12-08-2011, 03:51 PM | #176 |
Tot Roddin'
Re: Nacho Truck
Hey Del.... are those the modular CPP spindles?
"IS" there a difference between the modular/original drop spindle? I know they claim to suck in the wheels, but I don't believe I've ever heard someone verify they do. Truck is looking good! Welcome Mason!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-08-2011, 05:40 PM | #177 |
Re: Nacho Truck
I think the modular spindle moves the wheel forward in the wheel well about an inch. Welcome Mason looks like your gonna have a fine looken ride to show off. Lucky dude
12-09-2011, 02:08 AM | #178 | |
67-72 parts collector,…
Re: Nacho Truck
The info listed below was taken directly from CPP's website: http://www.classicperform.com/NewPro...op_Spindle.htm Modular™ Drop Spindle Complete Front Brake Kit Looking for a spindle and brake kit for your lowered truck with big tires and wheels? We have it! Introducing CPP's new modular 2" drop spindle and drop spindle wheel kits for 1960-87 Chevy pickups. Our exclusive new design helps solves tire to fender interference commonly found with lowered trucks. Our new modular spindle and bracket works with factory 1971-87 C10 brake components, or for a HIGH performance option, combine our spindle with the NEW CPP 13" Rotor Twin 52mm Piston Brake Kit. The ALL NEW CPP Modular Spindle offers many benefits available for the first time, installs easy without modifications, works with factory ball joints and tie rod ends, lowers your truck a full 2", offers adjustable steering stops, provides 1-1/8" more fender to tire clearance, allows use with standard factory brakes and PERFORMANCE aftermarket "BIG" Brake Kits. You can count on CPP for impressive quality, performance and price. 12" complete front brake kits include: spindles, 12" rotors, loaded calipers, caliper mount brackets, bearings, seals, spindle nuts, banjo bolts, rubber brake hoses and a booster, master cylinder & prop valve assembly. 13" complete kits include: spindles, 13" rotors, aluminum hubs, loaded calipers, caliper mount brackets, bearings, seals, spindle nuts, banjo bolts, rubber brake hoses and a booster, master cylinder and prop valve assembly. Note: Kits will fit 1967-70 trucks when modifying the firewall. Also note, the 12" kits come standard with plain rotors.
12-09-2011, 02:36 AM | #179 |
Re: Nacho Truck
Well I was told by CPP and it seems to be the case when bolting on other spindles that the Modulars suck the wheel in 3/4 a side. Where the 1 1/8 come from I have no idea unless they are sayin that you get 9/16 per side rather than 3/4. I'll have to confirm this of course. What do I know. LOL
12-09-2011, 10:01 AM | #180 |
Re: Nacho Truck
And what does this statement mean?
Note: Kits will fit 1967-70 trucks when modifying the firewall Ha. I think it's suppose to be 9/16" per side,... Delmo,... what backspace and width wheels are you using up front?
12-09-2011, 01:51 PM | #181 |
Re: Nacho Truck
Well the 22's are 9" with 5.5 BS and the 20's are 8.5 with 5.25 BS. This is the first I've heard of moving the wheels back or forward. Hmmmm.
12-09-2011, 05:43 PM | #182 |
Re: Nacho Truck
I apologize for the bad info posted earlier, I could have swore I read this when I ordered my drop spindles. Sorry
12-09-2011, 09:59 PM | #183 |
Re: Nacho Truck
12-09-2011, 10:45 PM | #184 |
Re: Nacho Truck
MASON-
Im starting a chevy truck anonymous meeting. Its on wednesdays at 8pm. Ill even be your sponsor. If you are like I was(spending all my money on parts, having my thoughts consumed of bagged c10's and not being able to manage life because of my problem) then this group may be able to help you. PM me for my number Posted via Mobile Device |
12-10-2011, 12:19 AM | #185 |
Re: Nacho Truck
I'll pay his admission. It's bad, he really needs help. LOL
12-10-2011, 12:43 AM | #186 |
Re: Nacho Truck
Where's the newest pics, I know you did more today. I'm like a crackhead and need a fix! Awesome project by the way!
Tony from Norcal Posted via Mobile Device |
12-11-2011, 02:04 AM | #187 |
Re: Nacho Truck
I bought the same spindle. All I can say is they were way rougher than I expected. I spent alot of time cleaning up and machining excess material off these spindles. The brake bolt holes were not tapped well enough to get bolts in either. Poor quality control is my honest opinion. I dont know where they locate the wheels , I have not got that far.
12-11-2011, 03:02 AM | #188 |
Re: Nacho Truck
Ya they are pretty rough to say the least. And almost impossible to get.
Tony, mostly doing brake lines, linkage etc. Nothing cool enough to post. LOL. If the brake lines turn out clean enough I'll snap a pic. Hahaha |
12-11-2011, 07:58 PM | #189 |
Re: Nacho Truck
Hey Delmo does Porterbuilt make that air ride setup for a one ton?
12-11-2011, 10:40 PM | #190 |
Re: Nacho Truck
12-11-2011, 11:25 PM | #191 |
What was I thinking?
Re: Nacho Truck
Looking good!
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
12-16-2011, 06:42 PM | #192 |
Re: Nacho Truck
Sick ride man! Good to talk with you!
2012 Dodge Mega Cab Dually H.O. 6.7 Cummis 4x4 on 22.5 American Force Holes 1977 Chevy C30 soon to be slammed, shoed with 22.5s, and maybe 12v Cummis swap 1976 GMC Jimmy High Sierra 5.3/Th400/NP205/D 60 and a 14 Bolt 4:56 gears Loc Right front and a Detroit rear. |
12-17-2011, 05:57 PM | #193 |
Re: Nacho Truck
Thanks man, you too. Love your new ride.
So as always I am kind of addicted to working and it's hard to get me out of the shop for any reason. Well then Mason the owner of Nacho invited me out to Glamis to do some Dune riding. I just couldn't resist, well actually I tried but he wouldn't let it go. So finally a day off and I had a blast blowin the dust off my 450. Thanks for draggin me out there man. So back to work today. Got a few things done so I figured I had better update y'all with some weekend artsy shots. Here ya go. |
12-17-2011, 05:58 PM | #194 |
Re: Nacho Truck
12-17-2011, 06:20 PM | #195 |
67cheby
Re: Nacho Truck
thats some cool photography !!
12-17-2011, 10:11 PM | #196 |
Re: Nacho Truck
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-17-2011, 11:33 PM | #197 |
Re: Nacho Truck
You SoCal boys have all the fun!! 40 degrees in VA for a high! Dang Canadian winds!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
12-18-2011, 01:13 AM | #198 |
GEARHEAD
Re: Nacho Truck
Not only a car builder, but a budding photographer. You think it's bad in VA compared to CA, try some true north my friends.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
12-18-2011, 03:01 AM | #199 |
Re: Nacho Truck
Thanks so much guys. I'm lucky to have guys like you to Bragg to.
12-18-2011, 09:39 AM | #200 |
Re: Nacho Truck
great pictures...that truck looks great!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
