19 AM   #188
Captainfab
60-66 Nut
Cool! you got your big block
That A/C compressor looks a lot like a York.....some guys turn the Yorks into air compressors for various uses....just a little FYI.
Old 01-18-2010, 09:33 AM   #189
protrash64
protrash64's Avatar
I'm aware of its use; I was going to ask you about the compressor. The tag clearly shows Tehcumsah (I gotta check the spelling) on the back. It was an old aftermarket set-up.
I tore down the external components last nite and blasted the engine so its looking better. I'm going back today to get a brand new ms/cyl that was on the truck. It should be a good match for the hydro boost.
Old 01-19-2010, 02:09 AM   #190
Captainfab
60-66 Nut
Yeah I've never heard of a Tehcumsah compressor either, just small engines.
Old 01-19-2010, 08:45 AM   #191
joe231
joe231's Avatar
IIRC, Tecumseh made York clones or re-manned Yorks.
they are the same compressors.
The '73 that John and I tried to part out had the very same set up.
CHEVY ONLY
Old 01-21-2010, 12:59 AM   #192
Dinos63
chevy only
Dinos63's Avatar
jeff i have a complete belt drive air compressor set up if you need one, let me know
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 01-21-2010, 11:03 AM   #193
protrash64
protrash64's Avatar
Thanx man, but that whole bunch of stuff is history. I have a complete '89 serp set-up to install along with hydroboost brakes.
I'm waiting on a small order from Summit and will install new gaskets on the 454 along with a fresh coat of Chevy orange.
Old 01-25-2010, 10:45 PM   #194
protrash64
protrash64's Avatar
Ok....thought I would post up some of the parts I'm dealing with here. The engine is torn down for cleaning and gaskets. I'm getting ready to paint it soon.
Here is my BBC serp set-up which I need to figure out. I dont know how it all goes together..I'm sure I'll get there. Also my mounts and stands. Also scored some *****in' Sanderson cast headers. These will have no clearance issues; very tite to the block.
Lastly are my hydroboost parts along with Cap'n Fabs brackets.
Old 01-25-2010, 10:50 PM   #195
joe231
joe231's Avatar
Wow man!
Cool parts!
I especially dig those headers
CHEVY ONLY
Old 01-26-2010, 12:08 AM   #196
CSoliz
Torn between 66 and 78
CSoliz's Avatar
protrash, how do you plan on making the engine perches work. I have a pair of those and they were a little to high of the top of the frame. I had to put my 3 point perches back on.
CSoliz is offline   Reply With Quote
Old 01-26-2010, 08:43 PM   #197
protrash64
protrash64's Avatar
Good question.....everything I'm going on is hearsay, so I guess I'm going to find out. My plan was to swing the engine over the bay and lower it in and see where I ended up in regards to the mounts.
I dont have SB mounts available, just hacked up 292 mounts currently. If I have to, I guess I'll go aftermarket or make some up. I'll definitely post it up 'cuz I cant find exactly how this works anywhere on the website.
Old 01-26-2010, 11:11 PM   #198
Broke1
Broke1's Avatar
how much lift do you get with the bag aired all the way up
Broke1 is offline   Reply With Quote
Old 01-26-2010, 11:14 PM   #199
protrash64
protrash64's Avatar
I dont know exact specs, but enough to make it look silly They are Slam Specialties bags; I'm sure the specs are available somewhere.
Old 01-26-2010, 11:49 PM   #200
ruffrida2005
If you need some V8 mounts I have a pair that I'm not using! let me know they cacme out of my 64.
What did the Hydro come out of?
Paul
