Old 12-22-2011, 01:40 PM   #176
dnd1978
dnd1978's Avatar
Re: I think i can!!! - SWB 72 Step-side
Originally Posted by chevyrestoguy View Post
I like where you're going with this. I am planning on the same thing on the upper mounts. I am also doing a mod on my stock lower arm that will gain some additional caster. I am dropping the parts off to the machinist today. I'll update my '64 build thread as I progress on that mod.
I will be watching. I have been following your 55 build for some time now. Great work on the the metal!
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 12-24-2011, 09:58 PM   #177
dnd1978
dnd1978's Avatar
Well i had a little time today to work on my frame. I changed the bracing around a little! Plus a got one battery tray mounted.
Merry Christmas to All!!
Later
Old 01-09-2012, 11:07 PM   #178
dnd1978
dnd1978's Avatar
Guys whats up? I have not done much on the frame because my welders brooken. I got a back up from a friend and im planning to kill it this weekend! If the wife lets... I did get some sheet metal in for my cab. I hope the body guy gets started soon.
Later
Dillon
Old 01-10-2012, 02:53 PM   #179
fishingjred73
fishingjred73's Avatar
Subscribed..........awesome build!
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 01-22-2012, 10:25 PM   #180
dnd1978
dnd1978's Avatar
Whats up guys? I have a little update. Work on the cab has started!! Bye,bye drip rail... Work on the frame is moving slow but moving. I will post some picture after next weekend.
Old 01-22-2012, 10:31 PM   #181
dnd1978
dnd1978's Avatar
other side
Old 01-23-2012, 03:13 AM   #182
ZUBZ
ZUBZ's Avatar
Looking good...
ZUBZ is offline   Reply With Quote
Old 01-29-2012, 08:48 PM   #183
dnd1978
dnd1978's Avatar
More pictures of the cab
Old 01-29-2012, 08:55 PM   #184
dnd1978
dnd1978's Avatar
I built some plates to attach the rear swaybar on the tubular trail-arm.
Old 01-29-2012, 08:58 PM   #185
dnd1978
dnd1978's Avatar
aa
Old 01-29-2012, 09:14 PM   #186
dnd1978
dnd1978's Avatar
I got the accuair sensors on all four corners. The accuair kit is very nice. Just the packaging lets you know its quality. I cannot wait to get it working!!
Old 02-21-2012, 01:29 PM   #187
raull
raull's Avatar
nice , subscribed !!!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 02-21-2012, 08:46 PM   #188
dnd1978
dnd1978's Avatar
Thanks Raull. I will have some updates this weekend.
Old 02-22-2012, 12:02 AM   #189
nuke1
nuke1's Avatar
Great build! You are building after my style, meant to be driven hard. This is what I built my truck for, I still have a long ways to go yet, things to be changed and adjusted but it will get there. You widened your rims just like I want to widen mine, everything is coming along nicely. You are goin to have one he'll of a ride when you are done. I am defiantly gonna watch this build.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-22-2012, 04:21 AM   #190
502ms
502ms's Avatar
Great stuff! Keep going! You can do it
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 02-23-2012, 01:49 AM   #191
mcbassin
Still Learning
mcbassin's Avatar
Awesome build you have going Dillon! I finally got through the whole thing. You have some super fab and metal skills. Too bad you already cut your cab, I would have made you a great deal or swapped you for my shaved cab HERE. I just cut a crap load of rust our of my "new" cab to get one with a drip rail. Go figure.
I'm subscribing to this one for sure.
mcbassin is offline   Reply With Quote
Old 02-23-2012, 08:00 PM   #192
dnd1978
dnd1978's Avatar
Nuke1,
Thanks! As soon as I’m finished I will post a video of a fat burn out.
Dillon
Old 02-23-2012, 08:06 PM   #193
dnd1978
dnd1978's Avatar
502ms,
Thanks i needed that.. HAHA
Old 02-23-2012, 08:10 PM   #194
dnd1978
dnd1978's Avatar
mcbassin,
Why the change of mined to keep the drip rail? I have been watching your build 1969 Short Wide.
Dillon
Old 02-23-2012, 08:34 PM   #195
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by dnd1978 View Post
mcbassin,
Dillon
Dillon, I bought the shaved cab to replace my badly rusted original cab. It started out as a simple daily driver on a tight budget. Well I've always liked the double mouldings on the wide/fleet side. The shaved cab doesn't really go with that theme. My truck will look exactly like it would have in 69 with modern drivetrain, exhaust, and wheels.
Old 02-26-2012, 08:11 PM   #196
dnd1978
dnd1978's Avatar
After a 4 day weekend i finished my frame. Finally I’m making some progress, it only needs to be blasted and paint. I’m going to paint it a dark gray with a grass clear. The frame it a lot more rigid. You can hear the different in the sound it make when you drop it on the ground! I boxed it in the front and rear where the chassis curves. Moved the front and rear shock mounts, added a plate in the rear to mount the compressor. I also filled 40 years of holes... fun, fun. I hope i never see a hole again!!
How do you guy like my chassis moving tool?
Old 02-26-2012, 08:46 PM   #197
VA72C10
VA72C10
VA72C10's Avatar
Looking good! Looks VERY solid!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-26-2012, 09:21 PM   #198
mcbassin
Still Learning
mcbassin's Avatar
Frame looks good to me. And I like the dolly
Old 02-26-2012, 09:33 PM   #199
smbrouss70
smbrouss70's Avatar
Got my wheels widened. Added 2.5 inches so I can running a 315/35r20 now should help with my traction problem. Now it time to work on my tubs.
Frame is looking great!
I just went back through your thread and saw this post about widening your wheels. Was that done locally? If so, who did it for you? I might have to come visit and check out your truck one day, you're just down the road from where I work.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-28-2012, 12:21 PM   #200
dnd1978
dnd1978's Avatar
Smbrouss,
I could not find a local shop to do it. I had to send them to http://www.weldcraftwheels.com/ . They did a great job, it took about 4 week. Where u work? We could me up one day.
I also need to meet KEITH 71 STEP SIDE. He is also a local.
