01-10-2012, 11:38 PM | #176 |
Re: 68 aka "Chained in Porterbuilt Prison"
Doc's Kustoms---he's got some neat stuff-U buy a gas cap yet??....Thanx again for the clip idea on cowl--works great---pics when done--hope mine is as slick as the one's I've seen by "lockdoc"........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
01-11-2012, 08:50 AM | #177 |
Great looking build you've got here.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
01-11-2012, 10:08 AM | #178 |
I have been strongly debating getting a set of those bearclaws. How hard were they to install and get everything lined up? Did they come with that panel insert or did you make that? Looks really good.
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
01-11-2012, 11:51 AM | #179 |
I used there installation kit-but added material to reach down to outer panel crimp(look at pics of cutout^^^^) Actually was pretty staightforward but your own your own-they are universal--have not installed striker yet-will post when I do-waiting to get 1 piece window kits-to see if I will have a rubbing problem on back edge of glass against the claw body--in their video U only have 3/4" of clearance from door end to glass edge-just want to make sure before going farther that I don't have to alter claw mounting-Yes I'm anal about fit and finish!!...lol....found out a long time ago about "take time for the details--pays off in the end"............jim
01-11-2012, 04:31 PM | #180 |
6>8 Plugless........
That dash looks awesome! That's also awesome that the air unit is totally invisible! Great work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-11-2012, 04:40 PM | #181 |
Great looking build.. Subscribed
01-11-2012, 10:06 PM | #182 |
Thanx--the dash is 2 1/2 " lower than stock which I wanted--but kicking the V.A. up tight in the toe kick was the trick-As low as this truck will be U will virtually never see air box-------------jim
01-12-2012, 12:10 AM | #183 |
gonna have quite a few need mods
01-20-2012, 10:35 PM | #184 |
A guy with a truck
Wow
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-28-2012, 10:12 PM | #185 |
Ok guys and gals,A little progress here---Christmas in January!! Got my Mod 5 wheels in ..........unbelievable polish......setup bed to get actual dimensions for narrowing rear....these pics are where truck would be aired out......also almost done with Nates x-member upgrade......I know its an upside down shot but i love how slick the dimensions of these frames are after the pieces from Nate totally change it!! More later when finished (I know Nate when U see this U will say "He changed the bar arrangement!!" Yes I did "tweak it" but I think U will like the finished product)..Haven't installed trans crossmember yet..............jim
01-28-2012, 11:01 PM | #186 |
CCTek
Nice work Jim! Keep it going!
Chad 68 swb Project http://67-72chevytrucks.com/vboard/s...d.php?t=262840 72 swb Project SOLD http://67-72chevytrucks.com/vboard/s...=1#post3993641 THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com) |
01-29-2012, 01:14 AM | #187 |
VA72C10
Very nice! Those wheels do have a super nice polish!!!
Looking for a 67-72 swb or blazer project in or around VA. |
01-29-2012, 01:35 AM | #188 |
67-72 parts collector,…
Sweet.
What's the specs on the wheels and tires? Lots of dish,... so the backspacing must be pretty low.
01-29-2012, 11:17 AM | #189 |
20 x 12.....6" backspace........Schott's.....the centercap is so precision made I've had 2 people that couldn't find the line were cap meets wheel......tires are 315-35's............jim
01-29-2012, 11:36 AM | #190 |
67cheby
Sick sick sick !!!!!!
Posted via Mobile Device |
01-29-2012, 05:18 PM | #191 |
Tot Roddin'
Amazing... simply amazing!!!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-29-2012, 06:12 PM | #192 |
Wheels look great.....
I had to go back and read the thread again because I noticed a tube configuration change in Nates X member. It looked braced differently than mine. Nice work! Did you determine that you cannot use 55-59 truck dashes for that awesome look?
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
01-29-2012, 08:59 PM | #193 |
Yeah that upper bar (or lower one in previous pic since its upside down!!) normally turns down into bottom bar-Just thought it was slicker extended and turned in...still can run 3 " exhaust..Waiting on delrin bushings for trans cross mount then will set motor in......may be picking your brain for ls engine questions as they come up......Chose belair dash because of all the choices in gauges...billet trim...etc..Almost as many parts being repoped for those cars as these trucks!!! Another pic with frame right side up this evening .....Frame has NO twist now..............jim
01-29-2012, 09:31 PM | #194 |
Thanks for the info.....Turned out really nice.
My kit came with poly trans mount bushings. Is the Delrin the new standard bushing?
01-29-2012, 10:17 PM | #195 |
low n' slo
Nice build so far...don't see how I missed this one
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
01-29-2012, 10:31 PM | #196 |
I assumed they were delrin but they may be poly....waiting for Nate to respond......busy man....don't U just love sending $$ to Arizona!! lol..............jim
02-03-2012, 02:26 AM | #197 |
totally impressed! :-)
02-05-2012, 09:13 PM | #198 |
Ok guys----little update during halftime!! got 6.0 liter and 4l80 mounted in chassis...I'm a little concerned about height of tailshaft and drive shaft angle to carrier bearing....but got a call into Nate with pics to get his opinion...the engine has 3-4* drop in pics with frame level--really don't see why I can't run this oil pan also..has 1 1/2 " clearance about frame rail--Only about 1" lower than dropmember..........Cab comes back tomorrow and I will see how it all fits late this week............back to the game.........Madonna (ugh!) I guess for 53 she's not bad..............jim
02-05-2012, 09:17 PM | #199 |
couple more
02-05-2012, 09:34 PM | #200 |
67cheby
That's much better than the half time show
