Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 08-23-2013, 10:02 PM   #176
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: SiX-fo SuBuRbAn
/\ /\ ** check out the rear seat on page 7 post 175 if this is the first new post you see!***
spray bombed the post and jamb-
picked up this 83 3/4 4x4 parts truck, (dad found it at a yard sale)
it has a 3:42 posi, and recently had brake work and tires.
the tires will do until I can afford the 33x12x16.5's for the "cool" wheels.
again I will switch differentials in this sub... I wanted to have the posi, and the 3:42 is a better ratio than the one that is in it, and most important, I won't have to deal with the RF axle shaft that has an egged out U joint that came from the 88 sub
Old 08-24-2013, 12:54 AM   #177
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
I like how that Blazer seat folds forward.
Old 08-24-2013, 11:29 PM   #178
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
I hope it will make room if I ever need to carry something bigger....
I was thinking about this the other day, and the only problem with the barn doors and this seat is if I needed to carry a 4x8 sheet of plywood... but this is to be a winter rig, so really I shouldn't be hauling much more than people in the snow...
Old 09-05-2013, 11:39 PM   #179
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
well, got the windshield in!
It is quite a story....
I ended up with a precision gasket, but the only one available at the time was for the chrome trim... that was fine , because I have a couple sets of trim...
I tried to do it myself, but could not get the gasket to even stay on the w/s, much less get the trim in.
I called up a local glass guy I know, and had him come out to put it in, he brought 2 helpers, and that made all the difference in the world for getting the gasket on, and the trim in.
they put the w/s in the opening, and started, got the rope pulled, got the center set, started on the sides, and the center popped out, then the whole thing fell out...
so they tried one more time with the trim in, and had the same problem....
he asked me if the opening had been compromised, but I did not tell him about all the work that has been done. ( I had a feeling that if I told him about the work they might have given up right there), I just showed him how I had cut the old gasket into chunks, and set the window in the opening.
so he tried once with out the trim, he said if they got it then they would try to get the trim in , but not to count on it...
same problem, got it about halfway in, and then everything fell apart...
now I was really getting worried that I might have to cut up and reshape the whole opening....
he gave one more try... this time they put the gasket in the opening, 3 of us held it in place, and he lubed the heck out of the w/s and started to work it in....
long story short, about 40 minutes later and after a lot of bad words the w/s just popped in!
no trim, but I didn't really want it in the first place... the glass does fit, and the opening is correct, it was just a real MF to get in.
Old 09-06-2013, 10:19 AM   #180
piratexpress1369a
piratexpress1369a's Avatar
Re: SiX-fo SuBuRbAn
glad you were able to get the window in ,,i have yet to get my window in never enough hands around lol
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 10-20-2013, 08:31 PM   #181
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
rust repair is a b*%$#!!
I have been putting off working on this...maybe I was hoping a good fender would fall in my lap
anyway now this really is a blue/green fender.
the green one was pretty rough in the back, top to bottom and the brace rusted... also a dent/push on the top of the back of the wheelwell...
the blue green one has a nice brace, and not horrible rust.... just the front was wiped out...
so taking 2 to make 1.
I forgot to get a pic, but I cut the patch out of a junk bedside piece.
still probably better than a re-pop?? maybe...
Old 10-21-2013, 10:40 AM   #182
66Z71
66Z71's Avatar
Re: SiX-fo SuBuRbAn
Nice work. Way better than patch panels.
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera
66Z71 is offline   Reply With Quote
Old 10-26-2013, 09:42 AM   #183
72 5500
Re: SiX-fo SuBuRbAn
Thanks for the info Jon.
72 5500 is offline   Reply With Quote
Old 10-26-2013, 08:27 PM   #184
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
you're welcome , I am glad the info helped.
today I finished welding and grinding the driver fender, and then started on the passenger.
I have 2 to work with, and started on one , then changed my mind and chose the other.. then I started to try and patch the rust, and then just decided to use 1 of the patch panels I have , it isn't shaped as nice as the factory, but it will work.
I had to fold in the edge of the wheel well, it came out ok, I wish these patches were formed a little better. the rust was higher than the patch, so I had to make a little piece to cover that.
Old 10-27-2013, 05:42 PM   #185
Average Joe
Average Joe's Avatar
Re: SiX-fo SuBuRbAn
Cool build! I like your low buck approach.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 01-19-2014, 02:33 PM   #186
padresag
Re: SiX-fo SuBuRbAn
Jon; what is this place do you know?
I didn't know where to post this, but I felt it ought to go somewhere. It appeared today on a Buick forum I belong to.
"Yesterday I went to a salvage yard in Whitehall, Mt. and watched the start of an operation that is crushing over a thousand cars from the 30's to the 70's. Over two dozen old Buicks. Sadly I cannot save them all so I'll post this for a friend who is doing his best. The crushing starts Monday morning and will take several weeks. If you have any specific needs and he can help you can contact Peter at montanamopar (at) gmail (dot) com . He does not own the yard but is trying his best to save the Mopar stuff that he knows about and any rare parts of other cars that he can."
ron
padresag is offline   Reply With Quote
Old 01-20-2014, 08:57 PM   #187
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
that would be neil fremans auto, he mainly had mopar, but did have a ton of stuff, I wonder if he died, or retired?
he did crush from time to time,but never the whole yard...
here is a link to his website
http://www.fremansauto.com/home/?sel=TRUE
Old 04-09-2014, 03:13 PM   #188
jmack91z28
jmack91z28's Avatar
Re: SiX-fo SuBuRbAn
This build is awesome. Keep it up. Nice shop too, it helps to have plenty of room like that doesn't it?
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear
1966 C10 Fleetside 350 W/ Saginaw 4 speed
1985 K10 Chevy 6.2 diesel 700r4 longbed
2001 Dodge 3500 Dually 24v NV5600 4x4
USMC Reserves
Jason
jmack91z28 is offline   Reply With Quote
Old 04-10-2014, 11:39 PM   #189
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
thanks!
Old 04-10-2014, 11:58 PM   #190
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
Been slow with the updates here.
Just after we got that parts truck at the end of August we found out that my dad had terminal cancer.
He made it the 5 months that they gave him, but I lost him at the end of January.
He was one of the few people that understood my/our vehicle obsession... I will miss all his help and support.
I have spent most of this spring cleaning up the place, and organizing, I now have 80 vehicles-I inherited his collection of squarebodys, and a few other projects as well..
My original plan was to have this sub ready for winter... I missed that, so next winter it is!
My main 2 expenditures will be a new (custom length) front driveshaft, and a new set of 33X12.50 16.5's.. other than that it is all labor, and since I don't charge myself that is free!!
So I hope to get you guy some more updates soon, as I finish out the rust repair and re-do the rear wheel wells.
Old 04-11-2014, 09:40 AM   #191
piratexpress1369a
Re: SiX-fo SuBuRbAn
sorry for your lost
63
Old 04-11-2014, 03:20 PM   #192
padresag
Re: SiX-fo SuBuRbAn
sorry hear of the loss of your father Jon
ron
Old 04-12-2014, 12:27 AM   #193
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
Very sorry to hear that Jon.
Old 04-20-2014, 01:40 AM   #194
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: SiX-fo SuBuRbAn
Sorry to hear about your pops man.
Thoughts and prayers to you and your family
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-20-2014, 06:51 AM   #195
MikeS.
MikeS.'s Avatar
Re: SiX-fo SuBuRbAn
Jon, real sorry for your loss man.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 04-20-2014, 10:09 AM   #196
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: SiX-fo SuBuRbAn
Sorry for your loss. Prayers for the family.
Alan's Classic is offline   Reply With Quote
Old 04-21-2014, 12:27 AM   #197
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
thanks for the kind words guys, I really like the comradery and support on this site.
I've got lots of projects going at once right now, but soon I have this slated to switch out the axles (again!) with the ones from the red parts truck.
Old 05-01-2014, 03:13 PM   #198
infinite-foamies
Re: SiX-fo SuBuRbAn
Sorry for your loss. That is a hard, I have gotten my vehicle obsession and basically every skill I have from my father and love wrenching on projects with him. I cherish the time we have together and I feel for you.
Great build and I can't wait to see it done! I am starting on a 71' 4x4 4bt swap shortly.
infinite-foamies is offline   Reply With Quote
Old 08-22-2014, 10:57 PM   #199
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
finally starting to get back to this.... as always one step forward 2 back....
I got the "guv lock" G80 posi rear out of the red truck and got it installed... then the problems: the drums came off the posi real nice, but inside was a mess, the drivers side had some broken brake springs, and on the passenger side the e brake lever (inside the drum) had come apart, and was laying in the bottom wearing a groove in the drum..
So I am thinking just pull the drums and brake hardware off the rear that's already in the sub.....No such luck, those drums are glued on pretty good... maybe I can get them off with some heat?
Or other suggestions if you have 'em...
now on to the front....the second step back-
I want to use the axle out of the red truck, the ratio matches the rear, and the axle I have in the sub has a blown up U joint, so I will just switch them, a lot of work, but cheap, except I get the front of the red truck jacked up and the LH hub is all wobbly and loose...
so now I'll have to tear this apart and see what I have...
along with this, I will need to switch out the red trucks auto locking hubs with the manual ones off the sub.
more to come-
Old 08-23-2014, 01:43 AM   #200
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
Yeah, sometimes some heat will help get a drum loose. I assume you have already tried persuading them with a 3-5 pounder?
