Old 07-08-2013, 03:35 PM   #176
67cheby
67cheby
67cheby's Avatar
Re: 1967 C10 "Sinister"
great score !
67cheby is offline   Reply With Quote
Old 07-08-2013, 08:22 PM   #177
808_67C10
808_67C10's Avatar
Last one...
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 07-10-2013, 12:48 PM   #178
808_67C10
808_67C10's Avatar
Fire wall is done... ready to ge tthe front end back on!!!
Old 07-10-2013, 12:59 PM   #179
jlsanborn
jlsanborn's Avatar
Looking great!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-10-2013, 03:00 PM   #180
Mr.Hyde
On the welding portion. If your using flux core with your wire feed it will most likely be better for the c notch because its a hotter welding process and you will get better bite into the parent material. For your sheet metal you want to do about a 1/8 gap between your body panel and patch if you see weld on the other side you know your getting good penetration on your welds. Butt weld clamps are good for keeping this gap and keeping the panels flat. Also another note when you are sanding if you see your steel is turning blue then stop immediately, the metal is getting too thin. Flap disc are great for finishing welds I wouldn't use a grinding stone for one reason and that's because they produce heat which can be controlled if you don't stay in one spot too long, goes for the flap disk too. You want long strokes when you grind and you want the abrasive as flat on the material as possible this will prevent you from digging into and gouging the material. If you need any advice on welding I'm a good guy to ask I do it for a living haha good luck with the project!
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline   Reply With Quote
Old 07-10-2013, 05:59 PM   #181
808_67C10
808_67C10's Avatar
Thanks for the tips. I am using a Lincoln electric Mig Pak with no gas... it works "okay" for sheetmetal but, I wouldnt use it on anything thicker... I really need to upgrade but, I dont have a clue where to go from here. I would love to learn how to TiG but, a TiG set up isnt cheap. I definately need to upgrade to a gas MiG soon - Especially if I go forward with bagging it. ...and to be honest, I just love to weld. Its thereputic! LOL
Old 07-10-2013, 07:38 PM   #182
Mr.Hyde
I always thought the mig pak you can put a tank on? I have a 140c myself and mig actually is metal inert gas so I think you can put a bottle on.
Old 07-10-2013, 09:38 PM   #183
808_67C10
808_67C10's Avatar
The one I have is the cheapest "hobbyist" model... I checked and it doesnt have input.
This is the one I have: http://www.homedepot.com/p/Lincoln-E...88-1/100031840
I have a tank, regulator and hose, just need to get higher model welder. I have been told stick is easier but... never tried it.
Old 07-11-2013, 12:20 AM   #184
Mr.Hyde
Ah dang well the problem with stick is your rods need to be dry so typically kept in an oven although great for thicker material and is a totally different technique because you need to move towards the material (feed the rod) as you make that side to side motion I always thought if I were to go big 240v I'd go stick/tig combo because if one can't do the other can. But if you just want to upgrade your mig and you are stuck with 140 plan on upgrading to 240 at some point or want to be able to go back and forth apparently the lincoln 180 is great for that it will run like a 140c on 110v and when you need more juice toss it on a 240v circuit.
Old 07-11-2013, 11:14 AM   #185
jlsanborn
jlsanborn's Avatar
If you've already got the bottle then I'd put your flux core machine on Craigslist and upgrade. You'll be amazed by the clean welds you will be putting down. If you've got a 240V receptacle available go that route. The welders have a short power cord, so make an extension cord too.
Old 07-11-2013, 02:10 PM   #186
808_67C10
808_67C10's Avatar
I would love to go to a 240 machine. I live in military (base) housing for 2 more years. My only 240 outlet is upstairs in the laundry room so, I am limited to 110 till I retire in a couple years... then, you better believe I will have 240 in my garage/shop.
Good call on the CL deal.. maybe I will sell mine and get a adaptable model.
Old 07-29-2013, 10:31 PM   #187
808_67C10
808_67C10's Avatar
Had planned some garage time but, damn hurricane coming through! Good times!
Old 07-30-2013, 12:25 PM   #188
808_67C10
808_67C10's Avatar
emailed BONSPEED about the rims 2 weeks ago for some info and got no response... WOW, you would think as much as these rims cost new, they would have some customer service worth a $hit... but, NO...
Old 08-03-2013, 12:11 PM   #189
808_67C10
808_67C10's Avatar
Acid washed the wheels, took off the 1" spacers in the front and dropped it 2 more inches in the front. I also got the front fenders mounted. Should have the grill and hood back on today.
Old 08-03-2013, 12:19 PM   #190
808_67C10
808_67C10's Avatar
Old 08-07-2013, 03:51 PM   #191
808_67C10
808_67C10's Avatar
Got the front end back on... still have some issues but, its back on the road!
Old 08-07-2013, 07:48 PM   #192
Hardesty454
Hardesty454's Avatar
Wow that looks good! What are the issues?
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 08-09-2013, 12:43 AM   #193
808_67C10
808_67C10's Avatar
The grill panel isn't matching up on the passenger side so the hood isn't sitting good. They are aftermarket fenders with an OG hood and grill panel...I think it's the fender to be honest. I need to roll the fenders too...had altitude scrape action on a turn/bump.
Old 08-10-2013, 12:55 PM   #194
808_67C10
808_67C10's Avatar
Working on converting the wires from the idiot light guage panel to the guages. All the directions I find are a little confusing...
Old 08-10-2013, 07:20 PM   #195
gdavis
gdavis's Avatar
I wish I could say that. I want my truck to be in the Christmas parade this year. But only wishful thinking I guess. But I am running out of time in a hurry. Like what I see and happy building.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 08-11-2013, 12:28 AM   #196
808_67C10
808_67C10's Avatar
Thanks for the props, it still isn't really drivable but, it's getting there. I still have to do the corners, rockers and bottom of the doors... That's why she is krylon flat black for now.
Old 08-17-2013, 02:05 PM   #197
808_67C10
808_67C10's Avatar
Takin da 67 out for a cruise today for the first time in 8 months. She needs some sun.
Old 08-27-2013, 02:46 PM   #198
808_67C10
808_67C10's Avatar
all cleaned up... working on some wiring issues with my guage panel but... its getting there.
Old 08-27-2013, 03:17 PM   #199
jlsanborn
jlsanborn's Avatar
Looks really good man!
Old 08-27-2013, 04:40 PM   #200
C_Ruiz
Very interesting build so far!
I'm liking it.
I scored a set of centerline Millenium wheels with 85% tread tires for cheap. (Cost $3100 total for everything) I couldn't pass them up either.
Unfortunately, I think I'm going to have the sane issue you did with your powdercoated wheels where the rear wheel was way inside the fender?
Anywho, keep the updates coming!
C_Ruiz is offline   Reply With Quote
