Old 07-06-2012, 11:16 PM   #176
shadow1967
shadow1967's Avatar
Re: 1959 Fleetside REBORN
Here's how the day ended. I found a couple of problems and figured a way out. We have all been there.....couple of cups of coffee later and waalaa.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 07-07-2012, 01:01 AM   #177
Kim57
Kim57's Avatar
Looking good.
What were the problems?
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-07-2012, 02:17 AM   #178
shadow1967
shadow1967's Avatar
Problems were ride height issue. Red circle is the block intended to mount the cradle to. Which inturn would give me 3" of travel(up), the yellow circle. When I removed the 2" block, I get 1" travel. So it's a c-notch issue. And add some round tubing to the cradle mount to transfer some load. Then if that is not enough, I will plate the bottom side of the upper arm and remove the upper layer plate and that will give me another .75". Also to remove some of the load at the upper cradle mount use poly bushing, with aluminum bushing at the lower cradle mount(solid mounting). With the x-member sharing that load.
Old 07-07-2012, 09:01 PM   #179
shadow1967
shadow1967's Avatar
We got the problems fixed. Have not c-notched the 2x4 tube on the outside yet, will do that when we flip the frame. The red tube is new, the yellow tubes were planned. The red tube also adds support to the cradle mount plate. First pic is start of day, last 4 are the end of day.
Old 07-07-2012, 11:23 PM   #180
Kim57
Kim57's Avatar
Coming along nicely.
Kim
My build thread
Old 07-08-2012, 10:37 AM   #181
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Keep at it and you'll be driving it soon!
ChuckDriver is offline   Reply With Quote
Old 07-09-2012, 10:19 PM   #182
shadow1967
shadow1967's Avatar
the suspension is set at ride height, pinion angle is set and motor is ready to be mated to frame. This saturday, better hurry up an get thing ready like the core support and radiator......There is a reason the front rearend mounts are not made yet. You will have to stay tuned in! Clue: old school weight transfer/leverage?
Old 07-09-2012, 11:18 PM   #183
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking great man, looking really great. Keep the pics coming.
Kabwe is offline   Reply With Quote
Old 07-10-2012, 05:47 PM   #184
shadow1967
shadow1967's Avatar
Since I have not said it yet! Thank for the encouragement. I have only been thinking of the deadline, 45 days away. AUG 25,1012, this is the date I would like to see it moving under it's own power. Taking it to the El Segundo car show as a rat rod would be a bonus.
Old 07-10-2012, 07:46 PM   #185
shadow1967
shadow1967's Avatar
Some items showed up, going to the metal shop to look through the scrap pile. 2 pieces 24x14x.25 aluminum should do....
Old 07-11-2012, 08:20 PM   #186
shadow1967
shadow1967's Avatar
My cradle bushing came along with all the other bushing front and rear. WoW! these things are huge.
Old 07-11-2012, 10:11 PM   #187
shadow1967
shadow1967's Avatar
WE finished roughing in the 1967-69 camaro radiator. You are going to ask why a camaro rad., because out on the road there is a higher chance of finding one to get me home.
Old 07-11-2012, 11:49 PM   #188
Kim57
Kim57's Avatar
Where did you get your radiator from?
Kim
My build thread
Old 07-12-2012, 01:17 PM   #189
_Ogre
_Ogre's Avatar
that radiator looks like it was meant to be there.
looking good
shop air compressor timer
Old 07-12-2012, 06:02 PM   #190
shadow1967
shadow1967's Avatar
I added some 1.25 L-stock next to the orginal mounting syrface to make room for the new ones.Leaving the original ones so you could use an original radiator if needed. Griffin 8-70009-LS Dominator Series, This is the radiator numbers. As you can see, I did not abstruct the fin area.
Link....
Amazon.com: Griffin 8-70009-LS Dominator Series... Amazon.com: Griffin 8-70009-LS Dominator Series...
Old 07-12-2012, 07:35 PM   #191
shadow1967
shadow1967's Avatar
Also there are 4 bolt and 1 nut holding it on. The stud for the nut is there to support it while you put the bolts in.
Old 07-13-2012, 09:23 PM   #192
shadow1967
shadow1967's Avatar
We got the engine semi-placed. Need to cut firewall just like everyone else..Steering issues...
Old 07-14-2012, 08:48 PM   #193
shadow1967
shadow1967's Avatar
Ever walk out to the garage and go "OH MY GOD". After todays adventure I went in to clean up, Grabbed a slice of pizza and said I would be right back. Then I opened the side door to the garage and...... well you know what happened next.....Guess I have some cleaning to do.
Old 07-14-2012, 11:36 PM   #194
BC Toy chest
BC Toy chest's Avatar
LOOKIN' GOOD. Can't wait to see her when she's done.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 07-15-2012, 09:22 PM   #195
shadow1967
shadow1967's Avatar
I'm a day late with pics. This was saturday... Cab removal day. Thanks to rhodog77 for the idea for the lift. Darth Vader Lives....
Old 07-15-2012, 09:34 PM   #196
shadow1967
shadow1967's Avatar
This is sunday. First thing is a cleanup. Second is place engine where we put the marks friday.
Old 07-15-2012, 09:41 PM   #197
ChuckDriver
Nice work1 What are your plans for cleaning/painting the frame?
Old 07-15-2012, 09:42 PM   #198
shadow1967
shadow1967's Avatar
End of sunday...40 days to El Segundo car show.
Old 07-15-2012, 10:16 PM   #199
shadow1967
shadow1967's Avatar
You snuck one in. Paint whats that! Powder coat!
I am going to get it drivable, so I can drive it as is. To work out some bug if any. I would hate to have to add a bracket or some sutch thing after it was powder coated.
Old 07-16-2012, 08:39 AM   #200
ricott
Man your project is really coming along. If you don't work your poor ole dad to death, you are going to have it in driving condition in record time (at least the way I build!). From the looks of the wood holding the front of the Camaro rear end in place, I'm assuming you are going to make some sort of cantilevered Air Bag set up to lay the back down like the front. When you got the engine in, is your oil pan going to have to be changed?
PS - I know it wasn't the case with your build, but I've filed away the "Honey the motor broke so I need to do a minor rework" line for a 1972 corvette convertible that I want to update with a LS6/T56 in the future.
Ricky
ricott is offline   Reply With Quote
