Old 05-16-2009, 07:10 AM   #176
50adrod
50adrod's Avatar
Re: so lets build a truck/my '52 chevy
very nice glass work. what is the material you used to form the contour? I have never seen that done before. keep up the good work.
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 05-16-2009, 07:16 AM   #177
GRIMSS
GRIMSS's Avatar
Man that truck is dusty, but the fiberglass work is looking great. I really like the way the shape turned out.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 05-16-2009, 10:37 AM   #178
cajundragger
the base is just matt and resin over green paint tape. Then I use old gas welding rods, basically coat hangers,and mdf to make my shapes then I stretch a thick t-shirt over it. Then I glass that with matt.
I use a tshirt because it is thin enough to not need alot of resin so it wont warp, yet it gets hard enough to hold its shape really well when using the chop mat.
Its like tac'ing all your metal before you weld so nothing pulls and moves.
and yeah lol, the truck is a mess but should clean up quickly. Just need to blow it all off.
cajundragger is offline   Reply With Quote
Old 05-16-2009, 12:39 PM   #179
solidaxel
solidaxel's Avatar
VERY NICE work,
I see a market for those kick panels, speaker pods!!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-16-2009, 01:12 PM   #180
cajundragger
Originally Posted by solidaxel View Post
VERY NICE work,
well I showed how to make them, so go make some.
there are molded to fit my truck exactly, so they wont fit yours or anyone elses. but the process is the same truck to truck. The kicks are SUPER simple to do, its the console that is a little more difficult.
Old 05-25-2009, 12:04 AM   #181
cajundragger
busted tail to get more done...
got everything painted
worked on finishing the seat. had to notch it for the console and make a pan for the bottom and remove the springs
custom upholstery
last look at springs
gone
twas alot of springs
Old 05-25-2009, 12:05 AM   #182
cajundragger
paned the bottom
notched for the console
painted
one last interior shot so far
Old 05-25-2009, 12:09 AM   #183
50adrod
50adrod's Avatar
looking good, I really like how the console came out.
Old 05-25-2009, 12:13 AM   #184
cajundragger
thanks man. I sat and worked with the headliner a bit and decided to just cover it. Im bringing it to the upholstery guy tomorrow to see if he can work with it.
I really appreciate you hooking me up and everything. Thanks again
Old 05-25-2009, 12:36 AM   #185
GRIMSS
GRIMSS's Avatar
Looks great. Is there some site that shows a little how to on that type of glass work?
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-25-2009, 07:19 AM   #186
cajundragger
fiberglassforums.com
Old 05-25-2009, 08:22 AM   #187
GRIMSS
GRIMSS's Avatar
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-31-2009, 11:44 PM   #188
cajundragger
been in new york for the past week, but went to work today for a few hours and got some stuff done.
put a filter on my tank vent
started making the cover, holes are for filter and the plug on the tank
cap for the plug hole will be off center of the hole to match up correctly with the filter hole. had to do this since summit cant build a square tank.
drilled holes so resin will have lots to grab to.
cover for emergency brake
glued with resin
using tape i made a pocket to pour resin into to make a cone shape
e brake cover in truck
Old 05-31-2009, 11:44 PM   #189
cajundragger
seam sealed
tank cover
primed everything to let the wood soak it up.
hopefully get everything painted next weekend.
show time is getting close.
Old 06-01-2009, 11:06 PM   #190
cajundragger
I dropped my headliner and seat off at the upholsters today. and I got the materials to make my door panels. Im super stoked. He said he should have everything back and done for scrapin at the end of this month.
Old 06-01-2009, 11:39 PM   #191
50adrod
50adrod's Avatar
sounds good, glad it will be done for scrapin. we may be headed there also. post pics when its done
Old 06-02-2009, 12:27 AM   #192
cajundragger
awesome
my interior guy is awesome. I couldnt get that headliner very close at all so he said no problem he's going to glue closed cell foam to it and sand it all smooth enough. so should work out nicely. I really appreciate it man. thanks again.
Old 06-02-2009, 08:04 AM   #193
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice build!!!!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-02-2009, 08:50 AM   #194
Bigblue29
Thanks 'til you're better paid
Bigblue29's Avatar
Very cool ride! That looks great!
-Luke
1950 Chevy AD 3100 pickup
2000 GMC Sierra
1970 Jeepster Commando
Bigblue29 is offline   Reply With Quote
Old 06-02-2009, 09:02 AM   #195
my67chevytruck
Under Construction
Cajun, Curious if the 67-72 pictured next to your '52 is your project too?
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-02-2009, 09:08 AM   #196
bensimmons_05
bensimmons_05's Avatar
I don't know how to say this, but....... I think I may have feelings for your truck.
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 06-02-2009, 03:09 PM   #197
Kabwe
Certified Car Nut
Kabwe's Avatar
Its looks great, a lot of nice work on going on.
Kabwe is offline   Reply With Quote
Old 06-02-2009, 05:13 PM   #198
cajundragger
thanks guys.
thats my brothers truck. should be finished sooon.
Old 06-02-2009, 06:06 PM   #199
cajundragger
no more springs. all foam like a new car.
Old 06-02-2009, 08:36 PM   #200
Kid
Kid's Avatar
lookin really good cajun, I like your idea of reworking the stock seat frame. It looks like the bottom will have a curve similar to some of the after market seats. thanks for the updates
Kid is offline   Reply With Quote
