10-27-2011, 08:39 PM | #176 |
Re: Power Steering Adapter Plates
Thanks John
Got the parts today. Impressive welding. Very clean. Mike |
10-28-2011, 01:03 AM | #177 |
60-66 Nut
Thanks for the compliment Mike
11-08-2011, 10:43 PM | #178 |
I got around to installing power steering on my truck your bracket was great and that pattern included really was awesome managed to change my front end to power disc brakes and power steering in less than 8 hours big thanks man ill get some pics soon and post them up
11-09-2011, 12:21 AM | #179 |
60-66 Nut
I'm glad to hear the conversion went well for you. Thanks for the compliment
12-26-2011, 12:36 AM | #180 |
60-66 Nut
I found this thread that gives a source for an inexpensive quicker ratio steering box.
http://www.67-72chevytrucks.com/vboa...d.php?t=499058
12-30-2011, 10:12 PM | #181 |
Hi Captain fab ..I im needing one of your world famous power steering mount for 65 short step build that im doing please sir.
Thanks Billw Last edited by niterider65; 12-30-2011 at 10:21 PM. |
12-31-2011, 12:19 AM | #182 |
60-66 Nut
I'll send you a PM Bill.....
01-07-2012, 11:31 AM | #183 |
Could you send me a pm with payment info
Posted via Mobile Device |
01-07-2012, 11:59 PM | #184 |
60-66 Nut
PM sent
01-22-2012, 12:47 AM | #185 |
Captin,
Do you make a plate for a 68 or 69 c10!? Posted via Mobile Device |
01-22-2012, 02:55 AM | #186 |
60-66 Nut
You do not need an adapter plate for those years. Your frame should already have the 4 holes in the correct location, and the frame should be contoured so you can just bolt up a power steering box. That is unless yours happens to be different than the ones I have worked on here.
01-22-2012, 03:09 AM | #187 | |
The current box only has 3 bolts mounting it, but there is a fourth at the top of the frame at the rear. Guess that saves me 1 more step. Sorry I couldn't drum up more business for ya but thanks for the input. Posted via Mobile Device |
02-01-2012, 07:03 PM | #188 |
Pm sent
02-02-2012, 12:38 AM | #189 |
60-66 Nut
Payment received.....thank you csa daddy
02-10-2012, 03:01 AM | #190 |
But Found Her 25yrs Later!
Is the 73-87 power steering box for a c20 the same as for a c10?
thanks
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
02-11-2012, 12:48 AM | #191 |
60-66 Nut
Yes the steering box is the same for C10, C20 and C30.
02-28-2012, 08:06 PM | #192 |
If I'm looking for a 2wd power steering box for my 65, what years newer than 73-87 can I use? or is 87 the last year that works with the 60-66 trucks?
02-29-2012, 12:46 AM | #193 |
60-66 Nut
The compatable power steering boxes are from '68-'87 for the C10, C20 and C30 pickups, Suburbans and 2wd K5 Blazers. The only newer boxes that will work would be from the '88-'91 R1500, R2500 Crewcabs, Suburbans, and possibly Blazers. I just don't know for sure if there were any 2wd Blazers in those years.
02-29-2012, 12:38 PM | #194 |
Cap if you could send me the info for purchasing one of these PS adapter plates that would be great, I plan on purchasing one here in the next few weeks. Thanks in advance.
03-01-2012, 12:11 AM | #195 |
60-66 Nut
PM sent.......
03-10-2012, 12:05 PM | #196 |
Help me out here. I've been searching for the best solution for brakes and steering and keep winding up looking at John's cool stuff! I've got a '67 C10 with a front disc conversion. I for sure want to do PS/PB and use the Hydra-Boost set up. Problem is, I've got the 292 L6, which I'll have to run until I can fund the small block swap, probably next winter. Seems that pump brackets for this in-line engine are rare and expensive. Anyone fab a pump mount for this?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
03-10-2012, 12:25 PM | #197 |
Cap
Please pm ordering info for a ps mount bracket. Thanks, Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
03-11-2012, 01:33 AM | #198 | |
60-66 Nut
On a '67 you shouldn't need this power steering adapter plate. The '67's I've seen/worked on, just need four 1/4" spacers. As for the 292 PS pump brackets, there was an ebay seller that was making some nice ones.
03-11-2012, 01:34 AM | #199 |
60-66 Nut
A PM coming your way...
04-24-2012, 03:04 AM | #200 |
I need to purchase another power steering bracket. This one is going on my 65.
Thanks Posted via Mobile Device
