Old 12-02-2012, 10:46 PM   #176
19GMC66
19GMC66's Avatar
Re: DURG's Black 65 C10
Really dig your truck and love the Coys!
19GMC66 is offline   Reply With Quote
Old 12-02-2012, 10:49 PM   #177
DURG
DURG's Avatar
Thanks, yours too! I actually have yours for a screen saver until I can get a picture of mine outside.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 12-03-2012, 12:20 PM   #178
Desert.Chevy
Desert.Chevy's Avatar
Just finished going through the build thread and I have to say Awesome build !! and you do great work.
Desert.Chevy is offline   Reply With Quote
Old 12-24-2012, 12:07 PM   #179
DURG
DURG's Avatar
Merry Christmas all.
I have been slowly continuing some fabrication, repairs and mocking up some things.
At ride height, I have 1/4 degree camber with no shims so Nate is making me a set of upper a-arms 3/8" shorter.
I got the Porterbuilt panhard setup installed and final welded.
I have repaired one of the messes made on a set of step side type? rear back up lights that was installed and they drilled about six holes in each side when mounting so I cut out the areas with holes and welded in a patch. One side still left to do.
I have included a photo from the rear of the bed to see how high the bed frame is raised.
I got the rear sill 2x3 final welded and have put a few supports in from the sills up to the new bed frame.
Old 12-24-2012, 12:15 PM   #180
DURG
DURG's Avatar
Old 12-24-2012, 04:12 PM   #181
mark 66
If I owned your truck I think I would try to autocross it. with the suspension set up you have you can probably get it handling really well.
mark 66 is offline   Reply With Quote
Old 12-25-2012, 12:32 AM   #182
19GMC66
19GMC66's Avatar
I can't stop reading this thread one of my favorites think I will have to build one with this coil over set up and an LS motor!
Old 12-25-2012, 02:09 AM   #183
65shortbox
65shortbox's Avatar
I completely agree! This will be the direction I take with my build if/when that day comes.
65shortbox is offline   Reply With Quote
Old 12-25-2012, 10:35 AM   #184
Bomp
Bomp's Avatar
x2
Really organized and clean. Like the 62 Impala SS too.
Bomp is offline   Reply With Quote
Old 12-25-2012, 11:47 AM   #185
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Nice work. Very nice.
I like the coil over suspension..
I am going to need to figure out how to apply that to my build.
I think Nate at Porterbuilt should give me a job since I live 5 minutes from his shop.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 12-30-2012, 02:39 AM   #186
69 chevy 1
69 chevy 1's Avatar
durg that is a super sick ride you have, im thinking of putting black on my suburban also,that is just nice work on a pretty truck
69 chevy 1 is offline   Reply With Quote
Old 01-07-2013, 01:47 PM   #187
mooseknuckles
mooseknuckles's Avatar
awesome build!
mooseknuckles is offline   Reply With Quote
Old 01-07-2013, 03:17 PM   #188
DURG
DURG's Avatar
Thanks for all the comments.
I have received some of the parts for my rear swaybar and when the rest come in that is the next project. The right side is kind of a busy area to hook it up to where the coilover, frame, and panhard bar all take up the same space. I have a plan, I just need to have more parts in hand to see if it will all work. I am going with an 1-1/4" hollow bar with splined ends and aluminum arms with heim joints.
I did get the left side back up light hole welded up but that is about all.
Old 01-12-2013, 08:19 AM   #189
DURG
DURG's Avatar
What do ya think?
Old 01-12-2013, 08:23 AM   #190
northern 85
northern 85's Avatar
Nice
northern 85 is offline   Reply With Quote
Old 01-12-2013, 12:39 PM   #191
Bomp
Bomp's Avatar
someones thinkin'
Old 01-12-2013, 12:41 PM   #192
DURG
DURG's Avatar
Starting mockup of the rear sway bar. I have ordered the splined bar and can mount the bushing brackets then.
Old 01-13-2013, 02:23 AM   #193
65shortbox
65shortbox's Avatar
Originally Posted by DURG View Post
What do ya think?
I love that a slammed short bed will be cruising the streets of Maine! Great work my friend...
Old 01-13-2013, 11:16 AM   #194
Desert.Chevy
Cool plate idea.
Old 01-13-2013, 12:05 PM   #195
Dinos63
chevy only
Dinos63's Avatar
great build and such nice work!! like the plate to
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 01-14-2013, 06:00 PM   #196
Solo2002
Solo2002's Avatar
LMAO looks like Dino beat ya to the plates Durg good thinking though love the truck
1966 C10 short stepper KMHK
Solo2002 is offline   Reply With Quote
Old 02-08-2013, 10:35 AM   #197
DURG
DURG's Avatar
Not much new. As seen in top photo the rear coilovers were short so the adjuster was way up onto the threaded body of the shock. Nate had Ride Tech drop ship me a new set of rear coilover springs with the same spring rate but two inches longer. The adjuster is now one inch up from the bottom of the threads which is much better. The 36.5" long 1-1/4" .095 wall hollow rear sway bar I ordered really needed to be a bit longer so I ordered a 37.5" long one. I hope that shows up soon so I can complete the rear sway bar install. Haven't really done much else and we are in the middle of what is supposed to be an 18-24" snow storm which is a PITA to deal with, so probably won't work in the garage on the truck this weekend either.
Old 02-09-2013, 12:08 PM   #198
65shortbox
65shortbox's Avatar
Hang in there. The truck looks great and glad to hear you got the correct springs. Hope that storm is easy on you all. Heck, even in So. Cal. it's difficult to get motivated to work on my project in the winter. Add kids sports practices and progress slows tremendously. The overall journey is a blast and seeing project like this truck keeps us all motivated. Looking forward to the updates!
Old 02-09-2013, 12:52 PM   #199
DURG
DURG's Avatar
The 18-24" of snow that was predicted was incorrect. As of 8:00 am this morning we had 29" and still snowing.
Old 02-17-2013, 12:34 PM   #200
DURG
DURG's Avatar
Rear suspension is now complete. The bolt on brackets will be welded and I will remove the top bolt and sleeves so as not to interfere with the bump stop installed on the underside of the notch. I will also need to weld up the 2 piece Porterbuilt rear end tube mounts when the pinion angle is final. I ended up with 15.5" long arms on the rear bar and it's 37.5 inches wide .095" diameter for a rating of ~175 lbs. @ 5 degrees of twist. I will probably drill some more holes in the arms just to make them look cooler when I tear the truck chassis back down for paint. I used the greaseable bushings. There does look like 10 pounds of **** in a 5 pound bag back here, but everything appears to have adequate clearance and should be fine.
